BW21-CVB-KIT基于udp的h264视频流可远程
lijrgj
7
小安派·BW21-CBV-KIt 644 7 2025-4-11 22:14:43
[i=s] 本帖最后由 lijrgj 于 2025-4-11 22:19 编辑 [/i]
开发板
#include "mmf2_siso.h"
#include "module_video.h"
#include "mmf2_pro2_video_config.h"
#include "video_example_media_framework.h"
#include "sensor.h"
#include "video_boot.h"
#include "FreeRTOS.h"
#include "task.h"
#include <stdio.h>
#include <sockets.h>
#include "avcodec.h"
#include "string.h"
#define V1_CHANNEL 0
#if USE_SENSOR == SENSOR_GC4653
#define V1_RESOLUTION VIDEO_2K
#define V1_FPS 15
#define V1_GOP 15
#else
#define V1_RESOLUTION VIDEO_VGA
#define V1_FPS 30
#define V1_GOP 30
#endif
#define V1_BPS 2*1024*1024
#define V1_RCMODE 2 // 1: CBR, 2: VBR
#define USE_H265 0
#if USE_H265
#include "sample_h265.h"
#define VIDEO_TYPE VIDEO_HEVC
#define VIDEO_CODEC AV_CODEC_ID_H265
#else
#include "sample_h264.h"
#define VIDEO_TYPE VIDEO_H264
#define VIDEO_CODEC AV_CODEC_ID_H264
#endif
#if V1_RESOLUTION == VIDEO_VGA
#define V1_WIDTH	640
#define V1_HEIGHT	480
#elif V1_RESOLUTION == VIDEO_HD
#define V1_WIDTH	1280
#define V1_HEIGHT	720
#elif V1_RESOLUTION == VIDEO_FHD
#define V1_WIDTH	1920
#define V1_HEIGHT	1080
#elif V1_RESOLUTION == VIDEO_2K
#define V1_WIDTH	2560
#define V1_HEIGHT	1440
#endif
static mm_context_t *video_h264_ctx = NULL;
#define max 8000
static int soc = -1;
static _mutex H264_mutex;
static _sema H264_sema;
//initparm
static video_params_t vp={
        .stream_id = V1_CHANNEL,
        .type = VIDEO_H264,
        .resolution = VIDEO_VGA,
        .width = V1_WIDTH,
        .height = V1_HEIGHT,
        .bps = V1_BPS,
        .fps = 30,
        .gop = 3,
        .rc_mode = 1,
        .direct_output = 1,
        .meta_enable=0,
static xQueueHandle muxer_queue;
#define VIDEO_IDLE  0x00
#define VIDEO_START 0X01
#define VIDEO_WRITE 0X02
#define VIDEO_STOP  0x03
#define VIDEO_QUIT  0x04
static int video_status = 0;
static int video_record = VIDEO_IDLE;
#define AD_PAGE_SIZE 320 //20ms
struct sockaddr_in soc_in;
typedef struct {
    uint32_t data_addr;
    uint32_t type;
    uint32_t timestamp;
    uint32_t size;
    uint32_t channel;
} mp4_muxer_ctx;
typedef struct h264_video{
   uint32_t *data_addr;
    uint32_t size;
    uint32_t channel;
}h264;
int indexe=0;
#define max_bit_size   1024
static void video_meta_cb(void *meta){
     video_meta_t *m=(video_meta_t*)meta;
    printf("enc2out-----------------%d\r\n",m->user_buf_len);
void send_h264(h264 h){
   // rtw_mutex_get(&H264_mutex);
    if (soc>-1){
        uint32_t *data_buf=h.data_addr;
        uint32_t data_len=h.size;
        if (data_len>0){
            int send= sendto(soc, data_buf,data_len, 0, (struct sockaddr *) &soc_in, sizeof(soc_in));
            printf("send_...........\r\n");
            printf("h264_send--send=%d------\r\n",send);
            vTaskDelay(2);
            printf("soc----video_output_cb_ok---------%d\r\n",soc);
            goto exit;
        } else{
            printf("soc----video_output_cb_data_len---------%d\r\n",data_len);
            goto exit;
    } else{
        printf("soc----video_output_cb_error---------%d\r\n",soc);
        goto exit;
    exit:
    printf("soc----st---------%d\r\n",soc);
static void video_output_cb(void *param1, void  *param2, uint32_t arg)
    enc2out_t *enc2out = (enc2out_t *)param1;
   // if((enc2out->codec & (CODEC_H264 | CODEC_HEVC | CODEC_JPEG)) != 0) {
    if(enc2out->codec==CODEC_H264) {
          uint32_t *en_ad=(uint32_t *)enc2out->enc_addr;
          uint32_t en_len= enc2out->enc_len;
        printf("en_ad-----------------==%d\r\n",(uint8_t )en_ad[en_len-1]);
        h264 h;
       h.data_addr=en_ad;
        h.size= en_len;
        h.channel=enc2out->ch;
        send_h264(h);
        dcache_invalidate_by_addr((uint32_t *)enc2out->enc_addr, enc2out->enc_len);
            video_encbuf_release(enc2out->ch, enc2out->codec, enc2out->enc_len);
    }else if ((enc2out->codec & (CODEC_NV12 | CODEC_RGB | CODEC_NV16)) != 0) {
    rtw_mutex_put(&H264_mutex);
    rtw_up_sema(&H264_sema);
    rtw_down_timeout_sema(&H264_sema, portMAX_DELAY);
int  stat=1;
static TaskHandle_t pz=NULL;
