啃小安派代码-5-小安派 AiPi-Cam
ckdsx.cn
小安派&M61基本系统教程 964 7 2023-11-23 08:21:42
工程目录:AiPi-Open-Kits/ AiPi-Cam
文件目录:AiPi-Open-Kits/ AiPi-Cam/main.c
使用指南
1.功能介绍
  自动开热点: 使用手机或电脑连接热点:AiPi-CAM,密码:12345678
  web服务器: 打开网页输入网站192.168.169.1
  视频流: 点击Start Stream,观看摄像头影像
  拍照: 按键进行拍照存储SD卡
  闪光灯: 长按Burn按钮打开闪光灯
二、开发指南
1. 选择摄像头类型
在 “proj.conf” 文件中,屏蔽set(CONFIG_CHERRYUSB 1)函数,即可编译 DVP摄像头程序,启用该函数即编译USB摄像头程序(默认编译DVP摄像头程序)。
main 工程代码:
* Licensed to the Apache Software Foundation (ASF) under one or more
* contributor license agreements.  See the NOTICE file distributed with
* this work for additional information regarding copyright ownership.  The
* ASF licenses this file to you under the Apache License, Version 2.0 (the
* "License"); you may not use this file except in compliance with the
* License.  You may obtain a copy of the License at
*   http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an "AS IS" BASIS, WITHOUT
* WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.  See the
* License for the specific language governing permissions and limitations
* under the License.
  * Included Files  加载头文件
#include "FreeRTOS.h"
#include "task.h"
#include "timers.h"
#include <lwip/tcpip.h>
#include <lwip/sockets.h>
#include <lwip/netdb.h>
#include "bl_fw_api.h"
#include "wifi_mgmr_ext.h"
#include "wifi_mgmr.h"
#include "bflb_irq.h"
#include "bflb_uart.h"
#include "bl616_glb.h"
#include "rfparam_adapter.h"
#include "board.h"
#include "shell.h"
#include "mjpeg.h"
#include "pbuff_dvp.h"
#include "dbi_disp.h"
  // #include "auadc.h"
  // #include "audac.h"
#undef CONFIG_CHERRYUSB    //如果没定义 XX 就定义XX
#ifdef CONFIG_CHERRYUSB
#include "usbh_core.h"
#include "usbh_uvc_uac.h"
#else
volatile uint32_t g_uvc_fps = 0;
#endif
#define DBG_TAG "MAIN"
#include "log.h"
* user Definitions   用户自定义
#define USE_SD_FATFS    0
// #undef CONFIG_CHERRYUSB
#define USER_AP_NAME "AiPi-CAM"     //定义 AP模式下用户名
#define USER_AP_PASSWORD "12345678"      //定义AP模式下密码
* Pre-processor Definitions  预处理器定义
#define WIFI_STACK_SIZE  (1536)  //WIFI堆栈大小
#define TASK_PRIORITY_FW (16)   // 任务优先级
  * Private Types
   * Private Data  专用数据
static struct bflb_device_s* uart0;
static struct bflb_device_s* gpio;
static TaskHandle_t wifi_fw_task;
static wifi_conf_t conf = {
    .country_code = "CN",
extern void shell_init_with_task(struct bflb_device_s* shell);
* Private Function Prototypes
  * Functions
int wifi_start_firmware_task(void)  // wifi启动固件任务
    LOG_I("Starting wifi ...\r\n");
    /* enable wifi clock */   //启用wifi时钟
    GLB_PER_Clock_UnGate(GLB_AHB_CLOCK_IP_WIFI_PHY | GLB_AHB_CLOCK_IP_WIFI_MAC_PHY | GLB_AHB_CLOCK_IP_WIFI_PLATFORM);
    GLB_AHB_MCU_Software_Reset(GLB_AHB_MCU_SW_WIFI);
    /* set ble controller EM Size */  //可设置控制器EM大小
    GLB_Set_EM_Sel(GLB_WRAM160KB_EM0KB);
        LOG_I("PHY RF init failed!\r\n");
        return 0;
    LOG_I("PHY RF init success!\r\n");
    /* Enable wifi irq */   //启用wifi irq
    extern void interrupt0_handler(void);
    bflb_irq_attach(WIFI_IRQn, (irq_callback)interrupt0_handler, NULL);
    bflb_irq_enable(WIFI_IRQn);
    xTaskCreate(wifi_main, (char*)"fw", WIFI_STACK_SIZE, NULL, TASK_PRIORITY_FW, &wifi_fw_task);
    return 0;
void wifi_event_handler(uint32_t code)   // wifi事件处理程序
