论坛
登录 | 立即注册 设为首页收藏本站 切换到宽版
查看: 277|回复: 1
关于ESP32使用aliyun mqtt例程失败
Rank: 2
发表于 2019-8-28 23:57:43 | 显示全部楼层 |阅读模式
I (3759) event: sta ip: 192.168.31.189, mask: 255.255.255.0, gw: 192.168.31.1
E (3769) wrapper_product: NVS Flash init fctry failed, Please check that you have flashed fctry partition!!!
E (3779) wrapper_product: NVS Flash init fctry failed, Please check that you have flashed fctry partition!!!
mqtt_main|124 :: mqtt example
E (3789) wrapper_product: NVS Flash init fctry failed, Please check that you have flashed fctry partition!!!
E (3799) wrapper_product: NVS Flash init fctry failed, Please check that you have flashed fctry partition!!!
[err] IOT_MQTT_Construct(395): Invalid product key, abort!
mqtt_main|227 :: MQTT construct failed
E (3819) FreeRTOS: FreeRTOS Task "mqtt_example" should not return, Aborting now!
abort() was called at PC 0x4008d1ff on core 1
0x4008d1ff: vPortTaskWrapper at D:/msys32/home/Administrator/esp/esp-idf/components/freertos/port.c:403
ELF file SHA256: f9c1359151487bb8ff8464aa8eb7edc45334155a65d2b46a6aacb7e9737a2209
Backtrace: 0x40086fe8:0x3ffc9250 0x40087235:0x3ffc9270 0x4008d1ff:0x3ffc9290
0x40086fe8: invoke_abort at D:/msys32/home/Administrator/esp/esp-idf/components/esp32/panic.c:715
0x40087235: abort at D:/msys32/home/Administrator/esp/esp-idf/components/esp32/panic.c:715
错误信息如上述所示。
例程链接https://github.com/espressif/esp-aliyun ... tt_example
信息提示连接wifi成功,但是提示错误信息NVS Flash 初始化fctry失败,要我检查是否flash过fctry分区,但是我已经按照readme中进行分区写操作了,求大大们教教如何操作!谢谢!
Rank: 2
 楼主| 发表于 2019-9-1 21:01:31 | 显示全部楼层
已解决,原因是分区配置那里的partitions.csv没有改成partitions_esp32.csv,另外可能和我经常取消编译和配置导致esp-idf部分文件出错有关。
手机版|小黑屋|安信可论坛
GMT+8, 2020-1-24 12:15 , Processed in 0.015505 second(s), 13 queries , Redis On.
Powered by Discuz! X3.3
© 2001-2017 Comsenz Inc.
快速回复 返回顶部 返回列表