int soc_stat=1;
 void mmf_h264_video(void)
     int iq_addr, sensor_addr, ret;
    rtw_init_sema(&H264_sema, 0);
    rtw_mutex_init(&H264_mutex);
    //////////////////////////////////VIDEO INIT//////////////////////////////////////////
    int voe_heap_size = video_voe_presetting(1, V1_WIDTH, V1_HEIGHT, V1_BPS, 0,
                                             0, 0, 0, 0, 0,
                                             0, 0, 0, 0, 0,
                                             0, 0, 0);
    printf("voe_heap_size---------%d\r\n",voe_heap_size);
    voe_get_sensor_info(2, &iq_addr, &sensor_addr);
    video_init(iq_addr, sensor_addr);
 ret= video_open(&vp,video_output_cb,NULL);
    if (ret>=0){
        while (soc_stat){
            printf("socket_init-----------\r\n");
            soc = socket(AF_INET, SOCK_DGRAM, 0);//udp
            if (soc < 0) {
                printf("soc_init_error=%d\r\n", errno);
                continue;
            soc_stat=0;
            printf("socket_init---ok\r\n");
            printf("udp_start--------udp---------\r\n");
            printf("soc==============%d\r\n", soc);
            soc_in.sin_family = AF_INET;
            soc_in.sin_port = htons(9091);
            //soc_in.sin_addr.s_addr= inet_addr("192.168.158.9");
            //soc_in.sin_addr.s_addr= inet_addr("192.168.211.9");
            soc_in.sin_addr.s_addr= inet_addr("192.168.150.9");
static void example_deinit(void)
    //Stop module
    mm_module_ctrl(video_h264_ctx, CMD_VIDEO_STREAM_STOP,STREAM_V1 );
    //Close module
    video_h264_ctx = mm_module_close(video_h264_ctx);
    //Video Deinit
    video_deinit();
android端重要
需要判断帧类型 比如IPPP GOP就是4,也就是关键帧间隔4 P帧是无法单独解码需要依赖前面的关键帧,I帧可以单独解码是包含了完整图像
mediaCodec =MediaCodec.createDecoderByType(MediaFormat.MIMETYPE_VIDEO_AVC);
                    MediaFormat mediaFormat=MediaFormat.createVideoFormat(MediaFormat.MIMETYPE_VIDEO_AVC,640,480);
                    mediaFormat.setInteger(MediaFormat.KEY_FRAME_RATE,30);
                    mediaFormat.setInteger(MediaFormat.KEY_BIT_RATE,2*1024*1024);
                  //  mediaFormat.setInteger(MediaFormat.KEY_MAX_INPUT_SIZE,0);
                    mediaFormat.setInteger(MediaCodec.PARAMETER_KEY_LOW_LATENCY,1);
                    mediaFormat.setInteger(MediaFormat.KEY_I_FRAME_INTERVAL,3);
                    mediaCodec.configure(mediaFormat,sh.getSurface(),null,0);
                    mediaCodec.start();
                    new Thread(()->{
                        while (true){
                            byte[] bytes=null;
                            try {
                                Thread.sleep(5);
                                ByteBuffer inputBuffer=null;
                                if (h264_queue.size()>0){
                                    System.out.println("000-----------------"+h264_queue.size());
                                    long l = System.nanoTime();
                                    System.out.println("开始解码");
                                    bytes=h264_queue.poll();
                                    int i = mediaCodec.dequeueInputBuffer(0);
                                    if (i>=0){
                                        inputBuffer = mediaCodec.getInputBuffer(i);
                                        inputBuffer.clear();
                                        inputBuffer.put(bytes,0,bytes.length);
                                        mediaCodec.queueInputBuffer(i,0,bytes.length,0,0);
                                    MediaCodec.BufferInfo bufferInfo=new MediaCodec.BufferInfo();
                                    int i1=-1;
                                    while ((i1=mediaCodec.dequeueOutputBuffer(bufferInfo, 0))>=0){
                                        mediaCodec.releaseOutputBuffer(i1,0);
                                        System.out.println("解码结束");
                                    i1=mediaCodec.dequeueOutputBuffer(bufferInfo,0);
                                    long l1 = System.nanoTime();
                                    System.out.println("总用时---"+(l1-l)/1000000);
