【BW21-CBV-Kit 开发板测评】手势和人脸的动态检测识别
无垠的广袤
小安派·BW21-CBV-KIt 1086 4 2025-3-12 13:33:49
本文介绍了安信可 BW21-CBV-Kit 开发套件实现 手势识别人脸识别 的测试情况。
工程测试
介绍官方 Demo (手势监测 HandGestureDetection 和人脸识别 RTSPFaceRecegnition)测试流程及效果展示。
手势识别
通过加载 NN (Neural Network, 神经网络) 训练模型,实现手势的跟踪、提取、模拟、识别。
代码
注意修改 WiFi 名称和密码
#include "WiFi.h"
#include "StreamIO.h"
#include "VideoStream.h"
#include "RTSP.h"
#include "NNGestureDetection.h"
#define CHANNEL   0
#define CHANNELNN 3
// Customised resolution for NN
#define NNWIDTH  192
#define NNHEIGHT 192
VideoSetting config(VIDEO_FHD, 30, VIDEO_H264, 0);
NNGestureDetection gesturedetect;
RTSP rtsp;
StreamIO videoStreamer(1, 1);
StreamIO videoStreamerRGBGD(1, 1);
char ssid[] = "xxx";    // your network SSID (name)
char pass[] = "xx";         // your network password
int status = WL_IDLE_STATUS;
IPAddress ip;
int rtsp_portnum;
void setup()
    Serial.begin(115200);
    // Attempt to connect to Wifi network:
        Serial.println(ssid);
        delay(2000);
    ip = WiFi.localIP();
    config.setBitrate(2 * 1024 * 1024);    // Recommend to use 2Mbps for RTSP streaming to prevent network congestion
    Camera.videoInit();
    rtsp.configVideo(config);
    rtsp.begin();
    // Configure Gesture Detection model
    gesturedetect.configVideo(configNN);
    gesturedetect.modelSelect(GESTURE_DETECTION, NA_MODEL, NA_MODEL, NA_MODEL, NA_MODEL, NA_MODEL, DEFAULT_PALMDETECT, DEFAULT_HANDLANDMARK);
    gesturedetect.begin();
    Camera.channelBegin(CHANNEL);
    // Configure StreamIO object to stream data from RGB video channel to gesture detection
    videoStreamerRGBGD.registerInput(Camera.getStream(CHANNELNN));
    videoStreamerRGBGD.setStackSize();
    videoStreamerRGBGD.setTaskPriority();
    videoStreamerRGBGD.registerOutput(gesturedetect);
    if (videoStreamerRGBGD.begin() != 0) {
    // Start video channel for NN
    OSD.configTextSize(CHANNEL, 16, 32);
    OSD.begin();
    gesturedetect.drawHandRegion();
void loop()
    // Do nothing
上传
1.按住 BOOT(下载) 按钮的同时按一下 EN(复位)按钮,进入下载模式;
2.选择目标串口对应的端口号,点击 Download 按钮,待上传成功提示 Success,完成固件上传;
3.再次短按 EN 键复位,执行程序。
配置
上传完成后打开串口监视器,检测到 WiFi 并连接,输出 Camera 摄像头的 ip 地址,
VLC 软件中输入 rtsp://192.168.1.104:554 实现 rtsp 推流。
效果
数字手势
动作手势
静态展示合集
人脸识别
使用 BW21-CBV-Kit 开发板识别检测到的人脸。
代码
详情参考:Neural Nework – Face Recognition – Realtek IoT/Wi-Fi MCU Solutions
#include "WiFi.h"
#include "RTSP.h"
#include "NNFaceDetectionRecognition.h"
#define CHANNEL   0
#define CHANNELNN 3
#define NNWIDTH  576
#define NNHEIGHT 320
NNFaceDetectionRecognition facerecog;
RTSP rtsp;
StreamIO videoStreamerFDFR(1, 1);
StreamIO videoStreamerRGBFD(1, 1);
char pass[] = "xxx";        // your network password
IPAddress ip;
int rtsp_portnum;
void setup()
        delay(2000);
    Camera.videoInit();
    rtsp.begin();
    // Configure Face Recognition model
    facerecog.configVideo(configNN);
    facerecog.modelSelect(FACE_RECOGNITION, NA_MODEL, DEFAULT_SCRFD, DEFAULT_MOBILEFACENET);
    facerecog.begin();
    facerecog.setResultCallback(FRPostProcess);
