12
返回列表 发新帖
2023-10-16 15:42:53
is麟儿 发表于 2023-10-16 15:17
D:\100_Src_Data\09_AI\AiPi-Open-Kits\aithinker_Ai-M6X_SDK\tools\make
D:\100_Src_Data\09_AI\AiPi-Open ...
@起个名字好难啊
2023-10-16 15:49:38
帮顶
2023-10-16 16:34:09
Redmi_2021@LAPTOP-BDJM4C6D MINGW64 /d/100_Src_Data/09_AI/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/examples/helloworld ((c7f51ba4...))
$ make clean
./../../tools/cmake/bin/cmake.exe -E remove_directory build
$ make
./../../tools/cmake/bin/cmake.exe -S . -B build -G "MinGW Makefiles" -DCROSS_COMPILE=riscv64-unknown-elf- -DCHIP=bl616 -DCPU_ID= -DBOARD=bl616dk -DBOARD_DIR= -DCONFIG_DEBUG=y -DCONFIG_ROMAPI=y -DCONFIG_USB_HS=y -DCONFIG_COMX=/dev/ttyUSB0 -DCMAKE_EXPORT_COMPILE_COMMANDS=OFF -DCONFIG_TLSF=y
-- The C compiler identification is GNU 10.2.0
-- The CXX compiler identification is GNU 10.2.0
-- The ASM compiler identification is GNU
-- Found assembler: D:/100_Src_Data/09_AI/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/toolchain_gcc_t-head_windows/bin/riscv64-unknown-elf-gcc.exe
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: D:/100_Src_Data/09_AI/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/toolchain_gcc_t-head_windows/bin/riscv64-unknown-elf-gcc.exe - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: D:/100_Src_Data/09_AI/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/toolchain_gcc_t-head_windows/bin/riscv64-unknown-elf-g++.exe - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- [register library : libc], path:/100_Src_Data/09_AI/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/components/libc
-- [register library : mm], path:/100_Src_Data/09_AI/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/components/mm
-- [register library : utils], path:/100_Src_Data/09_AI/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/components/utils
-- [register library : lhal], path:/100_Src_Data/09_AI/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/drivers/lhal
-- [register extern library : libcsi_xt900p32f_dsp], path:/100_Src_Data/09_AI/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/drivers/lhal
-- [register extern library : libpka], path:/100_Src_Data/09_AI/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/drivers/lhal
-- [register library : std], path:/100_Src_Data/09_AI/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/drivers/soc/bl616/std
-- Configuring done
-- Generating done
CMake Warning:
  Manually-specified variables were not used by the project:
    CONFIG_COMX
    CONFIG_USB_HS
-- Build files have been written to: D:/100_Src_Data/09_AI/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/examples/helloworld/build
make -C build -j8
[  0%] Building C object CMakeFiles/app.dir/D_/100_Src_Data/09_AI/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/bsp/board/bl616dk/board.c.obj
[  1%] Building C object CMakeFiles/app.dir/D_/100_Src_Data/09_AI/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/bsp/board/bl616dk/fw_header.c.obj
[  2%] Building ASM object build_out/drivers/soc/bl616/std/CMakeFiles/std.dir/startup/start.S.obj
[  3%] Building C object build_out/components/libc/CMakeFiles/libc.dir/newlib/port_memory.c.obj
[  3%] Building ASM object build_out/drivers/soc/bl616/std/CMakeFiles/std.dir/startup/vector.S.obj
[  3%] Building C object build_out/components/mm/CMakeFiles/mm.dir/mem.c.obj
[  3%] Building C object build_out/components/utils/CMakeFiles/utils.dir/log/log.c.obj
[  3%] Building C object build_out/drivers/lhal/CMakeFiles/lhal.dir/src/bflb_common.c.obj
[  4%] Building C object build_out/components/libc/CMakeFiles/libc.dir/newlib/syscalls_nosys.c.obj
[  5%] Building C object build_out/components/mm/CMakeFiles/mm.dir/tlsf/tlsf.c.obj
[  6%] Building ASM object build_out/drivers/soc/bl616/std/CMakeFiles/std.dir/startup/riscv_fpu.S.obj
[  7%] Building C object build_out/components/utils/CMakeFiles/utils.dir/ring_buffer/ring_buffer.c.obj
[  8%] Building C object build_out/drivers/lhal/CMakeFiles/lhal.dir/src/bflb_adc.c.obj
[  9%] Building C object build_out/components/libc/CMakeFiles/libc.dir/nuttx/libc/stdlib/lib_abs.c.obj
[ 10%] Building C object build_out/components/mm/CMakeFiles/mm.dir/tlsf/bflb_tlsf.c.obj
[ 11%] Linking C static library build_out\lib\libapp.a
[ 12%] Building C object build_out/drivers/soc/bl616/std/CMakeFiles/std.dir/startup/start_load.c.obj
[ 13%] Building C object build_out/components/utils/CMakeFiles/utils.dir/bflb_block_pool/bflb_block_pool.c.obj
[ 13%] Building C object build_out/components/libc/CMakeFiles/libc.dir/nuttx/libc/stdlib/lib_atof.c.obj
[ 13%] Built target app
[ 14%] Building C object build_out/drivers/lhal/CMakeFiles/lhal.dir/src/bflb_acomp.c.obj
[ 15%] Building C object build_out/drivers/soc/bl616/std/CMakeFiles/std.dir/startup/system_bl616.c.obj
[ 16%] Building C object build_out/components/libc/CMakeFiles/libc.dir/nuttx/libc/stdlib/lib_atoi.c.obj
[ 17%] Building C object build_out/components/utils/CMakeFiles/utils.dir/bflb_timestamp/bflb_timestamp.c.obj
[ 18%] Linking C static library ..\..\lib\libmm.a
[ 19%] Building C object build_out/components/utils/CMakeFiles/utils.dir/getopt/utils_getopt.c.obj
[ 20%] Building C object build_out/drivers/lhal/CMakeFiles/lhal.dir/src/bflb_cks.c.obj
[ 21%] Building C object build_out/drivers/soc/bl616/std/CMakeFiles/std.dir/startup/interrupt.c.obj
[ 22%] Building C object build_out/components/libc/CMakeFiles/libc.dir/nuttx/libc/stdlib/lib_atol.c.obj
[ 22%] Building C object build_out/drivers/soc/bl616/std/CMakeFiles/std.dir/src/bl616_romapi_e907.c.obj
[ 23%] Building C object build_out/drivers/lhal/CMakeFiles/lhal.dir/src/bflb_ef_ctrl.c.obj
[ 24%] Building C object build_out/components/libc/CMakeFiles/libc.dir/nuttx/libc/stdlib/lib_atoll.c.obj
[ 25%] Building C object build_out/drivers/soc/bl616/std/CMakeFiles/std.dir/src/bl616_romapi_patch.c.obj
[ 25%] Built target mm
[ 26%] Linking C static library ..\..\lib\libutils.a
[ 26%] Building C object build_out/drivers/lhal/CMakeFiles/lhal.dir/src/bflb_gpio.c.obj
[ 27%] Building C object build_out/components/libc/CMakeFiles/libc.dir/nuttx/libc/stdlib/lib_bsearch.c.obj
[ 28%] Building C object build_out/drivers/soc/bl616/std/CMakeFiles/std.dir/src/bl616_common.c.obj
[ 29%] Building C object build_out/drivers/lhal/CMakeFiles/lhal.dir/src/bflb_i2c.c.obj
[ 30%] Building C object build_out/drivers/soc/bl616/std/CMakeFiles/std.dir/src/bl616_ef_cfg.c.obj
[ 30%] Building C object build_out/components/libc/CMakeFiles/libc.dir/nuttx/libc/stdlib/lib_checkbase.c.obj
[ 30%] Built target utils
[ 31%] Building C object build_out/drivers/lhal/CMakeFiles/lhal.dir/src/bflb_dma.c.obj
[ 32%] Building C object build_out/drivers/soc/bl616/std/CMakeFiles/std.dir/src/bl616_sdh.c.obj
[ 33%] Building C object build_out/components/libc/CMakeFiles/libc.dir/nuttx/libc/stdlib/lib_itoa.c.obj
[ 34%] Building C object build_out/drivers/lhal/CMakeFiles/lhal.dir/src/bflb_rtc.c.obj
[ 35%] Building C object build_out/drivers/soc/bl616/std/CMakeFiles/std.dir/src/bl616_tzc_sec.c.obj
[ 36%] Building C object build_out/components/libc/CMakeFiles/libc.dir/nuttx/libc/stdlib/lib_llabs.c.obj
[ 37%] Building C object build_out/drivers/lhal/CMakeFiles/lhal.dir/src/bflb_sec_aes.c.obj
[ 37%] Building C object build_out/drivers/soc/bl616/std/CMakeFiles/std.dir/src/bl616_psram.c.obj
[ 38%] Building C object build_out/components/libc/CMakeFiles/libc.dir/nuttx/libc/stdlib/lib_lldiv.c.obj
[ 39%] Building C object build_out/drivers/lhal/CMakeFiles/lhal.dir/src/bflb_sec_sha.c.obj
[ 40%] Building C object build_out/drivers/soc/bl616/std/CMakeFiles/std.dir/src/bl616_pm.c.obj
[ 41%] Building C object build_out/components/libc/CMakeFiles/libc.dir/nuttx/libc/stdlib/lib_qsort.c.obj
[ 41%] Building C object build_out/drivers/lhal/CMakeFiles/lhal.dir/src/bflb_sec_trng.c.obj
[ 42%] Building C object build_out/drivers/soc/bl616/std/CMakeFiles/std.dir/src/bl616_aon.c.obj
[ 43%] Building C object build_out/drivers/lhal/CMakeFiles/lhal.dir/src/bflb_spi.c.obj
[ 43%] Building C object build_out/components/libc/CMakeFiles/libc.dir/nuttx/libc/stdlib/lib_strtod.c.obj
[ 44%] Building C object build_out/drivers/lhal/CMakeFiles/lhal.dir/src/bflb_timer.c.obj
[ 45%] Building C object build_out/components/libc/CMakeFiles/libc.dir/nuttx/libc/string/lib_ffs.c.obj
