linux编译错误
MrZeFr
15
问题汇总 1642 14 2024-7-9 18:58:22
./../../../../tools/cmake/bin/cmake -S . -B build -G "Unix Makefiles" -DCROSS_COMPILE=riscv64-unknown-elf- -DCHIP=bl616 -DCPU_ID= -DBOARD=bl616dk -DBOARD_DIR= -DCONFIG_DEBUG=y -DCONFIG_ROMAPI=y -DCONFIG_USB_HS=y -DCONFIG_COMX=COM5 -DCMAKE_EXPORT_COMPILE_COMMANDS=OFF -DCONFIG_TLSF=y
-- The C compiler identification is unknown
-- The CXX compiler identification is unknown
-- The ASM compiler identification is unknown
-- Found assembler: riscv64-unknown-elf-gcc
CMake Error at /home/mrzefr/aithinker_Ai-M6X_SDK/cmake/bouffalo_sdk-config.cmake:31 (enable_language):
  The CMAKE_C_COMPILER:
  is not a full path and was not found in the PATH.
  Tell CMake where to find the compiler by setting either the environment
  variable "CC" or the CMake cache entry CMAKE_C_COMPILER to the full path to
  the compiler, or to the compiler name if it is in the PATH.
Call Stack (most recent call first):
  CMakeLists.txt:5 (find_package)
  The CMAKE_CXX_COMPILER:
    riscv64-unknown-elf-g++
  variable "CXX" or the CMake cache entry CMAKE_CXX_COMPILER to the full path
  to the compiler, or to the compiler name if it is in the PATH.
  The CMAKE_ASM_COMPILER:
  variable "ASM" or the CMake cache entry CMAKE_ASM_COMPILER to the full path
-- Warning: Did not find file Compiler/-ASM
-- Configuring incomplete, errors occurred!
See also "/home/mrzefr/aithinker_Ai-M6X_SDK/examples/wifi/sta/wifi_udp/build/CMakeFiles/CMakeOutput.log".
See also "/home/mrzefr/aithinker_Ai-M6X_SDK/examples/wifi/sta/wifi_udp/build/CMakeFiles/CMakeError.log".
make: *** [../../../../project.build:50:build] 错误 1
希望各路大佬帮一下,我最近做了一个用ai-m61-32s驱动的小车,要安这个环境
2024-7-9 19:32:11
进入sdk目录执行. export.sh了吗
2024-7-9 19:36:35
执行了
2024-7-9 19:37:48
应该是因为这些找不到,能帮一下马?
2024-7-9 19:42:49
看私聊
2024-7-10 08:21:10
看起来编译工具链没有配置好
2024-7-10 08:37:06
马上给你抓个技术来
编译环境的问题的话,多半是脚本没执行完,去重新执行一下脚本,然后记得make clean一下
2024-7-10 11:52:52
跟着学系列
2024-7-10 14:49:09
跟着大佬学
  • 会员数: 30047 个
  • 话题数: 44012 篇