    switch (code) {
        case CODE_WIFI_ON_INIT_DONE: {
            LOG_I("[APP] [EVT] %s, CODE_WIFI_ON_INIT_DONE\r\n", __func__);
            wifi_mgmr_init(&conf);
        } break;
        case CODE_WIFI_ON_MGMR_DONE: {
            LOG_I("[APP] [EVT] %s, CODE_WIFI_ON_MGMR_DONE\r\n", __func__);
#ifndef SIMU_DATA_TEST
            LOG_I("[USB] uvc/uav start\r\n");
            usbh_video_test();
            //usbh_audio_test();
#endif
#endif
        } break;
        case CODE_WIFI_ON_SCAN_DONE: {
            LOG_I("[APP] [EVT] %s, CODE_WIFI_ON_SCAN_DONE\r\n", __func__);
            wifi_mgmr_sta_scanlist();
        } break;
        case CODE_WIFI_ON_CONNECTED: {
            LOG_I("[APP] [EVT] %s, CODE_WIFI_ON_CONNECTED\r\n", __func__);
            void mm_sec_keydump();
            mm_sec_keydump();
        } break;
        case CODE_WIFI_ON_GOT_IP: {
            LOG_I("[APP] [EVT] %s, CODE_WIFI_ON_GOT_IP\r\n", __func__);
        } break;
        case CODE_WIFI_ON_DISCONNECT: {
            LOG_I("[APP] [EVT] %s, CODE_WIFI_ON_DISCONNECT\r\n", __func__);
        } break;
        case CODE_WIFI_ON_AP_STARTED: {
            LOG_I("[APP] [EVT] %s, CODE_WIFI_ON_AP_STARTED\r\n", __func__);
        } break;
        case CODE_WIFI_ON_AP_STOPPED: {
            LOG_I("[APP] [EVT] %s, CODE_WIFI_ON_AP_STOPPED\r\n", __func__);
        } break;
        case CODE_WIFI_ON_AP_STA_ADD: {
            LOG_I("[APP] [EVT] [AP] [ADD] %lld\r\n", xTaskGetTickCount());
        } break;
        case CODE_WIFI_ON_AP_STA_DEL: {
            LOG_I("[APP] [EVT] [AP] [DEL] %lld\r\n", xTaskGetTickCount());
        } break;
        default: {
            LOG_I("[APP] [EVT] Unknown code %u \r\n", code);
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#include <FreeRTOS.h>
#include <task.h>
#include <queue.h>
#include <semphr.h>
#include <timers.h>
#define WIFI_HTTP_SERVER_STACK_SIZE  (1024 * 5)
#define HTTP_SERVERTASK_PRIORITY (15)
#define CAM_PROCESS_STACK_SIZE  (1024 * 1)
#define CAM_PROCESS_PRIORITY (14)
#define button_PROCESS_STACK_SIZE  (1024)
#define button_PROCESS_PRIORITY (14)
static TaskHandle_t http_server_task_hd;
static TaskHandle_t cam_process_task_hd;
static TaskHandle_t button_process_task_hd;
extern char* datajpeg_buf;
extern uint32_t datajpeg_len;
void* MuxSem_Handle = NULL;
static void fps_printf_task(void* pvParameters)
    // extern volatile uint32_t g_dbi_disp_fps;
    // extern volatile uint32_t g_dvp_fps;
    extern volatile uint32_t g_mjpeg_fps;
    extern volatile uint32_t g_uvc_fps;
    static char info_buffer[1024];
    while (1) {
        for (uint32_t i = 0; i < 5; i++) {
            printf("FPS ");
            // printf("lcd: %2d, ", g_dbi_disp_fps);
            // printf("dvp: %2d, ", g_dvp_fps);
            printf("mjpeg: %2d, ", g_mjpeg_fps);
            printf("uvc: %2d", g_uvc_fps);
            printf("\r\n");
            vTaskDelay(1000);
        vTaskGetRunTimeStats(info_buffer);
        printf("\r\n<taskname>   <runtime>   <cpu load>\r\n%s\r\n", info_buffer);
static void start_ap(void)  //启动ap
    wifi_mgmr_ap_params_t config = { 0 };
    config.channel = 3;
    config.key = USER_AP_PASSWORD;
    config.ssid = USER_AP_NAME;
    config.use_dhcpd = 1;
