make -C build combine
[11:13:49.247] - bflb firmware post process : V1.2.0
[11:13:49.247] - Chipname: bl616
[11:13:49.247] - Board config dir: ./../aithinker_Ai-M6X_SDK/bsp/board/bl616dk/config
[11:13:49.247] - Create partition using partition_cfg_4M.toml
[11:13:49.250] - Create dts for E:\system_file\desktop\AiPi-Open-Kits\AiPi-Eyes_weather\build\build_out\Eyes_bl616.bin
[11:13:49.250] - Create dts using bl_factory_params_IoTKitA_auto.dts
[11:13:49.254] - 4K header found,append dts file
[11:13:49.255] - Copy boot2_bl616_release_v8.0.8.bin
[11:13:49.257] - Copy mfg_bl616_gu_af8b0946f_v2.26.bin
[11:13:49.259] - Create dts for E:\system_file\desktop\AiPi-Open-Kits\AiPi-Eyes_weather\build\build_out\mfg_bl616_gu_af8b0946f_v2.26.bin
[11:13:49.259] - Create dts using bl_factory_params_IoTKitA_auto.dts
[11:13:49.262] - 4K header found,append dts file
[11:13:49.263] -
Process E:\system_file\desktop\AiPi-Open-Kits\AiPi-Eyes_weather\build\build_out\Eyes_bl616.bin
[11:13:49.264] - ========= sp image create =========
[11:13:49.265] - Flash config crc: b'b5fec518'
[11:13:49.265] - Clock config crc: b'4a05f490'
[11:13:49.265] - Image Offset:0x1000
[11:13:49.271] - Image hash is b'59f3243c4fab5bb592ee632a5344f1dc12fbb6bae3380ab53f28d953fdb1e35f'
[11:13:49.272] - Encrypt efuse data
[11:13:49.275] - Image Offset:0x1000
[11:13:49.275] - Image hash ignore,not calculate
[11:13:49.275] - Bootheader config crc: b'3747c780'
[11:13:49.276] -
Process E:\system_file\desktop\AiPi-Open-Kits\AiPi-Eyes_weather\build\build_out\boot2_bl616_release_v8.0.8.bin
[11:13:49.277] - ========= sp image create =========
[11:13:49.277] - Flash config crc: b'b5fec518'
[11:13:49.277] - Clock config crc: b'4a05f490'
[11:13:49.277] - Image Offset:0x2000
[11:13:49.277] - Image hash is b'4f4eecaddc6e597708f626253879f5560534d2e3baff848f4d96fabbce4b020f'
[11:13:49.278] - Encrypt efuse data
[11:13:49.278] - Image Offset:0x2000
[11:13:49.279] - Image hash ignore,not calculate
[11:13:49.279] - Bootheader config crc: b'ccbfa125'
[11:13:49.279] -
Process E:\system_file\desktop\AiPi-Open-Kits\AiPi-Eyes_weather\build\build_out\mfg_bl616_gu_af8b0946f_v2.26.bin
[11:13:49.280] - ========= sp image create =========
[11:13:49.280] - Flash config crc: b'4fb1fe70'
[11:13:49.280] - Clock config crc: b'0b34ef89'
[11:13:49.280] - Image Offset:0x1000
[11:13:49.282] - Image hash is b'69de5b7af45fea2e456fb6864612126bbdad58e69294d1466a2f892e010d1f3d'
[11:13:49.283] - Encrypt efuse data
[11:13:49.284] - Image Offset:0x1000
[11:13:49.284] - Bootheader config crc: b'f9cf01e0'
[11:13:49.819] - create XZ OTA file:E:\system_file\desktop\AiPi-Open-Kits\AiPi-Eyes_weather\build\build_out\Eyes_bl616.xz.ota
Built target combine
make (e=2): 系统找不到指定的文件。
PS E:\system_file\desktop\AiPi-Open-Kits\AiPi-Eyes_weather>
2933087375 发表于 2023-8-9 21:16
为啥我在克隆小安派的SDK这步,git报:fatal: failed to load library 'libcurl-4.dll'这个错误 ...
我去·,我也是
2023-11-11 17:45:30
那个是园长呀
我是最后在vsc编译时候编译器告诉我缺文件有和我一样的兄弟吗
process_begin: CreateProcess(NULL, #cp ./../aithinker_Ai-M6X_SDK/bsp/board/bl616dk/config/edata.bin build/build_out, ...) failed.
为什么我在验证是否成功那一步运行 riscv64-unknown-elf-gcc -v
以后显示这个?
还有一个问题,最后编译输入make以后显示
-- Warning: Did not find file Compiler/-ASM
-- Configuring incomplete, errors occurred!
See also "C:/Users/zyh/AiPi-Open-Kits/AiPi-Eyes_weather/build/CMakeFiles/CMakeOutput.log".
See also "C:/Users/zyh/AiPi-Open-Kits/AiPi-Eyes_weather/build/CMakeFiles/CMakeError.log".
这是什么问题,求大佬解答。
2023-11-11 21:33:10
ckdsx.cn 发表于 2023-8-14 12:30
学习一下!大佬威武!顺带问一句,这个录屏成动画的软件叫啥?
我猜是obs输出为gif就行。。。。
2023-11-12 00:28:55
学学 发表于 2023-10-24 23:26
终端提示:make (e=2): 系统找不到指定的文件。是啥原因要不建个QQ群吧这样方便 ...
有解决吗?
2023-11-12 00:56:19
nmghj 发表于 2023-11-10 00:34
有人解决了这个编译错误的问题吗?
cp ./../aithinker_Ai-M6X_SDK/bsp/board/bl616dk ...
参考这个 http://bbs.ai-thinker.com/forum. ... amp;_dsign=f70da3b5
  • 会员数: 30902 个
  • 话题数: 44871 篇
