配置vscode纵享丝滑
lovzx
Ai-WB2系列 2740 4 2024-9-23 11:16:46
配置VSCode纵享丝滑
最新版增加了command variable插件,通过点击设置-C参数指定make工作目录,详情参考 command variable 插件助力vscode 开发wb2/m61
效果展示
啥也不多说了,先看效果
make
make flash
make clean
按钮三件套
分别有make build、make clean 、flash以及pwd
配置原理
原理很简单,配置vscode的task任务,然后安装taskbutton插件,把task任务可视化的展示出来就可以了
1. 配置task
打开vscode的输入搜索框,输入>会有对应的提示,点击配置task,如下图所示
然后回出现推荐的task任务,随便选择一个就会跳到tasks.json里面了,把tasks对象替换成下面的内容
  1. "tasks": [
  2.                 {
  3.                         "type": "shell",
  4.                         "group": "build",
  5.                         "label": "pwd",
  6.                         "command": "pwd",
  7.                         "detail": "pwd",
  8.                 },
  9.                 {
  10.                         "type": "shell",
  11.                         "group": "build",
  12.                         "label": "make 编译",
  13.                         "command": "make",
  14.                         "detail": "make -j16",
  15.                         "args": [
  16.                                 "-j16"
  17.                         ],
  18.                 },
  19.                 {
  20.                         "type": "shell",
  21.                         "group": "build",
  22.                         "label": "make clean",
  23.                         "command": "make",
  24.                         "detail": "make clean",
  25.                         "args": [
  26.                                 "-j16",
  27.                                 "clean"
  28.                         ]
  29.                 },
  30.                 {
  31.                         "type": "shell",
  32.                         "group": "build",
  33.                         "label": "make flash",
  34.                         "command": "make",
  35.                         "detail": "make flash",
  36.                         "args": [
  37.                                 "-j16",
  38.                                 "flash",
  39.                                 "p=COM6"
  40.                         ]
  41.                 }
  42.         ]
type:任务的类型,有shell和progress两种
group:任务的执行组,这里写build
label:任务名称
command:任务命令
args:任务的参数
以WB2为例,编译命令是make -j16,这里的make是命令,-j16是编译线程的参数,make编译代码的任务就是这样
  1. {
  2.                         "type": "shell",
  3.                         "group": "build",
  4.                         "label": "make 编译",
  5.                         "command": "make",
  6.                         "detail": "make -j16",
  7.                         "args": [
  8.                                 "-j16"
  9.                         ],
  10.                 }
vscode默认执行路径是在当前的工作目录,如果打开的不是根目录这样是不能执行的,会提示找不到Makefile文件,这时候有两种解决方法
1. -C参数指定make的工作目录
2.  设置task的工作目录
为了方便修改可以在tasks的同级别对象里面添加options对象,配置options.cwd来设置tasks任务的工作目录
最后完整的tasks.json配置文件如下
  1. {
  2.         "version": "2.0.0",
  3.         "presentation": {
  4.                 "echo": false,
  5.                 "reveal": "always",
  6.                 "focus": true,
  7.                 "panel": "shared",
  8.                 "showReuseMessage": true,
  9.                 "clear": false
  10.         },
  11.         "options": {
  12.                 "cwd": "${workspaceFolder}/Ai-Thinker-WB2/applications/get-started/blink",
  13.                 // "cwd": "${workspaceFolder}/bel_demo"
  14.         },
  15.         "tasks": [
  16.                 {
  17.                         "type": "shell",
  18.                         "group": "build",
  19.                         "label": "pwd",
  20.                         "command": "pwd",
  21.                         "detail": "pwd",
  22.                 },
  23.                 {
  24.                         "type": "shell",
  25.                         "group": "build",
  26.                         "label": "make 编译",
  27.                         "command": "make",
  28.                         "detail": "make -j16",
  29.                         "args": [
  30.                                 "-j16"
  31.                         ],
  32.                 },
  33.                 {
  34.                         "type": "shell",
  35.                         "group": "build",
  36.                         "label": "make clean",
  37.                         "command": "make",
  38.                         "detail": "make clean",
  39.                         "args": [
  40.                                 "-j16",
  41.                                 "clean"
  42.                         ]
  43.                 },
  44.                 {
  45.                         "type": "shell",
  46.                         "group": "build",
  47.                         "label": "make flash",
  48.                         "command": "make",
  49.                         "detail": "make flash",
  50.                         "args": [
  51.                                 "-j16",
  52.                                 "flash",
  53.                                 "p=COM6"
  54.                         ]
  55.                 }
  56.         ]
  57. }
安装task buttons插件
在vscode插件搜索Task Buttons,可以找到下面的插件,点击安装
ps:一定要看好插件的作者spencerwmiles
配置Task Buttons
打开.vscode文件夹下面的settings.json文件(如果没有自己创建一个),把下面配置粘贴到settings.json中
  1. "VsCodeTaskButtons.showCounter": true,
  2.   "VsCodeTaskButtons.tasks": [
  3.     {
  4.       "label": "🛠️ make build",
  5.       "task": "make 编译",
  6.       "tooltip": "编译代码"
  7.     },
  8.     {
  9.       "label": "🧹make clean",
  10.       "task": "make clean",
  11.       "tooltip": "make clean"
  12.     },
  13.     {
  14.       "label": "⬇️ flash",
  15.       "task": "make flash",
  16.       "tooltip": "烧录"
  17.     },
  18.     {
  19.       "label": "pwd",
  20.       "task": "pwd",
  21.       "tooltip": "pwd"
  22.     }
  23.   ]
VsCodeTaskButtons.showCounter配置是否显示任务按钮
label是任务按钮的名字
task是tasks.json中json的label,这个要一一对应,否则会提示找不到task
tooltip是任务提示信息,鼠标放到task buttons上会显示出来
有意思的是配置支持Emoji字符,加上图标就有内味了
文中我是以wb2项目为例的,实际可以根据自己的项目对配置文件进行适当的修改就可以用了
目前这就是我知道最方便的配置方法了,如果哪位大佬有更好的配置方法欢迎评论分享探讨
2024-9-23 11:30:35
这个插件妙啊
这个插件厉害
2024-9-23 21:54:13
优秀
  • 会员数: 31251 个
  • 话题数: 42383 篇