    if (wifi_mgmr_conf_max_sta(2) != 0) {
        return 5;
    if (wifi_mgmr_ap_start(&config) == 0) {
        return 0;
void http_server_task(void* param)   //http服务器任务
    start_ap();
    mhttp_server_init();
void button_process_task(void* param)   //按钮处理任务
    static uint32_t press_10ms_cnt = 0;
    uint32_t press_mode = 0;
    static bool led_ctrl = 0;
    uint32_t frames = 1;
    uint8_t* pBuf = NULL;
    uint32_t len;
    uint8_t* pStr2 = NULL;
    uint32_t len2;
    bflb_gpio_init(gpio, GPIO_PIN_2, GPIO_INPUT | GPIO_FLOAT | GPIO_SMT_EN | GPIO_DRV_0);
    bflb_gpio_init(gpio, GPIO_PIN_16, GPIO_OUTPUT | GPIO_FLOAT | GPIO_SMT_EN | GPIO_DRV_1);
    // bflb_gpio_reset(gpio, GPIO_PIN_16);
    while (1) {
        if (bflb_gpio_read(gpio, GPIO_PIN_2) == 1) {
            press_10ms_cnt++;
        else if (bflb_gpio_read(gpio, GPIO_PIN_2) == 0) {
            if (press_10ms_cnt > 10 && press_10ms_cnt < 100) {
                press_mode = 1;
            else if (press_10ms_cnt > 100) {
                press_mode = 2;
            press_10ms_cnt = 0;
        if (1 == press_mode) {
            press_mode = 0;
            printf("1 == press_mode\r\n");
#if USE_SD_FATFS
            xSemaphoreTake(MuxSem_Handle, portMAX_DELAY);
            if (bl_cam_frame_fifo_get(&frames, &pBuf, &len, &pStr2, &len2, 2) == 0)
                take_photo(pBuf, len);
                bl_cam_frame_pop();
                // printf("io2 pBuf:0x%x, len:%d\r\n", pBuf, len);
            xSemaphoreGive(MuxSem_Handle);
#endif
        else if (2 == press_mode) {
            press_mode = 0;
            led_ctrl = !led_ctrl;
            printf("led_ctrl:%d\r\n", led_ctrl);
            if (led_ctrl) {
                bflb_gpio_set(gpio, GPIO_PIN_16);
            else {
        vTaskDelay(10);
void cam_process_task(void* param)   //摄像头进程任务
    uint32_t len;
    uint32_t len2;
    while (1)
            bl_cam_frame_pop();
            datajpeg_buf = pBuf;
            datajpeg_len = len;
            // printf("pBuf:0x%x, len:%d\r\n", pBuf, len);
        vTaskDelay(10);
void create_http_server_task(void)  //创建http服务器任务
    MuxSem_Handle = xSemaphoreCreateMutex();
    if (NULL != MuxSem_Handle)
        printf("MuxSem_Handle creat success!\r\n");
    xTaskCreate(http_server_task, (char*)"fw", WIFI_HTTP_SERVER_STACK_SIZE, NULL, HTTP_SERVERTASK_PRIORITY, &http_server_task_hd);
    xTaskCreate(cam_process_task, (char*)"cam_proc_task", CAM_PROCESS_STACK_SIZE, NULL, CAM_PROCESS_PRIORITY, &cam_process_task_hd);
    xTaskCreate(button_process_task, (char*)"button_proc_task", button_PROCESS_STACK_SIZE, NULL, button_PROCESS_PRIORITY, &button_process_task_hd);
//fatfs
#include "fatfs_diskio_register.h"
#include "ff.h"
FATFS fs;
__attribute((aligned(8))) static uint32_t workbuf[4096];
MKFS_PARM fs_para = {
    .fmt = FM_FAT32,     /* Format option (FM_FAT, FM_FAT32, FM_EXFAT and FM_SFD) */
    .n_fat = 1,          /* Number of FATs */
    .align = 0,          /* Data area alignment (sector) */
    .n_root = 1,         /* Number of root directory entries */
    .au_size = 512 * 32, /* Cluster size (byte) */
void filesystem_init(void)
    FRESULT ret;
    board_sdh_gpio_init();
    fatfs_sdh_driver_register();