[ 46%] Building C object build_out/drivers/soc/bl616/std/CMakeFiles/std.dir/port/bl616_clock.c.obj
[ 47%] Building C object build_out/components/libc/CMakeFiles/libc.dir/nuttx/libc/string/lib_ffsl.c.obj
[ 48%] Building C object build_out/drivers/lhal/CMakeFiles/lhal.dir/src/bflb_uart.c.obj
[ 49%] Building C object build_out/drivers/lhal/CMakeFiles/lhal.dir/src/bflb_wdg.c.obj
[ 50%] Building C object build_out/components/libc/CMakeFiles/libc.dir/nuttx/libc/string/lib_ffsll.c.obj
[ 50%] Building C object build_out/drivers/lhal/CMakeFiles/lhal.dir/src/bflb_flash.c.obj
[ 51%] Building C object build_out/drivers/lhal/CMakeFiles/lhal.dir/src/flash/bflb_sf_cfg.c.obj
[ 52%] Building C object build_out/components/libc/CMakeFiles/libc.dir/nuttx/libc/string/lib_fls.c.obj
[ 53%] Building C object build_out/drivers/lhal/CMakeFiles/lhal.dir/src/flash/bflb_xip_sflash.c.obj
[ 54%] Linking C static library ..\..\..\..\lib\libstd.a
[ 55%] Building C object build_out/drivers/lhal/CMakeFiles/lhal.dir/src/flash/bflb_sflash.c.obj
[ 56%] Building C object build_out/components/libc/CMakeFiles/libc.dir/nuttx/libc/string/lib_flsl.c.obj
[ 56%] Building C object build_out/components/libc/CMakeFiles/libc.dir/nuttx/libc/string/lib_flsll.c.obj
[ 57%] Building C object build_out/drivers/lhal/CMakeFiles/lhal.dir/src/flash/bflb_sf_ctrl.c.obj
[ 58%] Building C object build_out/components/libc/CMakeFiles/libc.dir/nuttx/libc/string/lib_index.c.obj
[ 59%] Building C object build_out/components/libc/CMakeFiles/libc.dir/nuttx/libc/string/lib_memccpy.c.obj
[ 60%] Building C object build_out/components/libc/CMakeFiles/libc.dir/nuttx/libc/string/lib_memchr.c.obj
[ 60%] Building C object build_out/drivers/lhal/CMakeFiles/lhal.dir/src/bflb_dac.c.obj
[ 61%] Building C object build_out/drivers/lhal/CMakeFiles/lhal.dir/src/bflb_emac.c.obj
[ 61%] Built target std
[ 62%] Building C object build_out/components/libc/CMakeFiles/libc.dir/nuttx/libc/string/lib_memcmp.c.obj
[ 63%] Building C object build_out/drivers/lhal/CMakeFiles/lhal.dir/src/bflb_ir.c.obj
[ 64%] Building C object build_out/drivers/lhal/CMakeFiles/lhal.dir/src/bflb_mjpeg.c.obj
[ 65%] Building C object build_out/drivers/lhal/CMakeFiles/lhal.dir/src/bflb_pwm_v2.c.obj
[ 65%] Building C object build_out/components/libc/CMakeFiles/libc.dir/nuttx/libc/string/lib_memmove.c.obj
[ 66%] Building C object build_out/components/libc/CMakeFiles/libc.dir/nuttx/libc/string/lib_memrchr.c.obj
[ 67%] Building C object build_out/components/libc/CMakeFiles/libc.dir/nuttx/libc/string/lib_memset.c.obj
[ 68%] Building C object build_out/drivers/lhal/CMakeFiles/lhal.dir/src/bflb_cam.c.obj
[ 68%] Building C object build_out/drivers/lhal/CMakeFiles/lhal.dir/src/bflb_sdio2.c.obj
[ 69%] Building C object build_out/components/libc/CMakeFiles/libc.dir/nuttx/libc/string/lib_stpcpy.c.obj
[ 70%] Building C object build_out/drivers/lhal/CMakeFiles/lhal.dir/src/bflb_i2s.c.obj
[ 71%] Building C object build_out/components/libc/CMakeFiles/libc.dir/nuttx/libc/string/lib_stpncpy.c.obj
[ 72%] Building C object build_out/drivers/lhal/CMakeFiles/lhal.dir/src/bflb_dbi.c.obj
[ 73%] Building C object build_out/drivers/lhal/CMakeFiles/lhal.dir/src/bflb_audac.c.obj
[ 73%] Building C object build_out/components/libc/CMakeFiles/libc.dir/nuttx/libc/string/lib_strcasecmp.c.obj
[ 74%] Building C object build_out/components/libc/CMakeFiles/libc.dir/nuttx/libc/string/lib_strcasestr.c.obj
[ 75%] Building C object build_out/drivers/lhal/CMakeFiles/lhal.dir/src/bflb_auadc.c.obj
[ 76%] Building C object build_out/components/libc/CMakeFiles/libc.dir/nuttx/libc/string/lib_strcat.c.obj
[ 76%] Building C object build_out/drivers/lhal/CMakeFiles/lhal.dir/src/bflb_platform_dma.c.obj
[ 77%] Building C object build_out/components/libc/CMakeFiles/libc.dir/nuttx/libc/string/lib_strchr.c.obj
[ 78%] Building C object build_out/components/libc/CMakeFiles/libc.dir/nuttx/libc/string/lib_strcmp.c.obj
[ 79%] Building C object build_out/drivers/lhal/CMakeFiles/lhal.dir/src/bflb_irq.c.obj
[ 80%] Building C object build_out/drivers/lhal/CMakeFiles/lhal.dir/src/bflb_l1c.c.obj
[ 81%] Building C object build_out/components/libc/CMakeFiles/libc.dir/nuttx/libc/string/lib_strcspn.c.obj
[ 82%] Building C object build_out/drivers/lhal/CMakeFiles/lhal.dir/src/bflb_mtimer.c.obj
[ 82%] Building C object build_out/components/libc/CMakeFiles/libc.dir/nuttx/libc/string/lib_strdup.c.obj
[ 83%] Building C object build_out/drivers/lhal/CMakeFiles/lhal.dir/include/arch/risc-v/t-head/rv_hart.c.obj
[ 84%] Building C object build_out/components/libc/CMakeFiles/libc.dir/nuttx/libc/string/lib_strnlen.c.obj
[ 84%] Building C object build_out/drivers/lhal/CMakeFiles/lhal.dir/include/arch/risc-v/t-head/rv_pmp.c.obj
[ 85%] Building C object build_out/components/libc/CMakeFiles/libc.dir/nuttx/libc/string/lib_strpbrk.c.obj
[ 86%] Building C object build_out/drivers/lhal/CMakeFiles/lhal.dir/config/bl616/device_table.c.obj
[ 87%] Building C object build_out/components/libc/CMakeFiles/libc.dir/nuttx/libc/string/lib_strrchr.c.obj
[ 88%] Building C object build_out/components/libc/CMakeFiles/libc.dir/nuttx/libc/string/lib_strsep.c.obj
[ 88%] Building C object build_out/components/libc/CMakeFiles/libc.dir/nuttx/libc/string/lib_strspn.c.obj
[ 89%] Building C object build_out/components/libc/CMakeFiles/libc.dir/nuttx/libc/string/lib_strstr.c.obj
[ 90%] Building C object build_out/components/libc/CMakeFiles/libc.dir/nuttx/libc/string/lib_strtok.c.obj
[ 91%] Building C object build_out/components/libc/CMakeFiles/libc.dir/nuttx/libc/string/lib_strtokr.c.obj
[ 92%] Building C object build_out/components/libc/CMakeFiles/libc.dir/nuttx/libc/string/lib_vikmemcpy.c.obj
[ 93%] Linking C static library ..\..\lib\liblhal.a
[ 93%] Building C object build_out/components/libc/CMakeFiles/libc.dir/vsnprintf.c.obj
[ 94%] Building C object build_out/components/libc/CMakeFiles/libc.dir/snprintf.c.obj
[ 95%] Building C object build_out/components/libc/CMakeFiles/libc.dir/sprintf.c.obj
[ 96%] Building C object build_out/components/libc/CMakeFiles/libc.dir/vsprintf.c.obj
[ 97%] Building C object build_out/components/libc/CMakeFiles/libc.dir/printf.c.obj
[ 97%] Built target lhal
[ 98%] Linking C static library ..\..\lib\liblibc.a
[ 98%] Built target libc
[ 99%] Building C object CMakeFiles/helloworld_bl616.elf.dir/main.c.obj
[100%] Linking C executable build_out\helloworld_bl616.elf
Generate D:/100_Src_Data/09_AI/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/examples/helloworld/build/build_out/helloworld_bl616.bin
[100%] Built target helloworld_bl616.elf
make -C build combine
[16:30:21.734] - bflb firmware post process : V1.2.0
[16:30:21.734] - Chipname: bl616
[16:30:21.734] - Board config dir: ./../../bsp/board/bl616dk/config
[16:30:21.734] - Create partition using partition_cfg_4M.toml
[16:30:21.738] - Create dts for D:\100_Src_Data\09_AI\AiPi-Open-Kits\aithinker_Ai-M6X_SDK\examples\helloworld\build\build_out\helloworld_bl616.bin
[16:30:21.738] - Create dts using bl_factory_params_IoTKitA_auto.dts
[16:30:21.738] - 4K header found,append dts file
[16:30:21.742] - Copy boot2_bl616_release_v8.0.8.bin
[16:30:21.742] - Copy mfg_bl616_gu_af8b0946f_v2.26.bin
[16:30:21.742] - Create dts for D:\100_Src_Data\09_AI\AiPi-Open-Kits\aithinker_Ai-M6X_SDK\examples\helloworld\build\build_out\mfg_bl616_gu_af8b0946f_v2.26.bin
[16:30:21.742] - Create dts using bl_factory_params_IoTKitA_auto.dts
[16:30:21.746] - 4K header found,append dts file
[16:30:21.746] -
Process D:\100_Src_Data\09_AI\AiPi-Open-Kits\aithinker_Ai-M6X_SDK\examples\helloworld\build\build_out\helloworld_bl616.bin
[16:30:21.746] - ========= sp image create =========
[16:30:21.746] - Flash config crc: b'b5fec518'
[16:30:21.746] - Clock config crc: b'4a05f490'
[16:30:21.746] - Image Offset:0x1000
[16:30:21.746] - Image hash is b'cd177f384f33c83c07f428c1e6d3da46f6487b44c9a8decdcd3c8da00d547a46'
[16:30:21.746] - Encrypt efuse data
[16:30:21.750] - Image Offset:0x1000
[16:30:21.750] - Image hash ignore,not calculate
[16:30:21.750] - Bootheader config crc: b'4ddfb44c'
[16:30:21.750] -
Process D:\100_Src_Data\09_AI\AiPi-Open-Kits\aithinker_Ai-M6X_SDK\examples\helloworld\build\build_out\boot2_bl616_release_v8.0.8.bin
[16:30:21.750] - ========= sp image create =========
[16:30:21.750] - Flash config crc: b'b5fec518'
[16:30:21.750] - Clock config crc: b'4a05f490'