                                    try {
                                      //  condition.await();
                                    } catch (Exception e) {
                                        e.printStackTrace();
                                    //l.unlock();
                                System.out.println(e.getMessage());
                    }).start();
                } catch (IOException ioException) {
                    ioException.printStackTrace();
ByteArrayOutputStream byteArrayOutputStream = null;
// ByteArrayOutputStream byteArrayOutputStream = new ByteArrayOutputStream();
ConcurrentLinkedQueue<byte[]>h264_queue=new ConcurrentLinkedQueue<>();
boolean h64_stat=false;
long l11=0;
long l12=0;
@RequiresApi(api = Build.VERSION_CODES.P)
void startUdpServer() throws IOException, InterruptedException {
datagramSocket = new DatagramSocket(3333);
    Log.d("udp-----", "udp启动");
    String data1 = "1111";
    DatagramPacket datagramPacket2 = new DatagramPacket(data1.getBytes(StandardCharsets.UTF_8), data1.length(), InetAddress.getByAddress(serip), port);
    System.out.println(datagramSocket + "------------");
    datagramSocket.send(datagramPacket2);
    byte[] bytes = new byte[100000];
    DatagramPacket datagramPacket = new DatagramPacket(bytes, bytes.length);
    while (aBoolean) {
        datagramSocket.receive(datagramPacket);
        byte[] data = datagramPacket.getData();
        if (data != null && data.length != 0 && datagramPacket.getLength() != 0) {
           /* if (datagramPacket.getLength()==5){
                if (data[0]==115&&data[1]==116&&data[2]==97&&data[3]==114&&data[4]==116){
                   System.out.println("数据开始------"+datagramPacket.getLength());
                        h64_stat=false;
                    continue;
            if (datagramPacket.getLength()==3){
                if (data[0]==101&&data[1]==110&&data[2]==100){
                    System.out.println("接受完毕------"+datagramPacket.getLength());
                    fps++;
            }else{*/
                    if (datagramPacket.getData()[4]==39&&!h264IP_isRsv_arr[0]){//这是I帧
                        l11 = System.nanoTime();
                        byteArrayOutputStream.write(data,0,datagramPacket.getLength());
                        h264IP_isRsv_arr[h264IP_isRsv_arr_index]=true;
                        h264IP_isRsv_arr_index++;
                        h64_stat=false;
                        System.out.println("iz="+byteArrayOutputStream.size());
                        Log.d("udp-----","进来了是I帧开头"+data[datagramPacket.getLength()-1]+"-----"+ h264IP_isRsv_arr_index+"数据长度---"+datagramPacket.getLength());
                       // hc++;
         if (datagramPacket.getData()[4]==33&&h264IP_isRsv_arr[0]) {//P帧
             if (h264IP_isRsv_arr[h264IP_isRsv_arr_index-1]&&h264IP_isRsv_arr_index<3){
                 System.out.println("pz="+byteArrayOutputStream.size());
                 Log.d("udp-----","进来了是P帧开头"+data[datagramPacket.getLength()-1]+"-----"+ h264IP_isRsv_arr_index+"数据长度---"+datagramPacket.getLength());
             }if (h264IP_isRsv_arr_index>=3){
                 System.out.println( Arrays.toString(h264IP_isRsv_arr));
              //   l.lock();
                 System.out.println("准备解码");
                 System.out.println("zlen="+byteArrayOutputStream.size());
                 h264_queue.add(byteArrayOutputStream.toByteArray());
                 l12=System.nanoTime();
                 System.out.println("用时------------------"+(l12-l11)/1000000);
                 byteArrayOutputStream.reset();
                 h64_stat=true;
              // condition.signal();
              //   l.unlock();
                // Thread.sleep(10);
                 Arrays.fill(h264IP_isRsv_arr, false);
                h264IP_isRsv_arr_index=0;
2025-4-11 23:52:30
很棒,赞!
很棒,赞!
棒~
2025-4-15 00:13:49
帧率大概能有多少?
2025-4-21 00:43:19
sdfjklkj 发表于 2025-4-15 00:13
帧率大概能有多少?
设置多少就是多少
2025-7-25 23:16:57
环境部署好了,程序也编译烧录了,WIFI连接在哪设置?
2025-8-4 12:50:16
直接调用串口处理WiFi连接函数你也可以枚举多个WiFi挨个连
  • 会员数: 30224 个
  • 话题数: 44437 篇
