拥有 Ai_M6X_SDK 本地文档
勤劳的打工人
小安派&M61基本系统教程 1961 14 2023-12-3 15:12:04
想要拥有本地doc文档,就来看看吧。
在C:\aithinker_Ai-M6X_SDK\docs下有SDK相关的文档。但是由于是rst格式没办法查看。
可以通过python编译成html以后进行查看。
接下来就开始编译docs目录到html。
下载安装 Python
打开[https://www.python.org/]()进入python官网
然后鼠标指向Downloads选项卡
弹出菜单
点击下载Python 3.12.0
下载完成后,找到下载完成的 安装包。
双击启动,如下安装页面
勾选Add python.exe to PATH, 点击Install Now 按照提示安装即可。
安装完成验证 Win+R ,输入cmd,然后输入 python即可显示如下图。
Python rst文件打开
RST与Python类似Javadoc与Java.
如果下载了别人的Python源码,里面有rst文件夹,我们可以转为html后用浏览器打开
1.安装python的sphinx模块:
pip install sphinx
2.执行make
C:\aithinker_Ai-M6X_SDK\docs>make
Sphinx v7.2.6
Please use `make target' where target is one of
  html        to make standalone HTML files
  dirhtml     to make HTML files named index.html in directories
  singlehtml  to make a single large HTML file
  pickle      to make pickle files
  json        to make JSON files
  htmlhelp    to make HTML files and an HTML help project
  qthelp      to make HTML files and a qthelp project
  devhelp     to make HTML files and a Devhelp project
  epub        to make an epub
  latex       to make LaTeX files, you can set PAPER=a4 or PAPER=letter
  text        to make text files
  man         to make manual pages
  texinfo     to make Texinfo files
  gettext     to make PO message catalogs
  changes     to make an overview of all changed/added/deprecated items
  xml         to make Docutils-native XML files
  pseudoxml   to make pseudoxml-XML files for display purposes
  linkcheck   to check all external links for integrity
  doctest     to run all doctests embedded in the documentation (if enabled)
  coverage    to run coverage check of the documentation (if enabled)
  clean       to remove everything in the build directory
3.然后执行make html
C:\aithinker_Ai-M6X_SDK\docs>make html
Running Sphinx v7.2.6
Extension error:
Could not import extension recommonmark (exception: No module named 'recommonmark')
发现缺少module 执行 pip install recommonmark
C:\aithinker_Ai-M6X_SDK\docs>pip install recommonmark
Collecting recommonmark
  Downloading recommonmark-0.7.1-py2.py3-none-any.whl (10 kB)
Collecting commonmark>=0.8.1 (from recommonmark)
  Downloading commonmark-0.9.1-py2.py3-none-any.whl (51 kB)
     ---------------------------------------- 51.1/51.1 kB 113.4 kB/s eta 0:00:00
Requirement already satisfied: docutils>=0.11 in c:\python\python312\lib\site-packages (from recommonmark) (0.20.1)
Requirement already satisfied: sphinx>=1.3.1 in c:\python\python312\lib\site-packages (from recommonmark) (7.2.6)
Requirement already satisfied: sphinxcontrib-applehelp in c:\python\python312\lib\site-packages (from sphinx>=1.3.1->recommonmark) (1.0.7)
Requirement already satisfied: sphinxcontrib-devhelp in c:\python\python312\lib\site-packages (from sphinx>=1.3.1->recommonmark) (1.0.5)
Requirement already satisfied: sphinxcontrib-jsmath in c:\python\python312\lib\site-packages (from sphinx>=1.3.1->recommonmark) (1.0.1)
Requirement already satisfied: sphinxcontrib-htmlhelp>=2.0.0 in c:\python\python312\lib\site-packages (from sphinx>=1.3.1->recommonmark) (2.0.4)
Requirement already satisfied: sphinxcontrib-serializinghtml>=1.1.9 in c:\python\python312\lib\site-packages (from sphinx>=1.3.1->recommonmark) (1.1.9)
Requirement already satisfied: sphinxcontrib-qthelp in c:\python\python312\lib\site-packages (from sphinx>=1.3.1->recommonmark) (1.0.6)
Requirement already satisfied: Jinja2>=3.0 in c:\python\python312\lib\site-packages (from sphinx>=1.3.1->recommonmark) (3.1.2)
