AI-WB2 增加个littlefs文件系统
邦邦
Ai-WB2系列 166 2 2025-3-17 23:32:48
littlefs文件系统github地址
https://github.com/littlefs-project/littlefs
其实我是从Ai-M6X_SDK_release_AiPi_Eyes_SDK里移植出来
上传的附件: littlefs_components.zip (765.08 KB, 下载次数: 2)
压缩包里有components和例程,要把components下的放到AI——WB2 SDK下的components
如图
例程放在
components增加了bouffalo.mk
# Component Makefile
## These include paths would be exported to project level
COMPONENT_ADD_INCLUDEDIRS += port littlefs littlefs/bd
## not be exported to project level
COMPONENT_PRIV_INCLUDEDIRS :=
## This component's src
COMPONENT_SRCS := port/lfs_xip_flash.c littlefs/lfs.c littlefs/lfs_util.c littlefs/bd/lfs_filebd.c littlefs/bd/lfs_rambd.c littlefs/bd/lfs_testbd.c
COMPONENT_OBJS := $(patsubst %.c,%.o, $(COMPONENT_SRCS))
COMPONENT_SRCDIRS := port littlefs littlefs/bd
#CPPFLAGS +=
修改了lfs_xip_flash.c
#include "lfs.h"
//#include "bflb_flash.h"
//#include "bflb_l1c.h"
#include <hosal_flash.h>
#define CONFIG_LITTLEFS_FLASH_ADDRESS        0x210000
#ifndef CONFIG_LITTLEFS_FLASH_ADDRESS
#error "must define CONFIG_LITTLEFS_FLASH_ADDRESS"
#endif
* @brief        Read a region in a block. Negative error codes are propagated
*               to the user.
* @param[in]    c
* @param[in]    block
* @param[in]    off
* @param[out]   buffer
* @param[in]    size
* @retval int
int lfs_xip_flash_read(const struct lfs_config *c, lfs_block_t block,
                       lfs_off_t off, void *buffer, lfs_size_t size)
    return hosal_flash_raw_read((uint8_t *)buffer, CONFIG_LITTLEFS_FLASH_ADDRESS + block * c->block_size + off, size);
* @brief        Program a region in a block. The block must have previously
*               been erased. Negative error codes are propagated to the user.
*               May return LFS_ERR_CORRUPT if the block should be considered bad.
* @param[in]    c
* @param[in]    block
* @param[in]    off
* @param[in]    buffer
* @param[in]    size
* @retval int
int lfs_xip_flash_prog(const struct lfs_config *c, lfs_block_t block,
                       lfs_off_t off, const void *buffer, lfs_size_t size)
    return hosal_flash_raw_write((uint8_t *)buffer, CONFIG_LITTLEFS_FLASH_ADDRESS + block * c->block_size + off, size);
* @brief        Erase a block. A block must be erased before being programmed.
*               The state of an erased block is undefined. Negative error codes
*               are propagated to the user.
* @param[in]    c
* @param[in]    block
* @retval int
int lfs_xip_flash_erase(const struct lfs_config *c, lfs_block_t block)
    return hosal_flash_raw_erase(CONFIG_LITTLEFS_FLASH_ADDRESS + block * c->block_size, c->block_size);
* @brief        Sync the state of the underlying block device. Negative error
*               codes are propagated to the user.
* @param[in]    c
* @retval int
int lfs_xip_flash_sync(const struct lfs_config *c)
    /*!< if use xip, may need to clean cache */
    return 0;
main()创建littlefs任务
xTaskCreate(littlefs_task, (char*)"littlefs_task", 512, NULL, 13, NULL);//任务优先级数值越小,优先级越低
littlefs任务做了个简单测试
* Licensed to the Apache Software Foundation (ASF) under one or more
* contributor license agreements.  See the NOTICE file distributed with
* this work for additional information regarding copyright ownership.  The
* ASF licenses this file to you under the Apache License, Version 2.0 (the
* "License"); you may not use this file except in compliance with the
* License.  You may obtain a copy of the License at
*   http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an "AS IS" BASIS, WITHOUT
* WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.  See the
* License for the specific language governing permissions and limitations
* under the License.
