Ai-WB2-32S uart rx超时中断(接收空闲中断)
黎明将至!
13
Ai-WB2系列 781 7 2024-2-21 17:55:50
前言
本期文档介绍一下uart接收中断的使用,在Linux Ubuntu下烧录的过程可以点击链接查看
芯片参考手册uart部分链接
**测试完记着要把bl_uart.c和bl_uart.h文件还原,要不然别的demo就无法编译了!
一、具体流程
第1步 进入目录~/Ai-Thinker-WB2/applications/peripherals/uart/uart
cd ~/Ai-Thinker-WB2/applications/peripherals/uart/uart
第2步 输入ls查看目录下的文件
ls
第3步 编写main.c文件
gedit main.c
将代码改为下面代码
 * @Author: [email]xuhongv@yeah.net[/email]
 * @Date: 2022-10-03 15:02:19
 * @LastEditors: [email]xuhongv@yeah.net[/email] [email]xuhongv@yeah.net[/email]
 * @LastEditTime: 2022-10-20 17:42:45
 * @FilePath: \bl_iot_sdk_for_aithinker\applications\get-started\helloworld\helloworld\main.c
 * @Description: Uart
#include <stdio.h>
#include <string.h>
#include <FreeRTOS.h>
#include <task.h>
#include <blog.h>
#include "bl_sys.h"
#include <stdio.h>
#include <cli.h>
#include <hosal_uart.h>
#include <blog.h>
#include "bl_uart.h"
//create a serial port structure variable.
hosal_uart_dev_t uart_dev_log = {
    .config = {
        .uart_id = 1,
        .tx_pin = 16, // TXD GPIO
        .rx_pin = 7,  // RXD GPIO
        .cts_pin = 255,
        .rts_pin = 255,
        .baud_rate = 115200,
        .data_width = HOSAL_DATA_WIDTH_8BIT,
        .parity = HOSAL_NO_PARITY,
        .stop_bits = HOSAL_STOP_BITS_1,
        .mode = HOSAL_UART_MODE_INT,
//functions used to create tasks.
void TaskUart(void *param)
    /* Uart init device */
    hosal_uart_init(&uart_dev_log);
    blog_info("Uart Demo Start");
    while (1)
        // hosal_uart_send(&uart_dev_log, "test\r\n", 6);      //test whether to exit the interrupt.
        if(my_uart_data.uart_rx_flag > 0)                   //if data is received, execute the following program.
            my_uart_data.uart_rx_flag = 0;                  //clear receiving flag.
            memset(my_uart_data.uart_tx_data, 0, sizeof(my_uart_data.uart_tx_data));
            //process the received data and write it to the send buffer.
            sprintf((char *)(my_uart_data.uart_tx_data), "receive: %s\r\n", my_uart_data.uart_rx_data);
            //send processed data
            hosal_uart_send(&uart_dev_log, my_uart_data.uart_tx_data, sizeof(my_uart_data.uart_tx_data));
            memset(my_uart_data.uart_rx_data, 0, sizeof(my_uart_data.uart_rx_data));
        //delay of 500ms.
        vTaskDelay(500);
 * @brief main
void main(void)
    //create task
    xTaskCreate(TaskUart, "TaskUart", 1024, NULL, 15, NULL);
第4步 进入~/Ai-Thinker-WB2/components/platform/hosal/bl602_hal目录
cd ~/Ai-Thinker-WB2/components/platform/hosal/bl602_hal/
第5步 修改bl_uart.c文件
gedit bl_uart.c
extern hosal_uart_dev_t uart_dev_log;
修改中断服务函数
void UART1_IRQHandler(void)
    cb_uart_notify_t cb;
    void *arg;
    uint32_t tmpVal = 0;
    uint32_t maskVal = 0;
    uint32_t UARTx = uartAddr[1];
    tmpVal = BL_RD_REG(UARTx,UART_INT_STS);
    maskVal = BL_RD_REG(UARTx,UART_INT_MASK);
    if (BL_IS_REG_BIT_SET(tmpVal,UART_URX_RTO_INT) && !BL_IS_REG_BIT_SET(maskVal,UART_CR_URX_RTO_MASK)){
        BL_WR_REG(UARTx,UART_INT_CLEAR,0x12);
        // *((uint32_t *)0x4000A128) = 0x12;
        /*Receive Data ready*/
        cb = g_uart_notify_arg[1].rx_cb;
        arg = g_uart_notify_arg[1].rx_cb_arg;
        if (cb) {
            /*notify up layer*/
            cb(arg);
            my_uart_data.uart_rx_flag = hosal_uart_receive(&uart_dev_log,
                my_uart_data.uart_rx_data, sizeof(my_uart_data.uart_rx_data));
第6步 修改bl_uart.c文件
gedit bl_uart.h
#define DATALINE        64
typedef struct {
    uint8_t uart_rx_data[DATALINE];
    uint8_t uart_rx_flag;
    uint8_t uart_tx_data[DATALINE];
}MY_UART_DATA;
MY_UART_DATA my_uart_data;
第7步 编译
编译
make -j8(博主的电脑内核是8核的,因此就是用了8核编译,这里的内核数最大写自己电脑的内核数)
第8步 烧录到模组(此时需要模组连接到虚拟机,具体过程可以点击此链接
执行 make flash p=/dev/ttyUSB0 b=115200
根据提示按下模组的复位键
第9步 通过调试助手向模组发送数据(这里要将模组连接到主机,具体过程可以点击次连接进行参考)
将模组连接到主机之后,打开串口调试助手,选择对应的串口、波特率等,打开串口,按下复位键
二、使用注意
清除接收中断标志位,既要清除urx_end_int,也要清除urx_rto_int;否则就会无法出中断;
原链接:https://blog.csdn.net/qq_54193285/article/details/135933164?spm=1001.2014.3001.5501
2024-2-22 08:28:39
打卡
2024-2-22 08:56:25
不错
2024-2-22 09:17:22
不错不错
2024-2-22 09:40:55
2024-2-22 10:48:29
2024-2-22 11:10:52
  • 会员数: 29534 个
  • 话题数: 42873 篇