Requirement already satisfied: Pygments>=2.14 in c:\python\python312\lib\site-packages (from sphinx>=1.3.1->recommonmark) (2.17.2)
Requirement already satisfied: snowballstemmer>=2.0 in c:\python\python312\lib\site-packages (from sphinx>=1.3.1->recommonmark) (2.2.0)
Requirement already satisfied: babel>=2.9 in c:\python\python312\lib\site-packages (from sphinx>=1.3.1->recommonmark) (2.13.1)
Requirement already satisfied: alabaster<0.8,>=0.7 in c:\python\python312\lib\site-packages (from sphinx>=1.3.1->recommonmark) (0.7.13)
Requirement already satisfied: imagesize>=1.3 in c:\python\python312\lib\site-packages (from sphinx>=1.3.1->recommonmark) (1.4.1)
Requirement already satisfied: requests>=2.25.0 in c:\python\python312\lib\site-packages (from sphinx>=1.3.1->recommonmark) (2.31.0)
Requirement already satisfied: packaging>=21.0 in c:\python\python312\lib\site-packages (from sphinx>=1.3.1->recommonmark) (23.2)
Requirement already satisfied: colorama>=0.4.5 in c:\python\python312\lib\site-packages (from sphinx>=1.3.1->recommonmark) (0.4.6)
Requirement already satisfied: setuptools in c:\python\python312\lib\site-packages (from babel>=2.9->sphinx>=1.3.1->recommonmark) (69.0.2)
Requirement already satisfied: MarkupSafe>=2.0 in c:\python\python312\lib\site-packages (from Jinja2>=3.0->sphinx>=1.3.1->recommonmark) (2.1.3)
Requirement already satisfied: charset-normalizer<4,>=2 in c:\python\python312\lib\site-packages (from requests>=2.25.0->sphinx>=1.3.1->recommonmark) (3.3.2)
Requirement already satisfied: idna<4,>=2.5 in c:\python\python312\lib\site-packages (from requests>=2.25.0->sphinx>=1.3.1->recommonmark) (3.6)
Requirement already satisfied: urllib3<3,>=1.21.1 in c:\python\python312\lib\site-packages (from requests>=2.25.0->sphinx>=1.3.1->recommonmark) (2.1.0)
Requirement already satisfied: certifi>=2017.4.17 in c:\python\python312\lib\site-packages (from requests>=2.25.0->sphinx>=1.3.1->recommonmark) (2023.11.17)
Installing collected packages: commonmark, recommonmark
Successfully installed commonmark-0.9.1 recommonmark-0.7.1
[notice] A new release of pip is available: 23.2.1 -> 23.3.1
[notice] To update, run: python.exe -m pip install --upgrade pip
再次执行 make html
Extension error:
Could not import extension sphinx_markdown_tables (exception: No module named 'sphinx_markdown_tables')
缺少module sphinx_markdown_tables 执行 pip install sphinx_markdown_tables
C:\aithinker_Ai-M6X_SDK\docs>pip install sphinx_markdown_tables
Collecting sphinx_markdown_tables
  Downloading sphinx_markdown_tables-0.0.17-py3-none-any.whl (28 kB)
Collecting markdown>=3.4 (from sphinx_markdown_tables)
  Obtaining dependency information for markdown>=3.4 from [https://files.pythonhosted.org/packages/70/58/2c5a654173937d9f540a4971c569b44dcd55e5424a484d954cdaeebcf79c/Markdown-3.5.1-py3-none-any.whl.metadata](https://files.pythonhosted.org/packages/70/58/2c5a654173937d9f540a4971c569b44dcd55e5424a484d954cdaeebcf79c/Markdown-3.5.1-py3-none-any.whl.metadata)
  Downloading Markdown-3.5.1-py3-none-any.whl.metadata (7.1 kB)
Downloading Markdown-3.5.1-py3-none-any.whl (102 kB)
   ---------------------------------------- 102.2/102.2 kB 391.1 kB/s eta 0:00:00
Installing collected packages: markdown, sphinx_markdown_tables
Successfully installed markdown-3.5.1 sphinx_markdown_tables-0.0.17
再次执行 make html
making output directory... done
Theme error:
no theme named 'sphinx_rtd_theme' found (missing theme.conf?)
