【板子申请】Ai-M61-32S开发环境搭建,过程截图如下
LMing
板子申请专区 754 3 2023-11-11 20:21:51
1.VSCode&Git
VSCode
Git
2.小安派 源码工程 克隆
1.克隆源码
直接在桌面或者某个文件夹里找个空的位置点击 **鼠标右键** 选择 Open Git bash here 即可打开安装好的git 工具。接着输入指令(可以复制运行):
开始克隆小安派的SDK。
2.拉取M61的SDK 子模块
进入AiPi-Open-Kits 中,用文本打开.gitmodules 文件url 参数中的 github.com 改成gitee.com
然后在**git 工具**中分别执行:
cd AiPi-Open-Kits/
3.拉取M61 SDK中的子模块
1)进入到SDK中拉取子模块
逐条运行以下指令:
cd aithinker_Ai-M6X_SDK/
2)克隆适用Windows 的编译工具链
三、编译工具路径设置
aithinker_Ai-M6X_SDK\toolchain_gcc_t-head_windows\bin   //添加工具链路径
aithinker_Ai-M6X_SDK\tools\make     //添加make路径
aithinker_Ai-M6X_SDK\tools\ninja    //添加nanja路径
4.验证是否成功设置
make -v
成功输出信息:
GNU Make 4.2.1
Built for x86_64-w64-mingw32
输入:
 riscv64-unknown-elf-gcc -v
成功时输出信息:
Using built-in specs.
COLLECT_GCC=D:\Desktop\AiPi-Open-Kits\aithinker_Ai-M6X_SDK\toolchain_gcc_t-head_windows\bin\riscv64-unknown-elf-gcc.exe
COLLECT_LTO_WRAPPER=d:/desktop/aipi-open-kits/aithinker_ai-m6x_sdk/toolchain_gcc_t-head_windows/bin/../libexec/gcc/riscv64-unknown-elf/10.2.0/lto-wrapper.exe
Target: riscv64-unknown-elf
Configured with: /mnt/ssd/jenkins_iotsw/slave/workspace/Toolchain/build-gnu-riscv/./source/riscv/riscv-gcc/configure --target=riscv64-unknown-elf --host=i686-w64-mingw32 --with-gmp=/mnt/ssd/jenkins_iotsw/slave/workspace/Toolchain/build-gnu-riscv/build-gcc-riscv64-unknown-elf/build-Xuantie-900-gcc-elf-newlib-mingw-V2.6.1/lib-for-gcc-mingw --with-mpfr=/mnt/ssd/jenkins_iotsw/slave/workspace/Toolchain/build-gnu-riscv/build-gcc-riscv64-unknown-elf/build-Xuantie-900-gcc-elf-newlib-mingw-V2.6.1/lib-for-gcc-mingw --with-mpc=/mnt/ssd/jenkins_iotsw/slave/workspace/Toolchain/build-gnu-riscv/build-gcc-riscv64-unknown-elf/build-Xuantie-900-gcc-elf-newlib-mingw-V2.6.1/lib-for-gcc-mingw --with-libexpat-prefix=/mnt/ssd/jenkins_iotsw/slave/workspace/Toolchain/build-gnu-riscv/build-gcc-riscv64-unknown-elf/build-Xuantie-900-gcc-elf-newlib-mingw-V2.6.1/lib-for-gcc-mingw --with-libmpfr-prefix=/mnt/ssd/jenkins_iotsw/slave/workspace/Toolchain/build-gnu-riscv/build-gcc-riscv64-unknown-elf/build-Xuantie-900-gcc-elf-newlib-mingw-V2.6.1/lib-for-gcc-mingw --with-pkgversion='Xuantie-900 elf newlib gcc Toolchain V2.6.1 B-20220906' CXXFLAGS='-g -O2 -DTHEAD_VERSION_NUMBER=2.6.1 ' --enable-libgcctf --prefix=/mnt/ssd/jenkins_iotsw/slave/workspace/Toolchain/build-gnu-riscv/build-gcc-riscv64-unknown-elf/Xuantie-900-gcc-elf-newlib-mingw-V2.6.1 --disable-shared --enable-threads=posix --enable-languages=c,c++ --without-system-zlib --enable-tls --with-newlib --with-sysroot=/mnt/ssd/jenkins_iotsw/slave/workspace/Toolchain/build-gnu-riscv/build-gcc-riscv64-unknown-elf/Xuantie-900-gcc-elf-newlib-mingw-V2.6.1/riscv64-unknown-elf --with-native-system-header-dir=/include --disable-libmudflap --disable-libssp --disable-libquadmath --disable-libgomp --disable-nls --disable-tm-clone-registry --src=/mnt/ssd/jenkins_iotsw/slave/workspace/Toolchain/build-gnu-riscv/./source/riscv/riscv-gcc --enable-multilib --with-abi=lp64d --with-arch=rv64gcxthead 'CFLAGS_FOR_TARGET=-Os   -mcmodel=medany' 'CXXFLAGS_FOR_TARGET=-Os   -mcmodel=medany'
Thread model: posix
四、编译天气站程序
1.在VScode 打开小安派仓库源码
打开 **VScode**,在VScode 打开AiPi-Open-Kits 文件夹,即可看到源码
2.编译AiPi-Eyes_weather
AiPi-Eyes_weather 是天气站的源码,选中该文件之后,鼠标右键选择在集成终端中打开,然后在终端输入:
make
开始编译源码。
2023-11-11 20:33:01
感谢楼主分享,学习了
2023-11-14 23:32:05
插个眼给园长看
2023-11-20 10:37:09
私信你了,小可爱。
  • 会员数: 29497 个
  • 话题数: 42821 篇
