啃小安派代码-3-小安派AiPi-Eyes_weather
ckdsx.cn
小安派&M61基本系统教程 1077 5 2023-11-21 08:36:41
工程目录:AiPi-Open-Kits/AiPi-Eyes_weather
文件目录:AiPi-Open-Kits/AiPi-Eyes_weather / main.c
使用指南
1.功能介绍
  自动连接: AiPi-Eyes 天气站会自动连接历史连接过的WiFi
  自动更新时间: 根据SNTP 服务器更新时间
  自动更新天气情况: 通过HTTPS 获取天气情况
  支持触摸配网: 可以利用键盘输出相应的SSID及PASSWORD 配置网络
  支持未来七天的天气预报,默认显示三天
2.配网操作
点击 右上角的"WiFi"网络图标后,会切换到配网界面,在SSID 输入框中输入WiFi 名称,在PASS输入框中输入WiFi密码后,点击 "确定按钮"后可触发配网,配网成功后会自动切换到主页面。
main 工程代码:
* Licensed to the Apache Software Foundation (ASF) under one or more
* contributor license agreements.  See the NOTICE file distributed with
* this work for additional information regarding copyright ownership.  The
* ASF licenses this file to you under the Apache License, Version 2.0 (the
* "License"); you may not use this file except in compliance with the
* License.  You may obtain a copy of the License at
*   http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an "AS IS" BASIS, WITHOUT
* WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.  See the
* License for the specific language governing permissions and limitations
* under the License.
  * Included Files  加载各种头文件
#include "FreeRTOS.h"
#include "task.h"
#include "timers.h"
#include <lwip/tcpip.h>
#include <lwip/sockets.h>
#include <lwip/netdb.h>
#include "sntp.h"
#include "bl_fw_api.h"
#include "wifi_mgmr_ext.h"
#include "wifi_mgmr.h"
#include "bflb_irq.h"
#include "bflb_uart.h"
#include "bflb_l1c.h"
#include "bflb_mtimer.h"
#include "bl616_glb.h"
#include "rfparam_adapter.h"
#include "board.h"
#define DBG_TAG "MAIN"
#include "log.h"
#include "lv_conf.h"
#include "lvgl.h"
#include "lv_port_disp.h"
#include "lv_port_indev.h"
#include "demos/lv_demos.h"
#include "lcd.h"
#include "portable.h"
  //#include "fhost.h"
#include "gui_guider.h"
#include "custom.h"
#include "easyflash.h"
#include "bflb_mtd.h"
extern xQueueHandle queue;
* Pre-processor Definitions  预处理器定义
#define WIFI_STACK_SIZE     (1536)
#define TASK_PRIORITY_FW    (16)
  * Private Types  私有类型
   * Private Data   专用数据
static struct bflb_device_s* uart0;
#if 1
static TaskHandle_t wifi_fw_task;
static wifi_conf_t conf =
    .country_code = "CN",
static uint32_t sta_ConnectStatus = 0;
extern void shell_init_with_task(struct bflb_device_s* shell);
extern int es8388_voice_init(void);
extern int audio_init(void);
extern int audio_pcm_init(void);
extern void play_voice_open(void);
extern void play_voice_close(void);
static int bl61x_get_heap_size(void);
* Private Function Prototypes 私有函数原型
  * Functions 函数
int wifi_start_firmware_task(void)  // wifi 开始固件任务
    LOG_I("Starting wifi ...\r\n");  //输出 Starting wifi ...
