(用啥学啥)NTC热敏电阻二次查询法
lsrly
技术杂谈 904 6 2023-11-17 10:59:38
(用啥学啥)NTC热敏电阻二次查询法
一,定义变量数组
1.定义NTC 温度把对应的ADC值(这个要根据你所用的串联电阻和NTC及单片机ADC范围来计算)
static const uint32_t NTC_ADC_Table[] =// 5K NTC ADC值
      10228,9865,9513,9170,8838,8515,8203,7900,7607,7323,
      7050,6785,6530,6283,6044,5817,5596,5383,5179,4982,
      4792,4610,4435,4266,4104,3948,3799,3655,3517,3385,
      3257,3135,3021,2905,2797,2693,2593,2497,2405,2317,
      2233,2151,2073,1998,1926,1857,1790,1726,1665,1606,
      1550,1495,1443,1393,1344,1298,1253,1210,1169,1130,
      1091,1054,1019,985,952,921,891,862,833,806,
      780,755,731,707,685,663,642,622,602,584,
      635,548,531,515,499,484,470,455,442,429,
      416,404,392,380,369,358,348,338,328,319,
      310,301,293,284,276,269,261,254,247,240,
      233,227,221,215,209,203,198,193,188,183,
2.定义NTC所对应的温度
static const sint16 NTC_temperature_table[] = //温度表
        -20, -19, -18, -17, -16, -15, -14, -13, -12, -11,
        -10, -9, -8, -7, -6, -5, -4, -3, -2, -1,
        0, 1, 2, 3, 4, 5, 6, 7, 8, 9,
        10, 11, 12, 13, 14, 15, 16, 17, 18, 19,
        20, 21, 22, 23, 24, 25, 26, 27, 28, 29,
        30, 31, 32, 33, 34, 35, 36, 37, 38, 39,
        40, 41, 42, 43, 44, 45, 46, 47, 48, 49,
        50, 51, 52, 53, 54, 55, 56, 57, 58, 59,
        60, 61, 62, 63, 64, 65, 66, 67, 68, 69,
        70, 71, 72, 73, 74, 75, 76, 77, 78, 79,
        80, 81, 82, 83, 84, 85, 86, 87, 88, 89,
        90, 91, 92, 93, 94, 95, 96, 97, 98, 99,
二,获取ADC值
uint32_t get_ntc()
  uint32_t TMVale = 0;
  for (int i = 0; i < 10; i++)
    TMVale += analogRead(A0);
    delay(10);
  TMVale = TMVale / 10;
  return TMVale;
三,根据ADC使用二次查询法查ADC值在NTC_ADC_Table[]表的位置
float get_temperature()
float temperature=0.0;
float temperxiaoxu=0.0;
  uint16_t start=0,end=120,middle=0;
  /********获取数组的长度**********/
  //end = sizeof( NTC_ADC_Table) / sizeof( NTC_ADC_Table[0]);
  uint32_t ntcvalue = get_ntc()*10;                                       // 获取NTC的ADC值
  //float resistance = (float)(1023 - ntcvalue) * 10000 / ntcvalue; // 计算NTC的电阻值
   Serial.print( "adc");
  Serial.println(ntcvalue);
  while (start <= end)
    Serial.print( "start=");
    Serial.println(start);
    Serial.print( "end=");
    Serial.println(end);
    middle = (start + end)/2; //折半
    if(ntcvalue== NTC_ADC_Table[middle])break; //值相等,说明查到了,退出循环
    if((ntcvalue< NTC_ADC_Table[middle])&&(ntcvalue> NTC_ADC_Table[middle+1]))break;//在两者之间退出循环
    if (ntcvalue >  NTC_ADC_Table[middle]) //当前值大于数组中间数值 说明要查找的数在前一半
       end= middle - 1;  //前一半的数组头不变 数组尾重新分配
    else if (ntcvalue <  NTC_ADC_Table[middle])// //当前AD值小于数组中间数值 说明要查找的数在后一半
      start = middle + 1;   //前一半的数组尾不变 数组头重新分配
    Serial.print( "middle=");
    Serial.println(middle);
    temperxiaoxu=(NTC_ADC_Table[middle]-NTC_ADC_Table[middle+1]);
    temperxiaoxu=(NTC_ADC_Table[middle]-ntcvalue)/temperxiaoxu;
    temperature=NTC_temperature_table[middle]+temperxiaoxu;
  return temperature;
四,调用get_temperature()获得对应的温度
2023-11-17 11:06:57
优秀!
2023-11-17 15:15:34
有理有据,就喜欢大家像这样能落地生根的!赞一个!
乍一看标题我还以为是我写的呢!加油!
2023-11-17 15:43:13
厉害了
2023-11-18 23:48:00
生搬硬套...
在纸上计算清楚,或者用xls先搞清楚,一次查表,不好吗?
本来是 一一对应关系啊。
另外,如果为了适配多种ADC,多种电阻,多种情况,分步骤完成,也可以。但是,你的代码也没有相关处理啊 ~
2023-11-19 09:14:10
一般情况查表能对应起来的概率不大,只能速温度才能对应,你要想得到小数位的,只能查个温度范围在去处理,我是查那个温度范围之间,如在14-15度之间,然后在把他们两个的ADC值差值分成10份,得到小位数,当然这只是我的想法,还请大佬们多多指教
2024-1-1 12:19:20
6
  • 会员数: 28904 个
  • 话题数: 41456 篇
