AIPi-SCP-2.4编译, ld的时候提示内存溢出, region `nocache_ram_memory' overflowed
marco
小安派Cam 825 8 2023-10-15 21:46:51
make -C build -j8
[  2%] Built target mm
[ 14%] Built target libc
[ 18%] Built target lhal
[ 21%] Built target bl6_os_adapter
[ 27%] Built target lwip
[ 46%] Built target app
[ 51%] Built target mbedtls
[ 51%] Built target shell
[ 51%] Built target ping
[ 51%] Built target dhcpd
[ 56%] Built target freertos
[ 58%] Built target utils
[ 59%] Built target rfparam
[ 63%] Built target std
[100%] Built target lvgl
[100%] Linking C executable build_out\mqtt_bl616.elf
c:/users/ait-m61/aipi-open-kits/aithinker_ai-m6x_sdk/toolchain_gcc_t-head_windows/bin/../lib/gcc/riscv64-unknown-elf/10.2.0/../../../../riscv64-unknown-elf/bin/ld.exe: build_out\mqtt_bl616.elf section `.nocache_ram_region' will not fit in region `nocache_ram_memory'        ache_ram_region'
c:/users/ait-m61/aipi-open-kits/aithinker_ai-m6x_sdk/toolchain_gcc_t-head_windows/bin/../lib/gcc/riscv64-unknown-elf/10.2.0/../../../../riscv64-unknown-elf/bin/ld.exe: region `nocache_ram_memory' overflowed by 11524 bytes        by 11524 bytes
collect2.exe: error: ld returned 1 exit status
make[3]: *** [CMakeFiles\mqtt_bl616.elf.dir\build.make:116: build_out/mqtt_bl616.elf] Error 1
make[2]: *** [CMakeFiles\Makefile2:734: CMakeFiles/mqtt_bl616.elf.dir/all] Error 2
make[1]: *** [Makefile:90: all] Error 2
make: *** [../aithinker_Ai-M6X_SDK/project.build:73: build] Error 2
2023-10-15 22:02:10
帮顶
2023-10-15 22:14:01
2023-10-16 08:12:28
帮顶
2023-10-16 09:01:15
给你抓个工程师解决!
我在使用win环境编译时,也遇到了,目前正在和原厂沟通
2023-10-16 09:56:13
在等修复
2023-10-16 11:31:09
工程师说已经修复了,拉取最新的SDK就可以了!
2023-10-16 13:23:09
[13:16:20.945] - ========= sp image create =========
[13:16:20.945] - Flash config crc: b'4fb1fe70'
[13:16:20.945] - Clock config crc: b'0b34ef89'
[13:16:20.945] - Image Offset:0x1000
[13:16:20.947] - Image hash is b'69de5b7af45fea2e456fb6864612126bbdad58e69294d1466a2f892e010d1f3d'
[13:16:20.948] - Encrypt efuse data
[13:16:20.949] - Image Offset:0x1000
[13:16:20.949] - Bootheader config crc: b'f9cf01e0'
[13:16:20.950] - create OTA file:C:\Users\ait-m61\AiPi-Open-Kits\AiPi-SCP-2.4\build\build_out\AiPi-SCP-2.4_bl616.bin.ota
[13:16:21.056] - create XZ file:C:\Users\ait-m61\AiPi-Open-Kits\AiPi-SCP-2.4\build\build_out\AiPi-SCP-2.4_bl616.xz
[13:16:21.490] - create XZ OTA file:C:\Users\ait-m61\AiPi-Open-Kits\AiPi-SCP-2.4\build\build_out\AiPi-SCP-2.4_bl616.xz.ota
Built target combine
果然好了,谢谢
  • 会员数: 28296 个
  • 话题数: 40290 篇