[16:30:21.750] - Image Offset:0x2000
[16:30:21.750] - Image hash is b'4f4eecaddc6e597708f626253879f5560534d2e3baff848f4d96fabbce4b020f'
[16:30:21.750] - Encrypt efuse data
[16:30:21.750] - Bootheader config crc: b'ccbfa125'
[16:30:21.750] -
Process D:\100_Src_Data\09_AI\AiPi-Open-Kits\aithinker_Ai-M6X_SDK\examples\helloworld\build\build_out\mfg_bl616_gu_af8b0946f_v2.26.bin
[16:30:21.754] - ========= sp image create =========
[16:30:21.754] - Flash config crc: b'4fb1fe70'
[16:30:21.754] - Clock config crc: b'0b34ef89'
[16:30:21.754] - Image Offset:0x1000
[16:30:21.754] - Image hash is b'69de5b7af45fea2e456fb6864612126bbdad58e69294d1466a2f892e010d1f3d'
[16:30:21.754] - Encrypt efuse data
[16:30:21.754] - Bootheader config crc: b'f9cf01e0'
[16:30:21.754] - create OTA file:\100_Src_Data\09_AI\AiPi-Open-Kits\aithinker_Ai-M6X_SDK\examples\helloworld\build\build_out\helloworld_bl616.bin.ota
[16:30:21.758] - create XZ file:\100_Src_Data\09_AI\AiPi-Open-Kits\aithinker_Ai-M6X_SDK\examples\helloworld\build\build_out\helloworld_bl616.xz
[16:30:21.770] - create XZ OTA file:\100_Src_Data\09_AI\AiPi-Open-Kits\aithinker_Ai-M6X_SDK\examples\helloworld\build\build_out\helloworld_bl616.xz.ota
Built target combine
cp ./../../bsp/board/bl616dk/config/edata.bin build/build_out
cp ./../../bsp/board/bl616dk/config/Rx_boot2_m61.bin build/build_out
怀疑是vscode的问题,但是咱也找不到证据。就直接在源码目录下,用git bash ,make一下 发现没有报错,大佬们看看是不是正确编译了
2023-10-16 16:42:20
Redmi_2021@LAPTOP-BDJM4C6D MINGW64 /d/100_Src_Data/09_AI/AiPi-Open-Kits/AiPi-Eyes_weather (master)
$ make flash COMX=COM38
./../aithinker_Ai-M6X_SDK/tools/cmake/bin/cmake.exe -S . -B build -G "MinGW Makefiles" -DCROSS_COMPILE=riscv64-unknown-elf- -DCHIP=bl616 -DCPU_ID= -DBOARD=bl616dk -DBOARD_DIR= -DCONFIG_DEBUG=y -DCONFIG_ROMAPI=y -DCONFIG_USB_HS=y -DCONFIG_COMX=COM38 -DCMAKE_EXPORT_COMPILE_COMMANDS=OFF -DCONFIG_TLSF=y
-- [register library : mbedtls], path:/100_Src_Data/09_AI/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/components/crypto/mbedtls
-- [register library : lvgl], path:/100_Src_Data/09_AI/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/components/graphics/lvgl
-- [register library : lwip], path:/100_Src_Data/09_AI/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/components/net/lwip/lwip
-- [register library : dhcpd], path:/100_Src_Data/09_AI/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/components/net/lwip/lwip_apps/dhcpd
-- [register library : ping], path:/100_Src_Data/09_AI/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/components/net/lwip/lwip_apps/ping
-- [register library : freertos], path:/100_Src_Data/09_AI/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/components/os/freertos
-- [register extern library : libwifi6], path:/100_Src_Data/09_AI/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/components/wireless/wifi6
-- [register library : bl6_os_adapter], path:D:/100_Src_Data/09_AI/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/components/wireless/wifi6/bl6_os_adapter
-- [register library : easyflash4], path:D:/100_Src_Data/09_AI/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/components/easyflash4
-- [register library : lhal], path:D:/100_Src_Data/09_AI/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/drivers/lhal
-- [register extern library : libcsi_xt900p32f_dsp], path:D:/100_Src_Data/09_AI/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/drivers/lhal
-- [register extern library : libpka], path:D:/100_Src_Data/09_AI/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/drivers/lhal
-- [register library : std], path:D:/100_Src_Data/09_AI/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/drivers/soc/bl616/std
-- [register extern library : librf], path:D:/100_Src_Data/09_AI/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/drivers/soc/bl616/rf
-- [register library : rfparam], path:D:/100_Src_Data/09_AI/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/drivers/rfparam
-- Configuring done
-- Generating done
-- Build files have been written to: D:/100_Src_Data/09_AI/AiPi-Open-Kits/AiPi-Eyes_weather/build
make -C build -j8
[  6%] Built target lhal
[ 20%] Built target mbedtls
[ 29%] Built target libc
[ 30%] Built target mm
[ 36%] Built target lwip
[ 36%] Built target ping
[ 37%] Built target easyflash4
[ 38%] Built target bl6_os_adapter
[ 40%] Built target utils
[ 44%] Built target freertos
[ 44%] Built target dhcpd
[ 47%] Built target std
[ 68%] Built target app
[ 99%] Built target lvgl
[100%] Built target rfparam
[100%] Built target Eyes_bl616.elf
[16:39:47.140] - bflb firmware post process : V1.2.0
[16:39:47.140] - Chipname: bl616
[16:39:47.140] - Board config dir: ./../aithinker_Ai-M6X_SDK/bsp/board/bl616dk/config
[16:39:47.140] - Create partition using partition_cfg_4M.toml
[16:39:47.140] - Create dts for D:\100_Src_Data\09_AI\AiPi-Open-Kits\AiPi-Eyes_weather\build\build_out\Eyes_bl616.bin
[16:39:47.140] - Create dts using bl_factory_params_IoTKitA_auto.dts
[16:39:47.144] - 4K header found,append dts file
[16:39:47.144] - Copy boot2_bl616_release_v8.0.8.bin
[16:39:47.148] - Copy mfg_bl616_gu_af8b0946f_v2.26.bin
[16:39:47.148] - Create dts for D:\100_Src_Data\09_AI\AiPi-Open-Kits\AiPi-Eyes_weather\build\build_out\mfg_bl616_gu_af8b0946f_v2.26.bin
[16:39:47.148] - Create dts using bl_factory_params_IoTKitA_auto.dts
[16:39:47.152] - 4K header found,append dts file
[16:39:47.152] -
Process D:\100_Src_Data\09_AI\AiPi-Open-Kits\AiPi-Eyes_weather\build\build_out\Eyes_bl616.bin
[16:39:47.152] - ========= sp image create =========
[16:39:47.152] - Flash config crc: b'b5fec518'
[16:39:47.152] - Clock config crc: b'4a05f490'
[16:39:47.152] - Image Offset:0x1000
[16:39:47.160] - Image hash is b'c70f0bbc3c6b4ee133b0dca008e9fd4cdd0447079804b3d76d341a50380560a6'
[16:39:47.160] - Encrypt efuse data
[16:39:47.164] - Image Offset:0x1000
[16:39:47.164] - Image hash ignore,not calculate
[16:39:47.164] - Bootheader config crc: b'a37a9e42'
[16:39:47.164] -
Process D:\100_Src_Data\09_AI\AiPi-Open-Kits\AiPi-Eyes_weather\build\build_out\boot2_bl616_release_v8.0.8.bin
[16:39:47.164] - ========= sp image create =========
[16:39:47.164] - Flash config crc: b'b5fec518'
[16:39:47.164] - Clock config crc: b'4a05f490'
[16:39:47.164] - Image Offset:0x2000
[16:39:47.164] - Image hash is b'4f4eecaddc6e597708f626253879f5560534d2e3baff848f4d96fabbce4b020f'
[16:39:47.164] - Encrypt efuse data
[16:39:47.164] - Bootheader config crc: b'ccbfa125'
[16:39:47.164] -
Process D:\100_Src_Data\09_AI\AiPi-Open-Kits\AiPi-Eyes_weather\build\build_out\mfg_bl616_gu_af8b0946f_v2.26.bin
[16:39:47.164] - Flash config crc: b'4fb1fe70'
[16:39:47.164] - Clock config crc: b'0b34ef89'
[16:39:47.168] - Image hash is b'69de5b7af45fea2e456fb6864612126bbdad58e69294d1466a2f892e010d1f3d'
[16:39:47.168] - Encrypt efuse data
[16:39:47.168] - Image Offset:0x1000
[16:39:47.168] - Bootheader config crc: b'f9cf01e0'
[16:39:47.168] - create OTA file:D:\100_Src_Data\09_AI\AiPi-Open-Kits\AiPi-Eyes_weather\build\build_out\Eyes_bl616.bin.ota
[16:39:47.301] - create XZ file:D:\100_Src_Data\09_AI\AiPi-Open-Kits\AiPi-Eyes_weather\build\build_out\Eyes_bl616.xz
[16:39:47.831] - create XZ OTA file:D:\100_Src_Data\09_AI\AiPi-Open-Kits\AiPi-Eyes_weather\build\build_out\Eyes_bl616.xz.ota
cp ./../aithinker_Ai-M6X_SDK/bsp/board/bl616dk/config/Rx_boot2_m61.bin build/build_out
./../aithinker_Ai-M6X_SDK/tools/bflb_tools/bouffalo_flash_cube/BLFlashCommand.exe --interface=uart --baudrate=2000000 --port=COM38 --chipname=bl616 --cpu_id= --config=flash_prog_cfg.ini
['./../aithinker_Ai-M6X_SDK/tools/bflb_tools/bouffalo_flash_cube/BLFlashCommand.exe', '--interface=uart', '--baudrate=2000000', '--port=COM38', '--chipname=bl616', '--cpu_id=', '--config=flash_prog_cfg.ini']
[16:39:49.395] - Serial port is COM38
[16:39:49.399] - ==================================================
[16:39:49.399] - Program Start
[16:39:49.399] - ========= eflash loader cmd arguments =========
[16:39:49.403] - serial port is COM38
[16:39:49.403] - chiptype: bl616
[16:39:49.403] - cpu_reset=False
[16:39:49.495] - ========= Interface is uart =========
[16:39:49.495] - isp mode speed: 2000000
[16:39:49.495] - Bootrom load
[16:39:49.495] - ========= get_boot_info =========
[16:39:49.495] - ========= image get bootinfo =========
[16:39:49.507] - Please Press Reset Key!
