BU04 INIT FAILED
soas42
UWB 526 5 2026-2-10 20:17:25
Sorry, i dont know chinese so i tried to use translater but i just thought that writing as english is a lot better to express.
i've bought the BU04 on board model and i'm using it with esp32 s2 through uart(rx,tx).
i succeeded at communicating with serial monitor, but after i tried to set SETCFG, i just throwing INIT FAILED.
AT+SETCFG AT+SAVE -> as one line, it dosen't show INIT FAILED, but i does not save changed information.
AT+SETCFG ->
setcfg ID:1, Role:1, CH:1, Rate:1
21:14:52.219 ->
21:14:52.219 -> OK
21:14:52.219 ->  INIT FAILED INIT FAILED....
setcfg ID:0, Role:1, CH:1, Rate:1
21:14:52.219 ->
21:14:52.219 -> OK
i can't type anything.
if i don't change the ID(65535),it successfully saves information but it does not communicate each other.
i dont know whats the problem
Are you using a module or a development board?
I have the same problem, I bought a module on Aliexpress (3 pieces)
getver software:V1.0.0
OK
2026-4-5 00:29:12
ok, i find it, just connect + to VDD1
2026-4-5 00:30:48
But AOA not working with 2 bu04 modules, range and angle don't arrive to com port of station. What could be the problem? AOA working only with bu03 and bu04?
  • 会员数: 31032 个
  • 话题数: 44935 篇
