AiPi-SCP-2.4编译失败,请指教!
molun
小安派Cam 2219 11 2023-8-29 08:48:59
官方源码编译失败,快来看看怎么解决?
  1. [100%] Linking C executable build_out\mqtt_bl616.elf
  2. d:/ai-thinker/toolchain_gcc_t-head_windows/bin/../lib/gcc/riscv64-unknown-elf/10.2.0/../../../../riscv64-unknown-elf/bin/ld.exe: build_out\mqtt_bl616.elf section `.nocache_ram_region' will not fit in region `nocache_ram_memory'
  3. d:/ai-thinker/toolchain_gcc_t-head_windows/bin/../lib/gcc/riscv64-unknown-elf/10.2.0/../../../../riscv64-unknown-elf/bin/ld.exe: region `nocache_ram_memory' overflowed by 11524 bytes
  4. collect2.exe: error: ld returned 1 exit status
  5. make[3]: *** [CMakeFiles\mqtt_bl616.elf.dir\build.make:116: build_out/mqtt_bl616.elf] Error 1
  6. make[2]: *** [CMakeFiles\Makefile2:734: CMakeFiles/mqtt_bl616.elf.dir/all] Error 2
  7. make[1]: *** [Makefile:90: all] Error 2
  8. make: *** [../aithinker_Ai-M6X_SDK/project.build:73: build] Error 2
  9. PS D:\Ai-Thinker\AiPi-Open-Kits\AiPi-SCP-2.4>
2023-8-29 08:58:26
静等我们工程师的教程!
2023-8-29 09:37:45
爱笑 发表于 2023-8-29 08:58
静等我们工程师的教程!
2023-8-29 13:24:43
我也是失败!哎!
2023-8-29 18:16:15
插眼
2023-8-29 18:19:32
再插一个
2023-8-29 18:48:56
俺也一样
2023-8-29 18:52:41
点一个赞
2023-8-29 20:10:14
同样的错,插眼等攻城狮回复
2023-8-30 16:37:45
  • 会员数: 29452 个
  • 话题数: 42744 篇