[16:39:53.774] - isp ready
[16:39:56.329] - default set DTR high
[16:39:56.433] - clean buf
[16:39:56.433] - send sync
[16:39:56.665] - ack is b'4f4b464c0201464c0201464c0201464c0201'
[16:39:56.697] - shake hand success
[16:39:57.211] - data read is b'0100160600000100271289014faf41e0c2b499000f758010'
[16:39:57.211] - ========= ChipID: b4c2e041af4f =========
[16:39:57.211] - Get bootinfo time cost(ms): 7715.8212890625
[16:39:57.211] - change bdrate: 2000000
[16:39:57.211] - Clock PLL set
[16:39:57.211] - Set clock time cost(ms): 0.0
[16:39:57.334] - flash set para
[16:39:57.334] - get flash pin cfg from bootinfo: 0x24
[16:39:57.334] - set flash cfg: 14124
[16:39:57.334] - Set flash config
[16:39:57.334] - Set para time cost(ms): 0.0
[16:39:57.334] - ========= flash read jedec ID =========
[16:39:57.339] - Read flash jedec ID
[16:39:57.339] - readdata:
[16:39:57.339] - b'c8401700'
[16:39:57.339] - Finished
[16:39:57.341] - Program operation
[16:39:57.341] - Dealing Index 0
[16:39:57.341] - ========= programming D:\100_Src_Data\09_AI\AiPi-Open-Kits\AiPi-Eyes_weather\.\build\build_out\boot2_bl616_release_v8.0.8.bin
[16:39:57.341] - flash para file: D:\100_Src_Data\09_AI\AiPi-Open-Kits\aithinker_Ai-M6X_SDK\tools\bflb_tools\bouffalo_flash_cube\chips/bl616/efuse_bootheader/flash_para.bin
[16:39:57.341] - Set flash config
[16:39:57.345] - Set para time cost(ms): 4.0029296875
[16:39:57.345] - ========= flash load =========
[16:39:57.345] - ========= flash erase =========
[16:39:57.345] - Erase flash  from 0x0 to 0xb0ef
[16:39:57.582] - Erase time cost(ms): 237.5361328125
[16:39:57.597] - Load 2048/45296 {"progress":4}
[16:39:57.613] - Load 4096/45296 {"progress":9}
[16:39:57.629] - Load 6144/45296 {"progress":13}
[16:39:57.641] - Load 8192/45296 {"progress":18}
[16:39:57.657] - Load 10240/45296 {"progress":22}
[16:39:57.673] - Load 12288/45296 {"progress":27}
[16:39:57.689] - Load 14336/45296 {"progress":31}
[16:39:57.701] - Load 16384/45296 {"progress":36}
[16:39:57.717] - Load 18432/45296 {"progress":40}
[16:39:57.733] - Load 20480/45296 {"progress":45}
[16:39:57.749] - Load 22528/45296 {"progress":49}
[16:39:57.761] - Load 24576/45296 {"progress":54}
[16:39:57.777] - Load 26624/45296 {"progress":58}
[16:39:57.794] - Load 28672/45296 {"progress":63}
[16:39:57.808] - Load 30720/45296 {"progress":67}
[16:39:57.823] - Load 32768/45296 {"progress":72}
[16:39:57.838] - Load 34816/45296 {"progress":76}
[16:39:57.851] - Load 36864/45296 {"progress":81}
[16:39:57.867] - Load 38912/45296 {"progress":85}
[16:39:57.884] - Load 40960/45296 {"progress":90}
[16:39:57.900] - Load 43008/45296 {"progress":94}
[16:39:57.913] - Load 45056/45296 {"progress":99}
[16:39:57.917] - Load 45296/45296 {"progress":100}
[16:39:57.917] - Write check
[16:39:57.917] - Flash load time cost(ms): 334.768798828125
[16:39:57.917] - Finished
[16:39:57.917] - Sha caled by host: 5d4b8621db7bfa71251c92ae8e0bf4c6952ee2aa558ecf6129e858c6f1b9ff0a
[16:39:57.917] - xip mode Verify
[16:39:57.961] - Read Sha256/45296
[16:39:57.961] - Flash xip readsha time cost(ms): 40.01025390625
[16:39:57.961] - Finished
[16:39:57.961] - Sha caled by dev: 5d4b8621db7bfa71251c92ae8e0bf4c6952ee2aa558ecf6129e858c6f1b9ff0a
[16:39:57.961] - Verify success
[16:39:57.961] - Dealing Index 1
[16:39:57.961] - ========= programming D:\100_Src_Data\09_AI\AiPi-Open-Kits\AiPi-Eyes_weather\.\build\build_out\partition.bin
[16:39:57.965] - flash para file: D:\100_Src_Data\09_AI\AiPi-Open-Kits\aithinker_Ai-M6X_SDK\tools\bflb_tools\bouffalo_flash_cube\chips/bl616/efuse_bootheader/flash_para.bin
[16:39:57.965] - Set flash config
[16:39:57.969] - Set para time cost(ms): 4.0009765625
[16:39:57.969] - ========= flash load =========
[16:39:57.969] - ========= flash erase =========
[16:39:57.969] - Erase flash  from 0xe000 to 0xe133
[16:39:58.009] - Erase time cost(ms): 39.915283203125
[16:39:58.013] - Load 308/308 {"progress":100}
[16:39:58.013] - Write check
[16:39:58.017] - Flash load time cost(ms): 8.00244140625
[16:39:58.017] - Finished
[16:39:58.017] - Sha caled by host: 99c055a2a7279c04d989a2a270106d2e2584a2d5773b57e40b3af0d87f623d12
[16:39:58.017] - xip mode Verify
[16:39:58.021] - Read Sha256/308
[16:39:58.021] - Flash xip readsha time cost(ms): 4.001220703125
[16:39:58.021] - Finished
[16:39:58.021] - Sha caled by dev: 99c055a2a7279c04d989a2a270106d2e2584a2d5773b57e40b3af0d87f623d12
[16:39:58.021] - Verify success
[16:39:58.021] - Dealing Index 2
[16:39:58.021] - ========= programming D:\100_Src_Data\09_AI\AiPi-Open-Kits\AiPi-Eyes_weather\.\build\build_out\Eyes_bl616.bin
[16:39:58.025] - flash para file: D:\100_Src_Data\09_AI\AiPi-Open-Kits\aithinker_Ai-M6X_SDK\tools\bflb_tools\bouffalo_flash_cube\chips/bl616/efuse_bootheader/flash_para.bin
[16:39:58.025] - Set flash config
[16:39:58.029] - Set para time cost(ms): 4.00146484375
[16:39:58.029] - ========= flash load =========
[16:39:58.029] - ========= flash erase =========
[16:39:58.029] - Erase flash  from 0x10000 to 0x19a65f
[16:40:00.530] - Erase time cost(ms): 2501.33447265625
[16:40:00.546] - Load 2048/1615456 {"progress":0}
[16:40:00.562] - Load 4096/1615456 {"progress":0}
[16:40:00.578] - Load 6144/1615456 {"progress":0}
[16:40:00.594] - Load 8192/1615456 {"progress":0}
[16:40:00.609] - Load 10240/1615456 {"progress":0}
[16:40:00.624] - Load 12288/1615456 {"progress":0}
[16:40:00.640] - Load 14336/1615456 {"progress":0}
[16:40:00.656] - Load 16384/1615456 {"progress":1}
[16:40:00.668] - Load 18432/1615456 {"progress":1}
[16:40:00.685] - Load 20480/1615456 {"progress":1}
[16:40:00.701] - Load 22528/1615456 {"progress":1}
[16:40:00.713] - Load 24576/1615456 {"progress":1}
[16:40:00.729] - Load 26624/1615456 {"progress":1}
[16:40:00.745] - Load 28672/1615456 {"progress":1}
[16:40:00.757] - Load 30720/1615456 {"progress":1}
[16:40:00.773] - Load 32768/1615456 {"progress":2}
[16:40:00.789] - Load 34816/1615456 {"progress":2}
[16:40:00.805] - Load 36864/1615456 {"progress":2}
[16:40:00.817] - Load 38912/1615456 {"progress":2}
[16:40:00.834] - Load 40960/1615456 {"progress":2}
[16:40:00.850] - Load 43008/1615456 {"progress":2}
[16:40:00.866] - Load 45056/1615456 {"progress":2}
[16:40:00.882] - Load 47104/1615456 {"progress":2}
[16:40:00.897] - Load 49152/1615456 {"progress":3}
[16:40:00.909] - Load 51200/1615456 {"progress":3}
[16:40:00.925] - Load 53248/1615456 {"progress":3}
[16:40:00.941] - Load 55296/1615456 {"progress":3}
[16:40:00.954] - Load 57344/1615456 {"progress":3}
[16:40:00.969] - Load 59392/1615456 {"progress":3}
[16:40:00.985] - Load 61440/1615456 {"progress":3}
[16:40:01.002] - Load 63488/1615456 {"progress":3}
[16:40:01.017] - Load 65536/1615456 {"progress":4}
[16:40:01.033] - Load 67584/1615456 {"progress":4}
[16:40:01.045] - Load 69632/1615456 {"progress":4}
[16:40:01.061] - Load 71680/1615456 {"progress":4}
[16:40:01.077] - Load 73728/1615456 {"progress":4}
[16:40:01.093] - Load 75776/1615456 {"progress":4}
[16:40:01.105] - Load 77824/1615456 {"progress":4}
[16:40:01.121] - Load 79872/1615456 {"progress":4}
[16:40:01.135] - Load 81920/1615456 {"progress":5}
[16:40:01.153] - Load 83968/1615456 {"progress":5}
[16:40:01.165] - Load 86016/1615456 {"progress":5}
[16:40:01.181] - Load 88064/1615456 {"progress":5}
[16:40:01.197] - Load 90112/1615456 {"progress":5}
[16:40:01.213] - Load 92160/1615456 {"progress":5}