* Included Files
#include "FreeRTOS.h"
#include "task.h"
#include "littlefs_task.h"
#include "lfs.h"
#include "lfs_port.h"
#include <blog.h>
组件log开关
静态开关 在相应的 proj_config.mk 文件目录下,LOG_ENABLED_COMPONENTS配置上增加对应组件的名字 例如这里需要增加blog_testc组件静态开关,其他组件默认关闭 LOG_ENABLED_COMPONENTS:=blog_testc
文件log管理
//#define BLOG_HARD_DECLARE_DISABLE 1    // 关
私有log管理
静态开关 使用就增加BLOG_DECLARE(…),不用直接不增加此行即可。 BLOG_DECLARE(blog_testc2);    // 打开,其中 "blog_testc2"为用户自定义
//BLOG_DECLARE(main);
调整等级
blog_set_level_log_component(BLOG_LEVEL_ALL, "blog_demo");
BLOG_DECLARE(littlefs);//必需定义????
* Pre-processor Definitions
/*!< use memory area after 512k */
#define LITTLEFS_FLASH_SIZE        (0x28000)
#define LITTLEFS_FLASH_BLOCK_SIZE  4096
#define LITTLEFS_FLASH_BLOCK_COUNT (LITTLEFS_FLASH_SIZE / LITTLEFS_FLASH_BLOCK_SIZE)
#define LITTLEFS_FLASH_BLOCK_CYCLE 500
* Private Data
lfs_t lfs;
lfs_file_t file;
/*!< configuration of the filesystem is provided by this struct */
const struct lfs_config cfg = {
    // block device operations
    .read = lfs_xip_flash_read,
    .prog = lfs_xip_flash_prog,
    .erase = lfs_xip_flash_erase,
    .sync = lfs_xip_flash_sync,
    // block device configuration
    .read_size = 16,
    .prog_size = 16,
    .lookahead_size = 16,
    .cache_size = 16,
    .block_size = LITTLEFS_FLASH_BLOCK_SIZE,
    .block_count = LITTLEFS_FLASH_BLOCK_COUNT,
    .block_cycles = LITTLEFS_FLASH_BLOCK_CYCLE,
* Private Function Prototypes
* Functions
void littlefs_task(void *pvParameters)
        blog_info_user(littlefs,"mount the filesystem");
    // mount the filesystem
    int err = lfs_mount(&lfs, &cfg);
    // reformat if we can't mount the filesystem
    // this should only happen on the first boot
    if (err) {
        blog_error_user(littlefs,"try to reformat");
        err = lfs_format(&lfs, &cfg);
        if (err) {
            blog_error_user(littlefs,"reformat fail");
            vTaskDelete(NULL);
        blog_info_user(littlefs,"reformat success");
        blog_info_user(littlefs,"try mount the filesystem");
        if (err) {
                blog_error_user(littlefs,"try mount fail");
            vTaskDelete(NULL);
        blog_info_user(littlefs,"mount success");
    // read current count
    uint32_t boot_count = 0;
    lfs_file_open(&lfs, &file, "boot_count", LFS_O_RDWR | LFS_O_CREAT);
    lfs_file_read(&lfs, &file, &boot_count, sizeof(boot_count));
    // update boot count
    boot_count += 1;
    lfs_file_rewind(&lfs, &file);
    lfs_file_write(&lfs, &file, &boot_count, sizeof(boot_count));
    // remember the storage is not updated until the file is closed successfully
    lfs_file_close(&lfs, &file);
    // release any resources we were using
    // lfs_unmount(&lfs);
    // print the boot count
    printf("boot_count: %d\n", boot_count);
        vTaskDelete(NULL);
    while (1) {
            vTaskDelay(1000 / portTICK_PERIOD_MS);
感谢
2025-3-18 08:33:59
好活
2025-3-18 09:11:17
谢谢分享
  • 会员数: 28598 个
  • 话题数: 40730 篇