    ret = f_mount(&fs, "/sd", 1);
    // ret = FR_NO_FILESYSTEM;
    if (ret == FR_NO_FILESYSTEM) {
        LOG_W("No filesystem yet, try to be formatted...\r\n");
        ret = f_mkfs("/sd", &fs_para, workbuf, sizeof(workbuf));
        if (ret != FR_OK) {
            LOG_F("fail to make filesystem %d\r\n", ret);
            _CALL_ERROR();
        if (ret == FR_OK) {
            LOG_I("done with formatting.\r\n");
            LOG_I("first start to unmount.\r\n");
            ret = f_mount(NULL, "/sd", 1);
            LOG_I("then start to remount.\r\n");
    else if (ret != FR_OK) {
        LOG_F("fail to mount filesystem,error= %d\r\n", ret);
        LOG_F("SD card might fail to initialise.\r\n");
        _CALL_ERROR();
    else {
        LOG_D("Succeed to mount filesystem\r\n");
    if (ret == FR_OK) {
        LOG_I("FileSystem cluster size:%d-sectors (%d-Byte)\r\n", fs.csize, fs.csize * 512);
int take_photo(uint8_t* Buf, uint32_t len)  //拍照
    FRESULT ret;
    FIL fnew;
    UINT fnum;
    uint32_t time_node;
    static creat_file_cnt = 0;
#define PHOTO_NAME_LEN 30
    uint8_t file_name[PHOTO_NAME_LEN] = { 0 };
    memset(file_name, 0, PHOTO_NAME_LEN);
    snprintf(file_name, PHOTO_NAME_LEN, "/sd/%d.jpg", creat_file_cnt);
    creat_file_cnt++;
    ret = f_open(&fnew, file_name, FA_CREATE_ALWAYS | FA_WRITE);
    // ret = f_open(&fnew, "/sd/test_file.txt", FA_CREATE_ALWAYS | FA_WRITE);
    if (ret == FR_OK) {
        time_node = (uint32_t)bflb_mtimer_get_time_ms();
        /*write into file*/
        ret = f_write(&fnew, Buf, len, &fnum);
        /* close file */
        ret |= f_close(&fnew);
        /* get time */
        time_node = (uint32_t)bflb_mtimer_get_time_ms() - time_node;
        if (ret == FR_OK) {
            LOG_I("Write Succeed! photo cnt:%d\r\n", creat_file_cnt-1);
            LOG_I("Write data size:%d Byte, written size:%d KB\r\n", len, fnum);
            // LOG_I("Time:%dms, Write Speed:%d KB/s \r\n", time_node, ((sizeof(RW_Buffer) * i) >> 10) * 1000 / time_node);
        else {
            LOG_F("Fail to write files(%d)\n", ret);
            return;
    else {
        LOG_F("Fail to open or create files: %d.\r\n", ret);
        return;
int main(void)   //主函数
    board_init();  //开发板初始化
#if USE_SD_FATFS
    filesystem_init();  //文件系统初始化
#endif
    bflb_irq_set_nlbits(4);
    bflb_irq_set_priority(37, 3, 0);
    bflb_irq_set_priority(WIFI_IRQn, 1, 0);
    uart0 = bflb_device_get_by_name("uart0");
    shell_init_with_task(uart0);
    /* queue init, Do not delete! */
    picture_frame_init();
    jpeg_frame_init();
    dbi_disp_free_init();
    /* mjpeg init */
    mjpeg_init(640, 480, 50);
#ifndef CONFIG_CHERRYUSB
    /* dvp cam init */
    dvp_cam_init();
#endif
#endif
    tcpip_init(NULL, NULL);
    wifi_start_firmware_task();
    printf("Starting usb host task...\r\n");
    /* usb video init */
    usbh_initialize();
#endif
    // xTaskCreate(fps_printf_task, (char *)"fps_printf", 1024, NULL, 1, NULL);
    create_http_server_task();
    vTaskStartScheduler();
    while (1) {
2023-11-23 12:17:53
帮顶
2023-11-24 11:10:23
2023-11-24 12:21:30
千斤顶
2023-11-24 21:05:17
2023-11-26 14:07:24
2023-11-26 23:11:39
2023-11-29 09:56:53
  • 会员数: 28493 个
  • 话题数: 40628 篇
