新人配置环境求助
bliysfyt
Ai-M61系列 611 1 2023-11-11 21:34:55
在按照图片输入make后:
显示如下(只复制了最后几行)
  1. <p>Process F:\Aipi\AiPi-Open-Kits\AiPi-Eyes_weather\build\build_out\mfg_bl616_gu_af8b0946f_v2.26.bin</p><p>[21:20:52.099] - ========= sp image create =========       </p><p>[21:20:52.101] - Flash config crc: b'4fb1fe70'</p><p>[21:20:52.101] - Clock config crc: b'0b34ef89'</p><p>[21:20:52.101] - Image Offset:0x1000</p><p>-Eyes_weather\build\build_out\Eyes_bl616.xz</p><p>[21:20:52.872] - create XZ OTA file:F:\Aipi\AiPi-Open-Kits\AiPi-Eyes_weather\build\build_out\Eyes_bl616.xz.ota</p><p>Built target combine</p><p>cp ./../aithinker_Ai-M6X_SDK/bsp/board/bl616dk/config/edata.bin build/build_out</p><p>process_begin: CreateProcess(NULL, cp ./../aithinker_Ai-M6X_SDK/bsp/board/bl616dk/config/edata.bin build/build_out, ...) failed.</p><p>make (e=2): 系统找不到指定的文件。</p><p>make: *** [../aithinker_Ai-M6X_SDK/project.build:75: build] Error 2Process F:\Aipi\AiPi-Open-Kits\AiPi-Eyes_weather\build\build_out\mfg_bl616_gu_af8b0946f_v2.26.bin</p><p>[21:20:52.099] - ========= sp image create =========       </p><p>[21:20:52.101] - Flash config crc: b'4fb1fe70'</p><p>[21:20:52.101] - Clock config crc: b'0b34ef89'</p><p>[21:20:52.101] - Image Offset:0x1000</p><p>-Eyes_weather\build\build_out\Eyes_bl616.xz</p><p>[21:20:52.872] - create XZ OTA file:F:\Aipi\AiPi-Open-Kits\AiPi-Eyes_weather\build\build_out\Eyes_bl616.xz.ota</p><p>Built target combine</p><p>cp ./../aithinker_Ai-M6X_SDK/bsp/board/bl616dk/config/edata.bin build/build_out</p><p>process_begin: CreateProcess(NULL, cp ./../aithinker_Ai-M6X_SDK/bsp/board/bl616dk/config/edata.bin build/build_out, ...) failed.</p><p>make (e=2): 系统找不到指定的文件。</p><p>make: *** [../aithinker_Ai-M6X_SDK/project.build:75: build] Error 2</p>
应该怎么办?
更新:问题解决了
按照如下办法,链接在评论区
2023-11-11 21:39:40
  • 会员数: 29497 个
  • 话题数: 42821 篇
