小安派-cam-d200求助
schoenevase
小安派·Cam-D200 551 10 2025-4-2 09:50:56
烧录固件的部分已经完成了,但是到at指令串口通信的部分怎么一直不能成功啊?有没有大佬能帮忙解释一下
2025-4-2 09:52:32
就是用安信可串口调试助手,串口选择了正确的串口,波特率也调到了2000000,串口打开也成功了,就是发送信息没有任何返回信息
2025-4-2 09:54:04
用了别的串口调试助手也同样没有效果
烧录完要重启,不可能启动信息都没有吧
2025-4-2 10:17:40
Ai-Thinker小泽 发表于 2025-4-2 09:58
烧录完要重启,不可能启动信息都没有吧
重启以后一直收到error
2025-4-2 10:19:11
烧录完要重启,不可能启动信息都没有吧
还是发送wifi密码那个指令
给个LOG
2025-4-2 10:35:29
[10:15:53.760]收←◆?
  ____               __  __      _       _       _
|  _ \             / _|/ _|    | |     | |     | |
| |_) | ___  _   _| |_| |_ __ _| | ___ | | __ _| |__
|  _ < / _ \| | | |  _|  _/ _` | |/ _ \| |/ _` | '_ \
| |_) | (_) | |_| | | | || (_| | | (_) | | (_| | |_) |
|____/ \___/ \__,_|_| |_| \__,_|_|\___/|_|\__,_|_.__/
Build:19:03:20,Jun 28 2024
Copyright (c) 2022 Bouffalolab team
Version of used components:
        Version: component_version_macsw_1.6.10
        Version: component_version_phyrf_v1.0.1-12-geca50a7
        Version: component_version_sdk_2.0.1
======== flash cfg ========
flash size 0x00800000
jedec id     0xC84017
mid              0xC8
iomode           0x04
clk delay        0x01
clk invert       0x01
read reg cmd0    0x05
read reg cmd1    0x35
write reg cmd0   0x01
write reg cmd1   0x31
qe write len     0x01
cread support    0x01
cread code       0x20
burst wrap cmd   0x77
dynamic memory init success, ocram heap size = 246 Kbyte, psram heap size = 3046 Kbyte
sig1:ffffffff
sig2:0000f32f
cgen1:9ffffffd
Starting wifi ...[I][rfparam] xtal value 40000000
[I][rfparam] pwr_mode is bf
Empty slot:0
No written slot found
[I][rfparam] no pwr_offset in efuse
[I][rfparam] tlv wlan pwr_offset[14]: 0,0,0,0,0,0,0,0,0,0,0,0,0,0,
[I][rfparam] wlan pwr_offset[14]: 0,0,0,0,0,0,0,0,0,0,0,0,0,0,
Empty slot:0
[I][rfparam] no lp pwr_offset in efuse
[I][rfparam] tlv wlan lp pwr_offset[14]: 0,0,0,0,0,0,0,0,0,0,0,0,0,0,
[I][rfparam] wlan lp pwr_offset[14]: 0,0,0,0,0,0,0,0,0,0,0,0,0,0,
Empty slot:0
[I][rfparam] no bz pwr_offset in efuse
[I][rfparam] tlv bz pwr_offset[5]: 0,0,0,0,0,
[I][rfparam] bz pwr_offset[5]: 0,0,0,0,0,
[I][rfparam] pwr_11b[4]: 20,20,20,20,
[I][rfparam] pwr_11g[8]: 18,18,18,18,18,18,16,16,
[I][rfparam] pwr_11n_ht20[8]: 18,18,18,18,18,16,15,15,
[I][rfparam] pwr_11n_ht40[8]: 18,18,18,18,18,16,15,14,
[I][rfparam] pwr_11ac_vht20[10]: 18,18,18,18,18,16,15,15,15,14,
[I][rfparam] pwr_11ac_vht40[10]: 18,18,18,18,18,16,15,14,14,13,
[I][rfparam] pwr_11ac_vht80[10]: 18,18,18,18,18,15,14,13,13,12,
[I][rfparam] pwr_11ax_he20[12]: 18,18,18,18,18,16,15,15,15,14,13,13,
[I][rfparam] pwr_11ax_he40[12]: 18,18,18,18,18,16,15,14,14,13,12,12,
[I][rfparam] pwr_11ax_he80[12]: 18,18,18,18,18,15,14,13,13,12,11,11,
[I][rfparam] pwr_11ax_he160[12]: 18,18,18,18,18,15,14,13,12,11,10,10,
[I][rfparam] capcode mode is MF
Empty slot:1
[I][rfparam] efuse capcode_in 32,capcode_out 32
[I][rfparam] capcode_in 32,capcode_out 32
[I][rfparam] tcal.en_tcal = 0
[I][rfparam] tcal.linear_or_follow = 1
[I][rfparam] tcal.Tchannels[5]: 2412,2427,2442,2457,2472,
[I][rfparam] tcal.Tchannel_os[5]: 180,168,163,160,157,
[I][rfparam] tcal.Tchannel_os_low[5]: 199,186,170,165,160,
[I][rfparam] tcal.Troom_os = -1
[I][rfparam] pwr_ble = 13
[I][rfparam] pwr_bt[3]: 10,8,8,
[I][rfparam] pwr_zigbee = 13
[I][rfparam] country_code = 86
[10:15:53.895]收←◆PHY RF init success!fail to mount filesystem,error= 3
SD card might fail to initialise.