缺少 sphinx_rtd_theme 再次执行 pip install sphinx_rtd_theme
C:\aithinker_Ai-M6X_SDK\docs>pip install sphinx_rtd_theme
Collecting sphinx_rtd_theme
  Obtaining dependency information for sphinx_rtd_theme from [https://files.pythonhosted.org/packages/ea/46/00fda84467815c29951a9c91e3ae7503c409ddad04373e7cfc78daad4300/sphinx_rtd_theme-2.0.0-py2.py3-none-any.whl.metadata](https://files.pythonhosted.org/packages/ea/46/00fda84467815c29951a9c91e3ae7503c409ddad04373e7cfc78daad4300/sphinx_rtd_theme-2.0.0-py2.py3-none-any.whl.metadata)
  Downloading sphinx_rtd_theme-2.0.0-py2.py3-none-any.whl.metadata (4.4 kB)
Requirement already satisfied: sphinx<8,>=5 in c:\python\python312\lib\site-packages (from sphinx_rtd_theme) (7.2.6)
Requirement already satisfied: docutils<0.21 in c:\python\python312\lib\site-packages (from sphinx_rtd_theme) (0.20.1)
Collecting sphinxcontrib-jquery<5,>=4 (from sphinx_rtd_theme)
  Downloading sphinxcontrib_jquery-4.1-py2.py3-none-any.whl (121 kB)
     ---------------------------------------- 121.1/121.1 kB 33.2 kB/s eta 0:00:00
Requirement already satisfied: sphinxcontrib-applehelp in c:\python\python312\lib\site-packages (from sphinx<8,>=5->sphinx_rtd_theme) (1.0.7)
Requirement already satisfied: sphinxcontrib-devhelp in c:\python\python312\lib\site-packages (from sphinx<8,>=5->sphinx_rtd_theme) (1.0.5)
Requirement already satisfied: sphinxcontrib-jsmath in c:\python\python312\lib\site-packages (from sphinx<8,>=5->sphinx_rtd_theme) (1.0.1)
Requirement already satisfied: sphinxcontrib-htmlhelp>=2.0.0 in c:\python\python312\lib\site-packages (from sphinx<8,>=5->sphinx_rtd_theme) (2.0.4)
Requirement already satisfied: sphinxcontrib-serializinghtml>=1.1.9 in c:\python\python312\lib\site-packages (from sphinx<8,>=5->sphinx_rtd_theme) (1.1.9)
Requirement already satisfied: sphinxcontrib-qthelp in c:\python\python312\lib\site-packages (from sphinx<8,>=5->sphinx_rtd_theme) (1.0.6)
Requirement already satisfied: Jinja2>=3.0 in c:\python\python312\lib\site-packages (from sphinx<8,>=5->sphinx_rtd_theme) (3.1.2)
Requirement already satisfied: Pygments>=2.14 in c:\python\python312\lib\site-packages (from sphinx<8,>=5->sphinx_rtd_theme) (2.17.2)
Requirement already satisfied: snowballstemmer>=2.0 in c:\python\python312\lib\site-packages (from sphinx<8,>=5->sphinx_rtd_theme) (2.2.0)
Requirement already satisfied: babel>=2.9 in c:\python\python312\lib\site-packages (from sphinx<8,>=5->sphinx_rtd_theme) (2.13.1)
Requirement already satisfied: alabaster<0.8,>=0.7 in c:\python\python312\lib\site-packages (from sphinx<8,>=5->sphinx_rtd_theme) (0.7.13)
Requirement already satisfied: imagesize>=1.3 in c:\python\python312\lib\site-packages (from sphinx<8,>=5->sphinx_rtd_theme) (1.4.1)
Requirement already satisfied: requests>=2.25.0 in c:\python\python312\lib\site-packages (from sphinx<8,>=5->sphinx_rtd_theme) (2.31.0)
Requirement already satisfied: packaging>=21.0 in c:\python\python312\lib\site-packages (from sphinx<8,>=5->sphinx_rtd_theme) (23.2)
Requirement already satisfied: colorama>=0.4.5 in c:\python\python312\lib\site-packages (from sphinx<8,>=5->sphinx_rtd_theme) (0.4.6)
Requirement already satisfied: setuptools in c:\python\python312\lib\site-packages (from babel>=2.9->sphinx<8,>=5->sphinx_rtd_theme) (69.0.2)
Requirement already satisfied: MarkupSafe>=2.0 in c:\python\python312\lib\site-packages (from Jinja2>=3.0->sphinx<8,>=5->sphinx_rtd_theme) (2.1.3)
Requirement already satisfied: charset-normalizer<4,>=2 in c:\python\python312\lib\site-packages (from requests>=2.25.0->sphinx<8,>=5->sphinx_rtd_theme) (3.3.2)
Requirement already satisfied: idna<4,>=2.5 in c:\python\python312\lib\site-packages (from requests>=2.25.0->sphinx<8,>=5->sphinx_rtd_theme) (3.6)
Requirement already satisfied: urllib3<3,>=1.21.1 in c:\python\python312\lib\site-packages (from requests>=2.25.0->sphinx<8,>=5->sphinx_rtd_theme) (2.1.0)
Requirement already satisfied: certifi>=2017.4.17 in c:\python\python312\lib\site-packages (from requests>=2.25.0->sphinx<8,>=5->sphinx_rtd_theme) (2023.11.17)
Downloading sphinx_rtd_theme-2.0.0-py2.py3-none-any.whl (2.8 MB)
   ---------------------------------------- 2.8/2.8 MB 43.8 kB/s eta 0:00:00
Installing collected packages: sphinxcontrib-jquery, sphinx_rtd_theme
Successfully installed sphinx_rtd_theme-2.0.0 sphinxcontrib-jquery-4.1
再次执行 make html 终于完成编译
[autosummary] generating autosummary for: advance_samples/index.rst, api_reference/components/bflog.rst, api_reference/components/ble.rst, api_reference/components/index.rst, api_reference/components/wifi.rst, api_reference/peripherals/adc.rst, api_reference/peripherals/cks.rst, api_reference/peripherals/clock.rst, api_reference/peripherals/dac.rst, api_reference/peripherals/dma.rst, ..., samples/peripherals/i2c/index.rst, samples/peripherals/index.rst, samples/peripherals/ir/index.rst, samples/peripherals/ir/ir_nec.rst, samples/peripherals/ir/ir_rc5.rst, samples/peripherals/ir/ir_swm.rst, samples/peripherals/ir/ir_tx_dma.rst, samples/peripherals/uart/index.rst, samples/peripherals/uart/uart_dma.rst, samples/peripherals/uart/uart_poll.rst
building [mo]: targets for 0 po files that are out of date
writing output...
