Ra-01收发切换
qqneinei
Ra-01S/01SH系列 637 15 2025-3-21 08:21:50
Ra-01可以先收数据,收到数据后再把数据发出去吗?网上说切换DIO0的电平实现切换,能具体点吗?我这边试了后还是只能一个芯片收,另一个发,没办法在一块芯片上实现收发
2025-3-21 08:44:26
通过状态识别切换,发送数据出发TXDONE以后即可进入接收模式接收数据,参考pingpong用例使用方法
2025-3-21 08:59:01
RitaChen 发表于 2025-3-21 08:44
通过状态识别切换,发送数据出发TXDONE以后即可进入接收模式接收数据,参考pingpong用例使用方法 ...
请问下这个“pingpong用例”能给个链接吗?我在官网没有找到
2025-3-21 09:06:06
	while (1)
		switch (State)
		case RX:
			if (isMaster == true)
				if (BufferSize > 0)
					if (strncmp((const char *)Buffer, (const char *)PongMsg, 4) == 0)
						printf("Received: PONG\r\n");
						// Send the next PING frame
						Buffer[0] = 'P';
						Buffer[1] = 'I';
						Buffer[2] = 'N';
						Buffer[3] = 'G';
						// We fill the buffer with numbers for the payload
						for (i = 4; i < BufferSize; i++)
							Buffer[i] = i - 4;
						delay_ms(10);
						printf("Sent: PING\r\n");
#ifdef REINIT_FLAG
						Radio_TX_Resetting();
#endif
						Radio.Send(Buffer, BufferSize);
					else if (strncmp((const char *)Buffer, (const char *)PingMsg, 4) == 0)
					{ // A master already exists then become a slave
						isMaster = false;
#ifdef REINIT_FLAG
						Radio_RX_Resetting();
#endif
						Radio.Rx(LORA_RX_TIMEOUT_VALUE);
					else // valid reception but neither a PING or a PONG message
					{	 // Set device as master ans start again
						isMaster = true;
#ifdef REINIT_FLAG
#endif
			else
				if (BufferSize > 0)
						printf("Received: PING\r\n");
						// Send the reply to the PONG string
						Buffer[0] = 'P';
						Buffer[1] = 'O';
						Buffer[2] = 'N';
						Buffer[3] = 'G';
							Buffer[i] = i - 4;
						delay_ms(10);
#ifdef REINIT_FLAG
#endif
						printf("Sent: PONG\r\n");
					else // valid reception but not a PING as expected
					{	 // Set device as master and start again
						isMaster = true;
#ifdef REINIT_FLAG
#endif
			State = LOWPOWER;
			break;
		case TX:
#ifdef REINIT_FLAG
#endif
			State = LOWPOWER;
			break;
		case RX_TIMEOUT:
		case RX_ERROR:
				Buffer[0] = 'P';
				Buffer[1] = 'I';
				Buffer[2] = 'N';
				Buffer[3] = 'G';
					Buffer[i] = i - 4;
				random = (rand() + 1) % 90;
				delay_ms(random);
#ifdef REINIT_FLAG
#endif
			else
#ifdef REINIT_FLAG
#endif
			State = LOWPOWER;
			break;
		case TX_TIMEOUT:
#ifdef REINIT_FLAG
#endif
			State = LOWPOWER;
			break;
		case LOWPOWER:
		default:
			// Set low power
			break;
		// Process Radio IRQ
		Radio.IrqProcess();
2025-3-21 09:07:56
RitaChen 发表于 2025-3-21 09:06
while (1)
                switch (State)
谢谢你,老哥
2025-3-21 09:07:56
上传的附件: PingPong.c (7.55 KB, 下载次数: 1)
2025-3-21 09:15:39
老哥,请问下它这个DIO0是接收进入中断还是发送进入中断啊?我看官方Demo上面说发送进入中断,但是实际却是接收进入中断
2025-3-21 09:32:16
qqneinei 发表于 2025-3-21 09:15
老哥,请问下它这个DIO0是接收进入中断还是发送进入中断啊?我看官方Demo上面说发送进入中断,但是实际却 ...
dio0是多种终端,触发中断之后还要去查状态码,确定触发中断的是那个条件,移植我们代码。用我刚刚上传的代码附件
2025-3-21 09:55:58
爱笑 发表于 2025-3-21 09:32
dio0是多种终端,触发中断之后还要去查状态码,确定触发中断的是那个条件,移植我们代码。用我刚刚上传的 ...
打开后中文显示乱码,换了UTF-8和GB2312都不行
2025-3-21 10:18:33
能给个完整的工程吗??
  • 会员数: 28681 个
  • 话题数: 40885 篇