[16:40:01.225] - Load 94208/1615456 {"progress":5}
[16:40:01.242] - Load 96256/1615456 {"progress":5}
[16:40:01.258] - Load 98304/1615456 {"progress":6}
[16:40:01.271] - Load 100352/1615456 {"progress":6}
[16:40:01.286] - Load 102400/1615456 {"progress":6}
[16:40:01.302] - Load 104448/1615456 {"progress":6}
[16:40:01.318] - Load 106496/1615456 {"progress":6}
[16:40:01.333] - Load 108544/1615456 {"progress":6}
[16:40:01.349] - Load 110592/1615456 {"progress":6}
[16:40:01.364] - Load 112640/1615456 {"progress":6}
[16:40:01.379] - Load 114688/1615456 {"progress":7}
[16:40:01.394] - Load 116736/1615456 {"progress":7}
[16:40:01.409] - Load 118784/1615456 {"progress":7}
[16:40:01.424] - Load 120832/1615456 {"progress":7}
[16:40:01.439] - Load 122880/1615456 {"progress":7}
[16:40:01.453] - Load 124928/1615456 {"progress":7}
[16:40:01.469] - Load 126976/1615456 {"progress":7}
[16:40:01.481] - Load 129024/1615456 {"progress":7}
[16:40:01.497] - Load 131072/1615456 {"progress":8}
[16:40:01.513] - Load 133120/1615456 {"progress":8}
[16:40:01.529] - Load 135168/1615456 {"progress":8}
[16:40:01.544] - Load 137216/1615456 {"progress":8}
[16:40:01.558] - Load 139264/1615456 {"progress":8}
[16:40:01.574] - Load 141312/1615456 {"progress":8}
[16:40:01.586] - Load 143360/1615456 {"progress":8}
[16:40:01.601] - Load 145408/1615456 {"progress":9}
[16:40:01.617] - Load 147456/1615456 {"progress":9}
[16:40:01.633] - Load 149504/1615456 {"progress":9}
[16:40:01.649] - Load 151552/1615456 {"progress":9}
[16:40:01.662] - Load 153600/1615456 {"progress":9}
[16:40:01.678] - Load 155648/1615456 {"progress":9}
[16:40:01.695] - Load 157696/1615456 {"progress":9}
[16:40:01.707] - Load 159744/1615456 {"progress":9}
[16:40:01.723] - Load 161792/1615456 {"progress":10}
[16:40:01.739] - Load 163840/1615456 {"progress":10}
[16:40:01.755] - Load 165888/1615456 {"progress":10}
[16:40:01.770] - Load 167936/1615456 {"progress":10}
[16:40:01.782] - Load 169984/1615456 {"progress":10}
[16:40:01.798] - Load 172032/1615456 {"progress":10}
[16:40:01.814] - Load 174080/1615456 {"progress":10}
[16:40:01.830] - Load 176128/1615456 {"progress":10}
[16:40:01.844] - Load 178176/1615456 {"progress":11}
[16:40:01.861] - Load 180224/1615456 {"progress":11}
[16:40:01.876] - Load 182272/1615456 {"progress":11}
[16:40:01.891] - Load 184320/1615456 {"progress":11}
[16:40:01.906] - Load 186368/1615456 {"progress":11}
[16:40:01.921] - Load 188416/1615456 {"progress":11}
[16:40:01.936] - Load 190464/1615456 {"progress":11}
[16:40:01.951] - Load 192512/1615456 {"progress":11}
[16:40:01.966] - Load 194560/1615456 {"progress":12}
[16:40:01.981] - Load 196608/1615456 {"progress":12}
[16:40:01.996] - Load 198656/1615456 {"progress":12}
[16:40:02.010] - Load 200704/1615456 {"progress":12}
[16:40:02.024] - Load 202752/1615456 {"progress":12}
[16:40:02.040] - Load 204800/1615456 {"progress":12}
[16:40:02.056] - Load 206848/1615456 {"progress":12}
[16:40:02.070] - Load 208896/1615456 {"progress":12}
[16:40:02.087] - Load 210944/1615456 {"progress":13}
[16:40:02.101] - Load 212992/1615456 {"progress":13}
[16:40:02.117] - Load 215040/1615456 {"progress":13}
[16:40:02.129] - Load 217088/1615456 {"progress":13}
[16:40:02.145] - Load 219136/1615456 {"progress":13}
[16:40:02.161] - Load 221184/1615456 {"progress":13}
[16:40:02.178] - Load 223232/1615456 {"progress":13}
[16:40:02.192] - Load 225280/1615456 {"progress":13}
[16:40:02.205] - Load 227328/1615456 {"progress":14}
[16:40:02.222] - Load 229376/1615456 {"progress":14}
[16:40:02.234] - Load 231424/1615456 {"progress":14}
[16:40:02.250] - Load 233472/1615456 {"progress":14}
[16:40:02.267] - Load 235520/1615456 {"progress":14}
[16:40:02.283] - Load 237568/1615456 {"progress":14}
[16:40:02.295] - Load 239616/1615456 {"progress":14}
[16:40:02.312] - Load 241664/1615456 {"progress":14}
[16:40:02.328] - Load 243712/1615456 {"progress":15}
[16:40:02.344] - Load 245760/1615456 {"progress":15}
[16:40:02.356] - Load 247808/1615456 {"progress":15}
[16:40:02.372] - Load 249856/1615456 {"progress":15}
[16:40:02.388] - Load 251904/1615456 {"progress":15}
[16:40:02.400] - Load 253952/1615456 {"progress":15}
[16:40:02.419] - Load 256000/1615456 {"progress":15}
[16:40:02.433] - Load 258048/1615456 {"progress":15}
[16:40:02.449] - Load 260096/1615456 {"progress":16}
[16:40:02.461] - Load 262144/1615456 {"progress":16}
[16:40:02.477] - Load 264192/1615456 {"progress":16}
[16:40:02.493] - Load 266240/1615456 {"progress":16}
[16:40:02.509] - Load 268288/1615456 {"progress":16}
[16:40:02.524] - Load 270336/1615456 {"progress":16}
[16:40:02.539] - Load 272384/1615456 {"progress":16}
[16:40:02.551] - Load 274432/1615456 {"progress":16}
[16:40:02.565] - Load 276480/1615456 {"progress":17}
[16:40:02.581] - Load 278528/1615456 {"progress":17}
[16:40:02.598] - Load 280576/1615456 {"progress":17}
[16:40:02.613] - Load 282624/1615456 {"progress":17}
[16:40:02.629] - Load 284672/1615456 {"progress":17}
[16:40:02.643] - Load 286720/1615456 {"progress":17}
[16:40:02.659] - Load 288768/1615456 {"progress":17}
[16:40:02.671] - Load 290816/1615456 {"progress":18}
[16:40:02.688] - Load 292864/1615456 {"progress":18}
[16:40:02.701] - Load 294912/1615456 {"progress":18}
[16:40:02.720] - Load 296960/1615456 {"progress":18}
[16:40:02.734] - Load 299008/1615456 {"progress":18}
[16:40:02.749] - Load 301056/1615456 {"progress":18}
[16:40:02.763] - Load 303104/1615456 {"progress":18}
[16:40:02.779] - Load 305152/1615456 {"progress":18}
[16:40:02.791] - Load 307200/1615456 {"progress":19}
[16:40:02.807] - Load 309248/1615456 {"progress":19}
[16:40:02.823] - Load 311296/1615456 {"progress":19}
[16:40:02.839] - Load 313344/1615456 {"progress":19}
[16:40:02.855] - Load 315392/1615456 {"progress":19}
[16:40:02.869] - Load 317440/1615456 {"progress":19}
[16:40:02.885] - Load 319488/1615456 {"progress":19}
[16:40:02.900] - Load 321536/1615456 {"progress":19}
[16:40:02.914] - Load 323584/1615456 {"progress":20}
[16:40:02.930] - Load 325632/1615456 {"progress":20}
[16:40:02.945] - Load 327680/1615456 {"progress":20}
[16:40:02.959] - Load 329728/1615456 {"progress":20}
[16:40:02.971] - Load 331776/1615456 {"progress":20}
[16:40:02.989] - Load 333824/1615456 {"progress":20}
[16:40:03.001] - Load 335872/1615456 {"progress":20}
[16:40:03.017] - Load 337920/1615456 {"progress":20}
[16:40:03.033] - Load 339968/1615456 {"progress":21}
[16:40:03.049] - Load 342016/1615456 {"progress":21}
[16:40:03.062] - Load 344064/1615456 {"progress":21}
[16:40:03.081] - Load 346112/1615456 {"progress":21}
[16:40:03.093] - Load 348160/1615456 {"progress":21}
[16:40:03.109] - Load 350208/1615456 {"progress":21}
[16:40:03.125] - Load 352256/1615456 {"progress":21}
[16:40:03.141] - Load 354304/1615456 {"progress":21}
[16:40:03.154] - Load 356352/1615456 {"progress":22}
[16:40:03.170] - Load 358400/1615456 {"progress":22}
[16:40:03.186] - Load 360448/1615456 {"progress":22}
[16:40:03.198] - Load 362496/1615456 {"progress":22}
[16:40:03.214] - Load 364544/1615456 {"progress":22}
[16:40:03.230] - Load 366592/1615456 {"progress":22}
[16:40:03.246] - Load 368640/1615456 {"progress":22}
[16:40:03.258] - Load 370688/1615456 {"progress":22}
[16:40:03.276] - Load 372736/1615456 {"progress":23}
[16:40:03.289] - Load 374784/1615456 {"progress":23}
[16:40:03.305] - Load 376832/1615456 {"progress":23}