    /* enable wifi clock */   启用wifi时钟
    GLB_PER_Clock_UnGate(GLB_AHB_CLOCK_IP_WIFI_PHY | GLB_AHB_CLOCK_IP_WIFI_MAC_PHY | GLB_AHB_CLOCK_IP_WIFI_PLATFORM);
    GLB_AHB_MCU_Software_Reset(GLB_AHB_MCU_SW_WIFI);
    /* set ble controller EM Size */  可设置控制器EM大小
    GLB_Set_EM_Sel(GLB_WRAM160KB_EM0KB);
        LOG_I("PHY RF init failed!\r\n");
        return 0;
    LOG_I("PHY RF init success!\r\n");
    /* Enable wifi irq */   启用wifi irq
    extern void interrupt0_handler(void);
    bflb_irq_attach(WIFI_IRQn, (irq_callback)interrupt0_handler, NULL);
    bflb_irq_enable(WIFI_IRQn);
    xTaskCreate(wifi_main, (char*)"fw", WIFI_STACK_SIZE, NULL, TASK_PRIORITY_FW, &wifi_fw_task);
    return 0;
void wifi_event_handler(uint32_t code)  //wifi事件处理程序
    sta_ConnectStatus = code;
    switch (code) {
        case CODE_WIFI_ON_INIT_DONE:
            LOG_I("[APP] [EVT] %s, CODE_WIFI_ON_INIT_DONE\r\n", __func__);
            wifi_mgmr_init(&conf);
        break;
        case CODE_WIFI_ON_MGMR_DONE:
            LOG_I("[APP] [EVT] %s, CODE_WIFI_ON_MGMR_DONE\r\n", __func__);
        break;
        case CODE_WIFI_ON_SCAN_DONE:
            LOG_I("[APP] [EVT] %s, CODE_WIFI_ON_SCAN_DONE\r\n", __func__);
            wifi_mgmr_sta_scanlist();
        break;
        case CODE_WIFI_ON_CONNECTED:
            LOG_I("[APP] [EVT] %s, CODE_WIFI_ON_CONNECTED\r\n", __func__);
            void mm_sec_keydump();
            mm_sec_keydump();
        break;
        case CODE_WIFI_ON_GOT_IP:
            LOG_I("[APP] [EVT] %s, CODE_WIFI_ON_GOT_IP\r\n", __func__);
        break;
        case CODE_WIFI_ON_DISCONNECT:
            LOG_I("[APP] [EVT] %s, CODE_WIFI_ON_DISCONNECT\r\n", __func__);
        break;
        case CODE_WIFI_ON_AP_STARTED:
            LOG_I("[APP] [EVT] %s, CODE_WIFI_ON_AP_STARTED\r\n", __func__);
        break;
        case CODE_WIFI_ON_AP_STOPPED:
            LOG_I("[APP] [EVT] %s, CODE_WIFI_ON_AP_STOPPED\r\n", __func__);
        break;
        case CODE_WIFI_ON_AP_STA_ADD:
            LOG_I("[APP] [EVT] [AP] [ADD] %lld\r\n", xTaskGetTickCount());
        break;
        case CODE_WIFI_ON_AP_STA_DEL:
            LOG_I("[APP] [EVT] [AP] [DEL] %lld\r\n", xTaskGetTickCount());
        break;
        default:
            LOG_I("[APP] [EVT] Unknown code %u \r\n", code);
#endif
/* lvgl log cb */  lvgl日志cb
void lv_log_print_g_cb(const char* buf)
    printf("[LVGL] %s", buf);
static TaskHandle_t lvgl_TaskHandle;
#define LVGL_STACK_SIZE 1024    //定义LVGL堆栈大小为1024
#define LVGL_TASK_PRIORITY 15   //定义LVGL任务优先级为15
void lvgl_task(void* param)  //lvgl_任务
    while (1) //死循环
        lv_task_handler(); // lv任务处理程序
        vTaskDelay(1);  // 延时任务
        // bflb_mtimer_delay_ms(1);
void io2_set(uint8_t value)  // io2_设置
    struct bflb_device_s* gpio;
    bflb_gpio_init(gpio, GPIO_PIN_2, GPIO_OUTPUT | GPIO_PULLUP | GPIO_SMT_EN | GPIO_DRV_0);
    if (value)
        bflb_gpio_set(gpio, GPIO_PIN_2);  // gpio2 置位 =1
    else
        bflb_gpio_reset(gpio, GPIO_PIN_2);  // gpio2 复位 =0
uint8_t wifi_connect(char* ssid, char* passwd)  // wifi_连接
    int ret = 255;
    // struct fhost_vif_ip_addr_cfg ip_cfg = { 0 };
    uint32_t ipv4_addr = 0;
    static char* queue_buff;
    queue_buff = pvPortMalloc(128);
    memset(queue_buff, 0, 128);
    if (NULL==ssid || 0==strlen(ssid)) {