    videoStreamerRGBFD.registerInput(Camera.getStream(CHANNELNN));
    videoStreamerRGBFD.setStackSize();
    videoStreamerRGBFD.setTaskPriority();
    videoStreamerRGBFD.registerOutput(facerecog);
    if (videoStreamerRGBFD.begin() != 0) {
    OSD.begin();
void loop()
    if (Serial.available() > 0) {
        String input = Serial.readString();
        input.trim();
        if (input.startsWith(String("REG="))) {
            String name = input.substring(4);
            facerecog.registerFace(name);
        } else if (input.startsWith(String("DEL="))) {
            facerecog.removeFace(name);
        } else if (input.startsWith(String("RESET"))) {
            facerecog.resetRegisteredFace();
        } else if (input.startsWith(String("BACKUP"))) {
            facerecog.backupRegisteredFace();
        } else if (input.startsWith(String("RESTORE"))) {
            facerecog.restoreRegisteredFace();
    delay(2000);
    OSD.createBitmap(CHANNEL);
    OSD.update(CHANNEL);
// User callback function for post processing of face recognition results
void FRPostProcess(std::vector<FaceRecognitionResult> results)
    Serial.print("Network URL for RTSP Streaming: ");
    Serial.print("rtsp://");
    Serial.print(ip);
    Serial.print(":");
    Serial.println(rtsp_portnum);
    Serial.println(" ");
    printf("Total number of faces detected = %d\r\n", facerecog.getResultCount());
    if (facerecog.getResultCount() > 0) {
        for (int i = 0; i < facerecog.getResultCount(); i++) {
            FaceRecognitionResult item = results[i];
            uint32_t osd_color;
            if (String(item.name()) == String("unknown")) {
                osd_color = OSD_COLOR_RED;
            } else {
                osd_color = OSD_COLOR_GREEN;
            // Draw boundary box
            printf("Face %d name %s:\t%d %d %d %d\n\r", i, item.name(), xmin, xmax, ymin, ymax);
            OSD.drawRect(CHANNEL, xmin, ymin, xmax, ymax, 3, osd_color);
            char text_str[40];
            snprintf(text_str, sizeof(text_str), "Face:%s", item.name());
            OSD.drawText(CHANNEL, xmin, ymin - OSD.getTextHeight(CHANNEL), text_str, osd_color);
上传完成后打开串口监视器,检测到 WiFi 并连接,输出 Camera 摄像头的 ip 地址,在 VLC 软件中输入 rtsp://192.168.253.1:554 实现 rtsp 推流。
将目标人脸对准摄像头,当监测到人脸并被红色线框选中时,在串口输入 REG=Bean 实现人名录入,此时线框颜色变为绿色,提示词指示对应的人物名字。
效果
动态识别
注意到人脸识别在距离较远时准确率更高,若人脸占据画面较大比例,则识别效果下降。此外,人脸识别程序在运行过程中,模块温度有明显升高,需要注意散热等问题。
可能因素包括:代码中设置的人脸信息采集分辨率为 192x192 ,面对动态画面的实际情况,采集样本不足,对于采集画面大小、复杂的人脸表情变化的应对能力有限;摄像头分辨率限制;处理器运算能力限制等。
改进方案:增加硬件算力、散热方案、扩充样本数量、增大训练迭代次数、改进模型。
注意:若串口输出错误信息 error: vipnn not applied 则需重新安装开发板程序包。
总结
本文介绍了安信可 BW21-CBV-Kit 开发套件实现 手势识别人脸识别 以及动态监测的项目,并对测试结果和试验的实际表现进行分析,给出相应的可能存在的问题和对应的解决方案,为该项目的后续完善和改进提供了思路和参考。
2025-3-12 13:56:51
写的真好~必须加精支持
2025-3-12 14:27:25
爱笑 发表于 2025-3-12 13:56
写的真好~必须加精支持
这个Demo好像支持多张人脸识别,后面尝试一下;计划设计适配一个PCB底座,扩展排针,再加上一些外设传感器,搭配3D外壳,让它更便携,提升拍摄画面的稳定性
2025-3-13 11:13:26
2025-3-13 15:45:51
  • 会员数: 30551 个
  • 话题数: 44705 篇