[16:40:03.319] - Load 378880/1615456 {"progress":23}
[16:40:03.335] - Load 380928/1615456 {"progress":23}
[16:40:03.351] - Load 382976/1615456 {"progress":23}
[16:40:03.363] - Load 385024/1615456 {"progress":23}
[16:40:03.379] - Load 387072/1615456 {"progress":23}
[16:40:03.396] - Load 389120/1615456 {"progress":24}
[16:40:03.410] - Load 391168/1615456 {"progress":24}
[16:40:03.426] - Load 393216/1615456 {"progress":24}
[16:40:03.438] - Load 395264/1615456 {"progress":24}
[16:40:03.454] - Load 397312/1615456 {"progress":24}
[16:40:03.471] - Load 399360/1615456 {"progress":24}
[16:40:03.483] - Load 401408/1615456 {"progress":24}
[16:40:03.501] - Load 403456/1615456 {"progress":24}
[16:40:03.516] - Load 405504/1615456 {"progress":25}
[16:40:03.528] - Load 407552/1615456 {"progress":25}
[16:40:03.544] - Load 409600/1615456 {"progress":25}
[16:40:03.560] - Load 411648/1615456 {"progress":25}
[16:40:03.576] - Load 413696/1615456 {"progress":25}
[16:40:03.592] - Load 415744/1615456 {"progress":25}
[16:40:03.606] - Load 417792/1615456 {"progress":25}
[16:40:03.621] - Load 419840/1615456 {"progress":25}
[16:40:03.633] - Load 421888/1615456 {"progress":26}
[16:40:03.651] - Load 423936/1615456 {"progress":26}
[16:40:03.663] - Load 425984/1615456 {"progress":26}
[16:40:03.679] - Load 428032/1615456 {"progress":26}
[16:40:03.695] - Load 430080/1615456 {"progress":26}
[16:40:03.712] - Load 432128/1615456 {"progress":26}
[16:40:03.726] - Load 434176/1615456 {"progress":26}
[16:40:03.742] - Load 436224/1615456 {"progress":27}
[16:40:03.754] - Load 438272/1615456 {"progress":27}
[16:40:03.772] - Load 440320/1615456 {"progress":27}
[16:40:03.788] - Load 442368/1615456 {"progress":27}
[16:40:03.800] - Load 444416/1615456 {"progress":27}
[16:40:03.817] - Load 446464/1615456 {"progress":27}
[16:40:03.832] - Load 448512/1615456 {"progress":27}
[16:40:03.848] - Load 450560/1615456 {"progress":27}
[16:40:03.863] - Load 452608/1615456 {"progress":28}
[16:40:03.878] - Load 454656/1615456 {"progress":28}
[16:40:03.893] - Load 456704/1615456 {"progress":28}
[16:40:03.908] - Load 458752/1615456 {"progress":28}
[16:40:03.923] - Load 460800/1615456 {"progress":28}
[16:40:03.938] - Load 462848/1615456 {"progress":28}
[16:40:03.953] - Load 464896/1615456 {"progress":28}
[16:40:03.965] - Load 466944/1615456 {"progress":28}
[16:40:03.982] - Load 468992/1615456 {"progress":29}
[16:40:03.998] - Load 471040/1615456 {"progress":29}
[16:40:04.010] - Load 473088/1615456 {"progress":29}
[16:40:04.028] - Load 475136/1615456 {"progress":29}
[16:40:04.043] - Load 477184/1615456 {"progress":29}
[16:40:04.058] - Load 479232/1615456 {"progress":29}
[16:40:04.071] - Load 481280/1615456 {"progress":29}
[16:40:04.087] - Load 483328/1615456 {"progress":29}
[16:40:04.101] - Load 485376/1615456 {"progress":30}
[16:40:04.117] - Load 487424/1615456 {"progress":30}
[16:40:04.133] - Load 489472/1615456 {"progress":30}
[16:40:04.149] - Load 491520/1615456 {"progress":30}
[16:40:04.160] - Load 493568/1615456 {"progress":30}
[16:40:04.176] - Load 495616/1615456 {"progress":30}
[16:40:04.192] - Load 497664/1615456 {"progress":30}
[16:40:04.208] - Load 499712/1615456 {"progress":30}
[16:40:04.220] - Load 501760/1615456 {"progress":31}
[16:40:04.238] - Load 503808/1615456 {"progress":31}
[16:40:04.254] - Load 505856/1615456 {"progress":31}
[16:40:04.269] - Load 507904/1615456 {"progress":31}
[16:40:04.283] - Load 509952/1615456 {"progress":31}
[16:40:04.299] - Load 512000/1615456 {"progress":31}
[16:40:04.311] - Load 514048/1615456 {"progress":31}
[16:40:04.327] - Load 516096/1615456 {"progress":31}
[16:40:04.344] - Load 518144/1615456 {"progress":32}
[16:40:04.359] - Load 520192/1615456 {"progress":32}
[16:40:04.374] - Load 522240/1615456 {"progress":32}
[16:40:04.389] - Load 524288/1615456 {"progress":32}
[16:40:04.404] - Load 526336/1615456 {"progress":32}
[16:40:04.419] - Load 528384/1615456 {"progress":32}
[16:40:04.434] - Load 530432/1615456 {"progress":32}
[16:40:04.449] - Load 532480/1615456 {"progress":32}
[16:40:04.464] - Load 534528/1615456 {"progress":33}
[16:40:04.479] - Load 536576/1615456 {"progress":33}
[16:40:04.492] - Load 538624/1615456 {"progress":33}
[16:40:04.510] - Load 540672/1615456 {"progress":33}
[16:40:04.523] - Load 542720/1615456 {"progress":33}
[16:40:04.539] - Load 544768/1615456 {"progress":33}
[16:40:04.554] - Load 546816/1615456 {"progress":33}
[16:40:04.567] - Load 548864/1615456 {"progress":33}
[16:40:04.584] - Load 550912/1615456 {"progress":34}
[16:40:04.600] - Load 552960/1615456 {"progress":34}
[16:40:04.612] - Load 555008/1615456 {"progress":34}
[16:40:04.628] - Load 557056/1615456 {"progress":34}
[16:40:04.644] - Load 559104/1615456 {"progress":34}
[16:40:04.660] - Load 561152/1615456 {"progress":34}
[16:40:04.672] - Load 563200/1615456 {"progress":34}
[16:40:04.690] - Load 565248/1615456 {"progress":34}
[16:40:04.705] - Load 567296/1615456 {"progress":35}
[16:40:04.718] - Load 569344/1615456 {"progress":35}
[16:40:04.734] - Load 571392/1615456 {"progress":35}
[16:40:04.750] - Load 573440/1615456 {"progress":35}
[16:40:04.762] - Load 575488/1615456 {"progress":35}
[16:40:04.778] - Load 577536/1615456 {"progress":35}
[16:40:04.795] - Load 579584/1615456 {"progress":35}
[16:40:04.810] - Load 581632/1615456 {"progress":36}
[16:40:04.823] - Load 583680/1615456 {"progress":36}
[16:40:04.839] - Load 585728/1615456 {"progress":36}
[16:40:04.855] - Load 587776/1615456 {"progress":36}
[16:40:04.867] - Load 589824/1615456 {"progress":36}
[16:40:04.883] - Load 591872/1615456 {"progress":36}
[16:40:04.901] - Load 593920/1615456 {"progress":36}
[16:40:04.913] - Load 595968/1615456 {"progress":36}
[16:40:04.931] - Load 598016/1615456 {"progress":37}
[16:40:04.944] - Load 600064/1615456 {"progress":37}
[16:40:04.960] - Load 602112/1615456 {"progress":37}
[16:40:04.975] - Load 604160/1615456 {"progress":37}
[16:40:04.988] - Load 606208/1615456 {"progress":37}
[16:40:05.004] - Load 608256/1615456 {"progress":37}
[16:40:05.020] - Load 610304/1615456 {"progress":37}
[16:40:05.033] - Load 612352/1615456 {"progress":37}
[16:40:05.049] - Load 614400/1615456 {"progress":38}
[16:40:05.065] - Load 616448/1615456 {"progress":38}
[16:40:05.081] - Load 618496/1615456 {"progress":38}
[16:40:05.093] - Load 620544/1615456 {"progress":38}
[16:40:05.109] - Load 622592/1615456 {"progress":38}
[16:40:05.125] - Load 624640/1615456 {"progress":38}
[16:40:05.141] - Load 626688/1615456 {"progress":38}
[16:40:05.154] - Load 628736/1615456 {"progress":38}
[16:40:05.170] - Load 630784/1615456 {"progress":39}
[16:40:05.184] - Load 632832/1615456 {"progress":39}
[16:40:05.198] - Load 634880/1615456 {"progress":39}
[16:40:05.214] - Load 636928/1615456 {"progress":39}
[16:40:05.232] - Load 638976/1615456 {"progress":39}
[16:40:05.246] - Load 641024/1615456 {"progress":39}
[16:40:05.262] - Load 643072/1615456 {"progress":39}
[16:40:05.274] - Load 645120/1615456 {"progress":39}
[16:40:05.290] - Load 647168/1615456 {"progress":40}
[16:40:05.306] - Load 649216/1615456 {"progress":40}
[16:40:05.322] - Load 651264/1615456 {"progress":40}
[16:40:05.334] - Load 653312/1615456 {"progress":40}
[16:40:05.353] - Load 655360/1615456 {"progress":40}
[16:40:05.367] - Load 657408/1615456 {"progress":40}
[16:40:05.383] - Load 659456/1615456 {"progress":40}
[16:40:05.397] - Load 661504/1615456 {"progress":40}