歷6.10.0.0 - build: sd Nov 22 2021 21:10:20
歟xtra component version:
      ceva_freertos
            mbedtls
ceva_wpa_supplicant
          ceva_lwip
Read slot:0
get sta mac: b4:c2:e0:42:52:73
Read slot:0
get ap mac: b4:c2:e0:42:52:73
wifi_mgmr_set_country_code:code = CN
CODE_WIFI_ON_MGMR_DONE
bl618_button_task
camera_muxsem_handle creat success!
[10:15:54.520]收←◆
Sensor name: GC2145
dvp x: 1600
dvp y: 1200
[10:15:56.908]收←◆bl618 wifi connecct
[10:16:04.976]发→◇AT+WJAP=social friendly zwei,2222111007
[10:16:05.226]收←◆ERROR
[10:17:50.360]发→◇AT+WJAP=social friendly zwei,2222111007
[10:17:50.608]收←◆ERROR
[10:21:04.719]发→◇AT+WJAP=social friendly zwei,2222111007
[10:21:04.966]收←◆ERROR
[10:21:24.455]发→◇AT+WJAP=social friendly zwei,2222111007
[10:21:24.701]收←◆ERROR
[10:28:08.761]发→◇AT+WJAP=social friendly zwei,2222111007
[10:28:09.011]收←◆ERROR
[10:28:17.252]发→◇AT+WJAP?
[10:28:17.474]收←◆0.0.0.0
OK
[10:28:33.665]发→◇AT+WJAP=social friendly zwei,2222111007
[10:28:33.914]收←◆ERROR
[10:31:14.407]发→◇AT+WJAP=social friendly zwei,2222111007
[10:31:14.656]收←◆ERROR
[10:31:35.048]发→◇AT+WJAP=social friendly zwei,2222111007
[10:31:35.301]收←◆
[10:31:40.959]发→◇AT+WJAP=social friendly zwei,2222111007
[10:31:41.205]收←◆        %5
[10:31:46.867]发→◇AT+WJAP=social friendly zwei,2222111007
[10:31:47.117]收←◆ERROR
[10:31:53.210]发→◇AT+WJAP=social friendly zwei,2222111007
[10:31:53.457]收←◆ERROR
[10:31:59.200]发→◇AT+WJAP=social friendly zwei,2222111007
[10:31:59.447]收←◆簯
[10:32:01.256]发→◇AT+WJAP=social friendly zwei,2222111007
[10:32:01.504]收←◆s
[10:32:02.961]发→◇AT+WJAP=social friendly zwei,2222111007
[10:32:03.213]收←◆虄澍
[10:32:04.549]发→◇AT+WJAP=social friendly zwei,2222111007
[10:32:04.795]收←◆?
[10:32:06.665]发→◇AT+WJAP=social friendly zwei,2222111007
[10:32:06.913]收←◆0
[10:32:10.094]发→◇AT+WJAP=social friendly zwei,2222111007
[10:32:10.344]收←◆
[10:32:12.177]发→◇AT+WJAP=social friendly zwei,2222111007
[10:32:12.427]收←◆H
[10:32:13.855]发→◇AT+WJAP=social friendly zwei,2222111007
[10:32:14.106]收←◆麳
[10:32:15.294]发→◇AT+WJAP=social friendly zwei,2222111007
[10:32:15.542]收←◆?
[10:32:16.457]发→◇AT+WJAP=social friendly zwei,2222111007
[10:32:16.704]收←◆
[10:32:17.721]发→◇AT+WJAP=social friendly zwei,2222111007
[10:32:17.971]收←◆
[10:32:19.110]发→◇AT+WJAP=social friendly zwei,2222111007
[10:32:19.364]收←◆?
[10:32:20.415]发→◇AT+WJAP=social friendly zwei,2222111007
[10:32:20.667]收←◆
[10:32:21.707]发→◇AT+WJAP=social friendly zwei,2222111007
[10:32:23.623]发→◇AT+WJAP=social friendly zwei,2222111007
[10:32:23.878]收←◆?
[10:32:25.386]发→◇AT+WJAP=social friendly zwei,2222111007
[10:32:27.183]发→◇AT+WJAP=social friendly zwei,2222111007
[10:32:27.453]收←◆
[10:32:28.646]发→◇AT+WJAP=social friendly zwei,2222111007
[10:32:29.987]发→◇AT+WJAP=social friendly zwei,2222111007
[10:32:31.593]发→◇AT+WJAP=social friendly zwei,2222111007
[10:32:33.219]发→◇AT+WJAP=social friendly zwei,2222111007
[10:32:35.516]发→◇AT+WJAP=social friendly zwei,2222111007
[10:32:36.937]发→◇AT+WJAP=social friendly zwei,2222111007
[10:32:42.378]发→◇AT+WJAP=social friendly zwei,2222111007
[10:32:42.629]收←◆ERROR
[10:32:49.557]发→◇AT+WJAP=social friendly zwei,2222111007
[10:32:49.806]收←◆ERROR
[10:32:53.365]发→◇AT+WJAP=social friendly zwei,2222111007
[10:32:53.617]收←◆ERROR
[10:32:55.917]发→◇AT+WJAP=social friendly zwei,2222111007
[10:32:56.167]收←◆ERROR
[10:32:59.628]发→◇AT+WJAP=social friendly zwei,2222111007
[10:32:59.877]收←◆ERROR
[10:33:02.649]发→◇AT+WJAP=social friendly zwei,2222111007
[10:33:02.897]收←◆ERROR
啊?你这WiFi带空格啊,改一下名称
2025-4-2 10:46:12
Ai-Thinker小泽 发表于 2025-4-2 10:39
啊?你这WiFi带空格啊,改一下名称
感谢
  • 会员数: 29221 个
  • 话题数: 42111 篇
