论坛
登录 | 立即注册
查看: 837|回复: 3
A9G Flight mode not reconnecting
新手上路
Rank: 1
发表于 2019-8-7 18:58:26 | 显示全部楼层 |阅读模式
I am trying to use the flightmode setting on the A9G board
the following works:  Network_SetFlightMode(true);
But when i set  Network_SetFlightMode(false); and then Network_StartAttach();
the device will not reconnect to the network.
How can i make it reconnect after i have i used the flight mode?
I am wanting to use the flight mode to see if this can save some power by shutting down the modem.
Also does PM_SleepMode disable the modem? or just reduce power consumption
Rank: 9Rank: 9Rank: 9
发表于 2019-8-30 17:11:26 | 显示全部楼层
Your operation is just to reduce power consumption and reduce the frequency.
新手上路
Rank: 1
 楼主| 发表于 2019-8-30 17:20:31 | 显示全部楼层
Yes – but I want to turn off the GSM modem to save more power.
When I detach from the network the device cannot reconnect.
I have tried the use the following ion different examples to make it reconnect – but none of these have worked,
Network_Register((uint8_t[]){0,0,0,0,0,0}, NETWORK_REGISTER_MODE_MANUAL_AUTO);
I want to make the device as low power as possible until it is time to wake up again.
Does setting the device PM_SleepMode(true); turn off the modem? Or it just makes the device slower?
Rank: 2
发表于 2019-9-30 20:18:21 | 显示全部楼层
If you have a gamepad it uses classic flight mode, I play with one and is ok, still use the mouse and keyboard for some stuff, but all flying is done with an X-box controller.
<a href=https://prom-electric.ru/>.</a>
手机版|小黑屋|安信可论坛
GMT+8, 2020-6-3 00:39 , Processed in 0.020764 second(s), 14 queries , Redis On.
Powered by Discuz! X3.3
© 2001-2017 Comsenz Inc.
快速回复 返回顶部 返回列表