[16:40:05.412] - Load 663552/1615456 {"progress":41}
[16:40:05.428] - Load 665600/1615456 {"progress":41}
[16:40:05.443] - Load 667648/1615456 {"progress":41}
[16:40:05.458] - Load 669696/1615456 {"progress":41}
[16:40:05.472] - Load 671744/1615456 {"progress":41}
[16:40:05.484] - Load 673792/1615456 {"progress":41}
[16:40:05.501] - Load 675840/1615456 {"progress":41}
[16:40:05.516] - Load 677888/1615456 {"progress":41}
[16:40:05.532] - Load 679936/1615456 {"progress":42}
[16:40:05.544] - Load 681984/1615456 {"progress":42}
[16:40:05.564] - Load 684032/1615456 {"progress":42}
[16:40:05.578] - Load 686080/1615456 {"progress":42}
[16:40:05.592] - Load 688128/1615456 {"progress":42}
[16:40:05.608] - Load 690176/1615456 {"progress":42}
[16:40:05.620] - Load 692224/1615456 {"progress":42}
[16:40:05.637] - Load 694272/1615456 {"progress":42}
[16:40:05.652] - Load 696320/1615456 {"progress":43}
[16:40:05.667] - Load 698368/1615456 {"progress":43}
[16:40:05.683] - Load 700416/1615456 {"progress":43}
[16:40:05.699] - Load 702464/1615456 {"progress":43}
[16:40:05.710] - Load 704512/1615456 {"progress":43}
[16:40:05.729] - Load 706560/1615456 {"progress":43}
[16:40:05.741] - Load 708608/1615456 {"progress":43}
[16:40:05.758] - Load 710656/1615456 {"progress":43}
[16:40:05.774] - Load 712704/1615456 {"progress":44}
[16:40:05.791] - Load 714752/1615456 {"progress":44}
[16:40:05.804] - Load 716800/1615456 {"progress":44}
[16:40:05.820] - Load 718848/1615456 {"progress":44}
[16:40:05.832] - Load 720896/1615456 {"progress":44}
[16:40:05.848] - Load 722944/1615456 {"progress":44}
[16:40:05.864] - Load 724992/1615456 {"progress":44}
[16:40:05.880] - Load 727040/1615456 {"progress":45}
[16:40:05.896] - Load 729088/1615456 {"progress":45}
[16:40:05.911] - Load 731136/1615456 {"progress":45}
[16:40:05.926] - Load 733184/1615456 {"progress":45}
[16:40:05.941] - Load 735232/1615456 {"progress":45}
[16:40:05.955] - Load 737280/1615456 {"progress":45}
[16:40:05.971] - Load 739328/1615456 {"progress":45}
[16:40:05.986] - Load 741376/1615456 {"progress":45}
[16:40:06.001] - Load 743424/1615456 {"progress":46}
[16:40:06.016] - Load 745472/1615456 {"progress":46}
[16:40:06.031] - Load 747520/1615456 {"progress":46}
[16:40:06.043] - Load 749568/1615456 {"progress":46}
[16:40:06.061] - Load 751616/1615456 {"progress":46}
[16:40:06.075] - Load 753664/1615456 {"progress":46}
[16:40:06.091] - Load 755712/1615456 {"progress":46}
[16:40:06.104] - Load 757760/1615456 {"progress":46}
[16:40:06.120] - Load 759808/1615456 {"progress":47}
[16:40:06.136] - Load 761856/1615456 {"progress":47}
[16:40:06.148] - Load 763904/1615456 {"progress":47}
[16:40:06.164] - Load 765952/1615456 {"progress":47}
[16:40:06.180] - Load 768000/1615456 {"progress":47}
[16:40:06.196] - Load 770048/1615456 {"progress":47}
[16:40:06.213] - Load 772096/1615456 {"progress":47}
[16:40:06.226] - Load 774144/1615456 {"progress":47}
[16:40:06.242] - Load 776192/1615456 {"progress":48}
[16:40:06.258] - Load 778240/1615456 {"progress":48}
[16:40:06.271] - Load 780288/1615456 {"progress":48}
[16:40:06.287] - Load 782336/1615456 {"progress":48}
[16:40:06.299] - Load 784384/1615456 {"progress":48}
[16:40:06.318] - Load 786432/1615456 {"progress":48}
[16:40:06.331] - Load 788480/1615456 {"progress":48}
[16:40:06.347] - Load 790528/1615456 {"progress":48}
[16:40:06.363] - Load 792576/1615456 {"progress":49}
[16:40:06.379] - Load 794624/1615456 {"progress":49}
[16:40:06.391] - Load 796672/1615456 {"progress":49}
[16:40:06.407] - Load 798720/1615456 {"progress":49}
[16:40:06.423] - Load 800768/1615456 {"progress":49}
[16:40:06.439] - Load 802816/1615456 {"progress":49}
[16:40:06.455] - Load 804864/1615456 {"progress":49}
[16:40:06.470] - Load 806912/1615456 {"progress":49}
[16:40:06.485] - Load 808960/1615456 {"progress":50}
[16:40:06.500] - Load 811008/1615456 {"progress":50}
[16:40:06.515] - Load 813056/1615456 {"progress":50}
[16:40:06.529] - Load 815104/1615456 {"progress":50}
[16:40:06.542] - Load 817152/1615456 {"progress":50}
[16:40:06.558] - Load 819200/1615456 {"progress":50}
[16:40:06.574] - Load 821248/1615456 {"progress":50}
[16:40:06.590] - Load 823296/1615456 {"progress":50}
[16:40:06.604] - Load 825344/1615456 {"progress":51}
[16:40:06.620] - Load 827392/1615456 {"progress":51}
[16:40:06.635] - Load 829440/1615456 {"progress":51}
[16:40:06.647] - Load 831488/1615456 {"progress":51}
[16:40:06.663] - Load 833536/1615456 {"progress":51}
[16:40:06.679] - Load 835584/1615456 {"progress":51}
[16:40:06.695] - Load 837632/1615456 {"progress":51}
[16:40:06.707] - Load 839680/1615456 {"progress":51}
[16:40:06.723] - Load 841728/1615456 {"progress":52}
[16:40:06.740] - Load 843776/1615456 {"progress":52}
[16:40:06.753] - Load 845824/1615456 {"progress":52}
[16:40:06.769] - Load 847872/1615456 {"progress":52}
[16:40:06.785] - Load 849920/1615456 {"progress":52}
[16:40:06.801] - Load 851968/1615456 {"progress":52}
[16:40:06.813] - Load 854016/1615456 {"progress":52}
[16:40:06.829] - Load 856064/1615456 {"progress":52}
[16:40:06.846] - Load 858112/1615456 {"progress":53}
[16:40:06.862] - Load 860160/1615456 {"progress":53}
[16:40:06.876] - Load 862208/1615456 {"progress":53}
[16:40:06.890] - Load 864256/1615456 {"progress":53}
[16:40:06.906] - Load 866304/1615456 {"progress":53}
[16:40:06.922] - Load 868352/1615456 {"progress":53}
[16:40:06.934] - Load 870400/1615456 {"progress":53}
[16:40:06.951] - Load 872448/1615456 {"progress":54}
[16:40:06.967] - Load 874496/1615456 {"progress":54}
[16:40:06.980] - Load 876544/1615456 {"progress":54}
[16:40:06.995] - Load 878592/1615456 {"progress":54}
[16:40:07.012] - Load 880640/1615456 {"progress":54}
[16:40:07.025] - Load 882688/1615456 {"progress":54}
[16:40:07.041] - Load 884736/1615456 {"progress":54}
[16:40:07.055] - Load 886784/1615456 {"progress":54}
[16:40:07.069] - Load 888832/1615456 {"progress":55}
[16:40:07.085] - Load 890880/1615456 {"progress":55}
[16:40:07.100] - Load 892928/1615456 {"progress":55}
[16:40:07.115] - Load 894976/1615456 {"progress":55}
[16:40:07.131] - Load 897024/1615456 {"progress":55}
[16:40:07.147] - Load 899072/1615456 {"progress":55}
[16:40:07.163] - Load 901120/1615456 {"progress":55}
[16:40:07.175] - Load 903168/1615456 {"progress":55}
[16:40:07.192] - Load 905216/1615456 {"progress":56}
[16:40:07.208] - Load 907264/1615456 {"progress":56}
[16:40:07.222] - Load 909312/1615456 {"progress":56}
[16:40:07.237] - Load 911360/1615456 {"progress":56}
[16:40:07.252] - Load 913408/1615456 {"progress":56}
[16:40:07.268] - Load 915456/1615456 {"progress":56}
[16:40:07.282] - Load 917504/1615456 {"progress":56}
[16:40:07.298] - Load 919552/1615456 {"progress":56}
[16:40:07.314] - Load 921600/1615456 {"progress":57}
[16:40:07.325] - Load 923648/1615456 {"progress":57}
[16:40:07.342] - Load 925696/1615456 {"progress":57}
[16:40:07.357] - Load 927744/1615456 {"progress":57}
[16:40:07.373] - Load 929792/1615456 {"progress":57}
[16:40:07.385] - Load 931840/1615456 {"progress":57}
[16:40:07.401] - Load 933888/1615456 {"progress":57}
[16:40:07.417] - Load 935936/1615456 {"progress":57}
[16:40:07.433] - Load 937984/1615456 {"progress":58}
[16:40:07.445] - Load 940032/1615456 {"progress":58}
[16:40:07.461] - Load 942080/1615456 {"progress":58}
[16:40:07.477] - Load 944128/1615456 {"progress":58}