building [html]: targets for 69 source files that are out of date
updating environment: [new config] 69 added, 0 changed, 0 removed
reading sources... [100%] samples/peripherals/uart/uart_poll
C:\aithinker_Ai-M6X_SDK\docs\source\api_reference/components/ble.rst:11: WARNING: Bullet list ends without a blank line; unexpected unindent.
C:\aithinker_Ai-M6X_SDK\docs\source\api_reference/components/ble.rst:16: WARNING: Bullet list ends without a blank line; unexpected unindent.
C:\aithinker_Ai-M6X_SDK\docs\source\api_reference/components/ble.rst:22: WARNING: Bullet list ends without a blank line; unexpected unindent.
C:\aithinker_Ai-M6X_SDK\docs\source\api_reference/components/ble.rst:23: WARNING: Bullet list ends without a blank line; unexpected unindent.
C:\aithinker_Ai-M6X_SDK\docs\source\api_reference/components/ble.rst:523: WARNING: Explicit markup ends without a blank line; unexpected unindent.
C:\aithinker_Ai-M6X_SDK\docs\source\api_reference/components/ble.rst:716: WARNING: Explicit markup ends without a blank line; unexpected unindent.
C:\aithinker_Ai-M6X_SDK\docs\source\samples/peripherals/gpio/index.rst:13: ERROR: "table" widths do not match the number of columns in table (2).
.. table:: GPIO 口
    :widths: 25, 25, 25, 25
    :width: 80%
    :align: center
    |   开发板             | GPIO        |
    | BL61x_MB_V1          | GPIO 0-34(其中 GPIO 2 为 BOOT 引脚,GPIO16/17默认为晶振引脚)                   |
C:\aithinker_Ai-M6X_SDK\docs\source\samples/peripherals/i2c/i2c_eeprom_interrupt.rst:2: WARNING: Title underline too short.
I2C - eeprom_interrupt
looking for now-outdated files... none found
pickling environment... done
checking consistency... done
preparing documents... done
copying assets... copying static files... done
copying extra files... done
done
writing output... [100%] samples/peripherals/uart/uart_poll
C:\aithinker_Ai-M6X_SDK\docs\source\samples\components\freertos.rst:69: WARNING: undefined label: 'bl_dev_cube'
generating indices... genindex done
writing additional pages... search done
copying images... [100%] notes/img/uart_sig.png
dumping search index in English (code: en)... done
dumping object inventory... done
====================== slowest reading durations =======================
0.187 api_reference/peripherals/adc
0.156 api_reference/components/bflog
0.156 api_reference/peripherals/spi
0.125 api_reference/peripherals/flash
0.125 api_reference/peripherals/pwm_v2
build succeeded, 9 warnings.
The HTML pages are in build\html.
最终打开,C:\aithinker_Ai-M6X_SDK\docs\build\html 下的 index.html
效果如下:我们拥有了一个离线的SDK文档。
2023-12-3 15:24:14
2023-12-3 15:42:11
真不错
2023-12-3 16:24:43
2023-12-3 17:16:23
2023-12-3 23:41:26
这个好玩,有空学一下,66
2023-12-4 08:54:28
2023-12-4 10:25:53
挺实用的
不错不错
  • 会员数: 28977 个
  • 话题数: 41710 篇