        return 1;
    if (wifi_mgmr_sta_state_get() == 1) {
        wifi_sta_disconnect();
    if (wifi_sta_connect(ssid, passwd, NULL, NULL, 0, 0, 0, 1)) {
        return 4;
    //等待连接成功
    for (int i = 0;i<10*30;i++) {
        vTaskDelay(100);
        switch (sta_ConnectStatus) {
            case CODE_WIFI_ON_CONNECTED:        //连接成功(表示wifi sta状态的时候表示同时获取IP(DHCP)成功,或者使用静态IP)
                break;;
            case CODE_WIFI_ON_DISCONNECT:        //连接失败(超过了重连次数还没有连接成功的状态)
                return 4;
                wifi_sta_ip4_addr_get(&ipv4_addr, NULL, NULL, NULL);
                printf("wifi connened %s,IP:%s\r\n", ssid, inet_ntoa(ipv4_addr));
                sprintf(queue_buff, "{\"ip\":{\"IP\":\"%s\"}}", inet_ntoa(ipv4_addr));
                flash_erase_set(SSID_KEY, ssid);
                flash_erase_set(PASS_KEY, passwd);
                xQueueSend(queue, queue_buff, portMAX_DELAY);
                return 0;
            default:
                //等待连接成功
                break;
    vPortFree(queue_buff);
    return 14; //连接超时
void lwip_sntp_init(void)  // lwip_sntp_初始化 sntp:简单网络时间协议
    sntp_setoperatingmode(SNTP_OPMODE_POLL);
    // sntp_setserver();
    // sntp_setservername(0, "pool.ntp.org");
    sntp_setservername(0, "ntp1.aliyun.com");   //连接阿里云
    // sntp_setservername(0, "114.67.237.130");
    sntp_init();  // 同步时间
    printf("getservername:%s\r\n", sntp_getservername(0));
static void bl61x_show_heap_size_task(void* arg)  // bl61x显示堆大小任务
    while (1) {
        LOG_F("[%s:%d]heap_size-------> %d\r\n", DBG_TAG, __LINE__, bl61x_get_heap_size());
        vTaskDelay(3000/portTICK_PERIOD_MS);
lv_ui guider_ui;  // 指南_用户界面
int main(void) //主程序
    board_init();  //初始化开发板
    // audio_init();
    // audio_pcm_init();
    // es8388_voice_init();
    // uart0 = bflb_device_get_by_name("uart0");
    // shell_init_with_task(uart0);
    // printf("HeapSize:%d\r\n",xPortGetFreeHeapSize());
    tcpip_init(NULL, NULL);  // 初始化 tcpip
    wifi_start_firmware_task();
    lwip_sntp_init();
    //init easyflash
    bflb_mtd_init();
    easyflash_init();
    /* lvgl init */
    lv_log_register_print_cb(lv_log_print_g_cb);
    lv_init();
    lv_port_disp_init();  //lv 显示端口初始化
    lv_port_indev_init();
    setup_ui(&guider_ui);
    printf("lv_task_handler\r\n");
    // lv_task_handler();
    custom_init(&guider_ui);
    printf("lvgl success\r\n");
    xTaskCreate(lvgl_task, (char*)"lvgl", LVGL_STACK_SIZE, NULL, LVGL_TASK_PRIORITY, &lvgl_TaskHandle);
    xTaskCreate(bl61x_show_heap_size_task, (char*)"heap", 1024, NULL, 2, NULL);
    vTaskStartScheduler();  // v任务启动计划程序
    // while (1) {
    while (1) {
        // printf("\r\n[%s] heap size ------------------- %d\r\n", __func__, xPortGetFreeHeapSize());
        vTaskDelay(5000/portTICK_RATE_MS);
static int bl61x_get_heap_size(void)  // bl61x获取堆大小
    struct meminfo info1 = { 0 };
    struct meminfo info2 = { 0 };
    uint32_t total_free_size = 0;
    // return xPortGetFreeHeapSize();
    bflb_mem_usage(KMEM_HEAP, &info1);
    bflb_mem_usage(PMEM_HEAP, &info2);
    total_free_size = info1.free_size + info2.free_size;
    return total_free_size;
2023-11-21 08:45:49
满满的都是代码
2023-11-21 08:47:20
一点点啃,难也不难!
2023-11-21 09:33:56
代码满满
2023-11-21 10:55:42
2023-11-23 08:36:18
厉害的不行
  • 会员数: 28374 个
  • 话题数: 40425 篇
