问题 小安派S1 I2S编译报错
timo
问题汇总 1206 6 2024-6-18 15:19:06
今天想用下 I2S,看泽哥的教程配置
(十四)零基础开发小安派-Eyes-S1【外设篇】——I2S - 小安派&M61零基础开发教程(官方) - 物联网开发者社区-安信可论坛 - Powered by Discuz! (ai-thinker.com)
我按教程步骤复制了8388的库
修改了代码
CMakeLists.txt 和 flash_prog_cfg.ini 也修改了
复制好了 main.c 文件
结果无法编译
发现,CMakeLists.txt 不添加这一行,可以编译,但是喇叭没音,
sdk_set_linker_script($ENV{BL_SDK_BASE}/bsp/board/bl616dk/bl616_flash_old.ld)
添加了这一行,报老多错误了
这是报错日志
[ 99%] Linking C executable build_out/audio_bl616.elf
/home/timo/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/toolchain/bin/../lib/gcc/riscv64-unknown-elf/10.2.0/../../../../riscv64-unknown-elf/bin/ld: warning: cannot find entry symbol _start; defaulting to 0000000000010100
/home/timo/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/toolchain/bin/../lib/gcc/riscv64-unknown-elf/10.2.0/../../../../riscv64-unknown-elf/bin/ld: build_out/lib/libstd.a(start_load.c.o): in function `start_load':
/home/timo/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/drivers/soc/bl616/std/startup/start_load.c:48: undefined reference to `__tcm_code_start__'
/home/timo/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/toolchain/bin/../lib/gcc/riscv64-unknown-elf/10.2.0/../../../../riscv64-unknown-elf/bin/ld: /home/timo/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/drivers/soc/bl616/std/startup/start_load.c:48: undefined reference to `__tcm_code_end__'
/home/timo/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/toolchain/bin/../lib/gcc/riscv64-unknown-elf/10.2.0/../../../../riscv64-unknown-elf/bin/ld: /home/timo/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/drivers/soc/bl616/std/startup/start_load.c:48: undefined reference to `__tcm_code_start__'
/home/timo/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/toolchain/bin/../lib/gcc/riscv64-unknown-elf/10.2.0/../../../../riscv64-unknown-elf/bin/ld: /home/timo/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/drivers/soc/bl616/std/startup/start_load.c:48: undefined reference to `__itcm_load_addr'
/home/timo/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/toolchain/bin/../lib/gcc/riscv64-unknown-elf/10.2.0/../../../../riscv64-unknown-elf/bin/ld: /home/timo/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/drivers/soc/bl616/std/startup/start_load.c:48: undefined reference to `__tcm_data_start__'
/home/timo/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/toolchain/bin/../lib/gcc/riscv64-unknown-elf/10.2.0/../../../../riscv64-unknown-elf/bin/ld: /home/timo/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/drivers/soc/bl616/std/startup/start_load.c:56: undefined reference to `__tcm_data_end__'
/home/timo/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/toolchain/bin/../lib/gcc/riscv64-unknown-elf/10.2.0/../../../../riscv64-unknown-elf/bin/ld: /home/timo/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/drivers/soc/bl616/std/startup/start_load.c:56: undefined reference to `__tcm_data_start__'
/home/timo/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/toolchain/bin/../lib/gcc/riscv64-unknown-elf/10.2.0/../../../../riscv64-unknown-elf/bin/ld: /home/timo/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/drivers/soc/bl616/std/startup/start_load.c:56: undefined reference to `__dtcm_load_addr'
/home/timo/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/toolchain/bin/../lib/gcc/riscv64-unknown-elf/10.2.0/../../../../riscv64-unknown-elf/bin/ld: /home/timo/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/drivers/soc/bl616/std/startup/start_load.c:56: undefined reference to `__ram_data_start__'
/home/timo/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/toolchain/bin/../lib/gcc/riscv64-unknown-elf/10.2.0/../../../../riscv64-unknown-elf/bin/ld: /home/timo/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/drivers/soc/bl616/std/startup/start_load.c:64: undefined reference to `__ram_data_end__'
/home/timo/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/toolchain/bin/../lib/gcc/riscv64-unknown-elf/10.2.0/../../../../riscv64-unknown-elf/bin/ld: /home/timo/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/drivers/soc/bl616/std/startup/start_load.c:64: undefined reference to `__ram_data_start__'
/home/timo/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/toolchain/bin/../lib/gcc/riscv64-unknown-elf/10.2.0/../../../../riscv64-unknown-elf/bin/ld: /home/timo/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/drivers/soc/bl616/std/startup/start_load.c:64: undefined reference to `__ram_load_addr'
/home/timo/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/toolchain/bin/../lib/gcc/riscv64-unknown-elf/10.2.0/../../../../riscv64-unknown-elf/bin/ld: /home/timo/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/drivers/soc/bl616/std/startup/start_load.c:64: undefined reference to `__nocache_ram_data_start__'
/home/timo/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/toolchain/bin/../lib/gcc/riscv64-unknown-elf/10.2.0/../../../../riscv64-unknown-elf/bin/ld: /home/timo/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/drivers/soc/bl616/std/startup/start_load.c:64: undefined reference to `__nocache_ram_data_end__'
/home/timo/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/toolchain/bin/../lib/gcc/riscv64-unknown-elf/10.2.0/../../../../riscv64-unknown-elf/bin/ld: /home/timo/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/drivers/soc/bl616/std/startup/start_load.c:72: undefined reference to `__nocache_ram_data_start__'
/home/timo/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/toolchain/bin/../lib/gcc/riscv64-unknown-elf/10.2.0/../../../../riscv64-unknown-elf/bin/ld: /home/timo/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/drivers/soc/bl616/std/startup/start_load.c:72: undefined reference to `__nocache_ram_data_end__'
/home/timo/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/toolchain/bin/../lib/gcc/riscv64-unknown-elf/10.2.0/../../../../riscv64-unknown-elf/bin/ld: /home/timo/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/drivers/soc/bl616/std/startup/start_load.c:72: undefined reference to `__nocache_ram_load_addr'
/home/timo/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/toolchain/bin/../lib/gcc/riscv64-unknown-elf/10.2.0/../../../../riscv64-unknown-elf/bin/ld: /home/timo/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/drivers/soc/bl616/std/startup/start_load.c:73: undefined reference to `__bss_start__'
2024-6-18 15:37:21
让泽哥给你瞧瞧!
2024-6-18 15:42:12
等泽哥解决
2024-6-18 17:08:25
是不是新的SDK和帖子里面的不匹配
2024-6-18 22:10:00
bzhou830 发表于 2024-6-18 17:08
是不是新的SDK和帖子里面的不匹配
我用的还是master分支,当然也可能是新的不兼容了,毕竟泽哥的教程好早了,只是不知如何处理
2024-6-19 08:34:46
timo 发表于 2024-6-18 22:10
我用的还是master分支,当然也可能是新的不兼容了,毕竟泽哥的教程好早了,只是不知如何处理 ...
别着急,泽哥出差了,等他回来后第一时间回复你。
2024-7-29 11:30:03
蹲个答案
  • 会员数: 30047 个
  • 话题数: 44012 篇