[16:40:07.494] - Load 946176/1615456 {"progress":58}
[16:40:07.506] - Load 948224/1615456 {"progress":58}
[16:40:07.524] - Load 950272/1615456 {"progress":58}
[16:40:07.536] - Load 952320/1615456 {"progress":58}
[16:40:07.552] - Load 954368/1615456 {"progress":59}
[16:40:07.568] - Load 956416/1615456 {"progress":59}
[16:40:07.584] - Load 958464/1615456 {"progress":59}
[16:40:07.596] - Load 960512/1615456 {"progress":59}
[16:40:07.612] - Load 962560/1615456 {"progress":59}
[16:40:07.628] - Load 964608/1615456 {"progress":59}
[16:40:07.643] - Load 966656/1615456 {"progress":59}
[16:40:07.659] - Load 968704/1615456 {"progress":59}
[16:40:07.671] - Load 970752/1615456 {"progress":60}
[16:40:07.689] - Load 972800/1615456 {"progress":60}
[16:40:07.704] - Load 974848/1615456 {"progress":60}
[16:40:07.717] - Load 976896/1615456 {"progress":60}
[16:40:07.733] - Load 978944/1615456 {"progress":60}
[16:40:07.747] - Load 980992/1615456 {"progress":60}
[16:40:07.763] - Load 983040/1615456 {"progress":60}
[16:40:07.777] - Load 985088/1615456 {"progress":60}
[16:40:07.793] - Load 987136/1615456 {"progress":61}
[16:40:07.810] - Load 989184/1615456 {"progress":61}
[16:40:07.824] - Load 991232/1615456 {"progress":61}
[16:40:07.836] - Load 993280/1615456 {"progress":61}
[16:40:07.852] - Load 995328/1615456 {"progress":61}
[16:40:07.868] - Load 997376/1615456 {"progress":61}
[16:40:07.884] - Load 999424/1615456 {"progress":61}
[16:40:07.900] - Load 1001472/1615456 {"progress":61}
[16:40:07.915] - Load 1003520/1615456 {"progress":62}
[16:40:07.930] - Load 1005568/1615456 {"progress":62}
[16:40:07.944] - Load 1007616/1615456 {"progress":62}
[16:40:07.960] - Load 1009664/1615456 {"progress":62}
[16:40:07.975] - Load 1011712/1615456 {"progress":62}
[16:40:07.989] - Load 1013760/1615456 {"progress":62}
[16:40:08.005] - Load 1015808/1615456 {"progress":62}
[16:40:08.019] - Load 1017856/1615456 {"progress":63}
[16:40:08.034] - Load 1019904/1615456 {"progress":63}
[16:40:08.046] - Load 1021952/1615456 {"progress":63}
[16:40:08.064] - Load 1024000/1615456 {"progress":63}
[16:40:08.078] - Load 1026048/1615456 {"progress":63}
[16:40:08.094] - Load 1028096/1615456 {"progress":63}
[16:40:08.106] - Load 1030144/1615456 {"progress":63}
[16:40:08.122] - Load 1032192/1615456 {"progress":63}
[16:40:08.138] - Load 1034240/1615456 {"progress":64}
[16:40:08.154] - Load 1036288/1615456 {"progress":64}
[16:40:08.166] - Load 1038336/1615456 {"progress":64}
[16:40:08.184] - Load 1040384/1615456 {"progress":64}
[16:40:08.199] - Load 1042432/1615456 {"progress":64}
[16:40:08.215] - Load 1044480/1615456 {"progress":64}
[16:40:08.230] - Load 1046528/1615456 {"progress":64}
[16:40:08.242] - Load 1048576/1615456 {"progress":64}
[16:40:08.258] - Load 1050624/1615456 {"progress":65}
[16:40:08.274] - Load 1052672/1615456 {"progress":65}
[16:40:08.290] - Load 1054720/1615456 {"progress":65}
[16:40:08.302] - Load 1056768/1615456 {"progress":65}
[16:40:08.318] - Load 1058816/1615456 {"progress":65}
[16:40:08.335] - Load 1060864/1615456 {"progress":65}
[16:40:08.347] - Load 1062912/1615456 {"progress":65}
[16:40:08.363] - Load 1064960/1615456 {"progress":65}
[16:40:08.379] - Load 1067008/1615456 {"progress":66}
[16:40:08.395] - Load 1069056/1615456 {"progress":66}
[16:40:08.411] - Load 1071104/1615456 {"progress":66}
[16:40:08.423] - Load 1073152/1615456 {"progress":66}
[16:40:08.441] - Load 1075200/1615456 {"progress":66}
[16:40:08.457] - Load 1077248/1615456 {"progress":66}
[16:40:08.472] - Load 1079296/1615456 {"progress":66}
[16:40:08.487] - Load 1081344/1615456 {"progress":66}
[16:40:08.502] - Load 1083392/1615456 {"progress":67}
[16:40:08.517] - Load 1085440/1615456 {"progress":67}
[16:40:08.531] - Load 1087488/1615456 {"progress":67}
[16:40:08.547] - Load 1089536/1615456 {"progress":67}
[16:40:08.562] - Load 1091584/1615456 {"progress":67}
[16:40:08.577] - Load 1093632/1615456 {"progress":67}
[16:40:08.591] - Load 1095680/1615456 {"progress":67}
[16:40:08.607] - Load 1097728/1615456 {"progress":67}
[16:40:08.619] - Load 1099776/1615456 {"progress":68}
[16:40:08.635] - Load 1101824/1615456 {"progress":68}
[16:40:08.652] - Load 1103872/1615456 {"progress":68}
[16:40:08.664] - Load 1105920/1615456 {"progress":68}
[16:40:08.681] - Load 1107968/1615456 {"progress":68}
[16:40:08.696] - Load 1110016/1615456 {"progress":68}
[16:40:08.712] - Load 1112064/1615456 {"progress":68}
[16:40:08.728] - Load 1114112/1615456 {"progress":68}
[16:40:08.740] - Load 1116160/1615456 {"progress":69}
[16:40:08.754] - Load 1118208/1615456 {"progress":69}
[16:40:08.773] - Load 1120256/1615456 {"progress":69}
[16:40:08.789] - Load 1122304/1615456 {"progress":69}
[16:40:08.801] - Load 1124352/1615456 {"progress":69}
[16:40:08.817] - Load 1126400/1615456 {"progress":69}
[16:40:08.833] - Load 1128448/1615456 {"progress":69}
[16:40:08.847] - Load 1130496/1615456 {"progress":69}
[16:40:08.863] - Load 1132544/1615456 {"progress":70}
[16:40:08.879] - Load 1134592/1615456 {"progress":70}
[16:40:08.894] - Load 1136640/1615456 {"progress":70}
[16:40:08.907] - Load 1138688/1615456 {"progress":70}
[16:40:08.923] - Load 1140736/1615456 {"progress":70}
[16:40:08.938] - Load 1142784/1615456 {"progress":70}
[16:40:08.951] - Load 1144832/1615456 {"progress":70}
[16:40:08.966] - Load 1146880/1615456 {"progress":70}
[16:40:08.983] - Load 1148928/1615456 {"progress":71}
[16:40:08.998] - Load 1150976/1615456 {"progress":71}
[16:40:09.013] - Load 1153024/1615456 {"progress":71}
[16:40:09.029] - Load 1155072/1615456 {"progress":71}
[16:40:09.041] - Load 1157120/1615456 {"progress":71}
[16:40:09.057] - Load 1159168/1615456 {"progress":71}
[16:40:09.073] - Load 1161216/1615456 {"progress":71}
[16:40:09.087] - Load 1163264/1615456 {"progress":72}
[16:40:09.104] - Load 1165312/1615456 {"progress":72}
[16:40:09.116] - Load 1167360/1615456 {"progress":72}
[16:40:09.133] - Load 1169408/1615456 {"progress":72}
[16:40:09.149] - Load 1171456/1615456 {"progress":72}
[16:40:09.163] - Load 1173504/1615456 {"progress":72}
[16:40:09.179] - Load 1175552/1615456 {"progress":72}
[16:40:09.194] - Load 1177600/1615456 {"progress":72}
[16:40:09.209] - Load 1179648/1615456 {"progress":73}
[16:40:09.222] - Load 1181696/1615456 {"progress":73}
[16:40:09.238] - Load 1183744/1615456 {"progress":73}
[16:40:09.254] - Load 1185792/1615456 {"progress":73}
[16:40:09.266] - Load 1187840/1615456 {"progress":73}
[16:40:09.282] - Load 1189888/1615456 {"progress":73}
[16:40:09.298] - Load 1191936/1615456 {"progress":73}
[16:40:09.314] - Load 1193984/1615456 {"progress":73}
[16:40:09.329] - Load 1196032/1615456 {"progress":74}
[16:40:09.344] - Load 1198080/1615456 {"progress":74}
[16:40:09.360] - Load 1200128/1615456 {"progress":74}
[16:40:09.372] - Load 1202176/1615456 {"progress":74}
[16:40:09.388] - Load 1204224/1615456 {"progress":74}
[16:40:09.404] - Load 1206272/1615456 {"progress":74}
[16:40:09.420] - Load 1208320/1615456 {"progress":74}
[16:40:09.435] - Load 1210368/1615456 {"progress":74}
[16:40:09.450] - Load 1212416/1615456 {"progress":75}
[16:40:09.466] - Load 1214464/1615456 {"progress":75}
[16:40:09.480] - Load 1216512/1615456 {"progress":75}
[16:40:09.495] - Load 1218560/1615456 {"progress":75}
[16:40:09.510] - Load 1220608/1615456 {"progress":75}
[16:40:09.525] - Load 1222656/1615456 {"progress":75}
[16:40:09.538] - Load 1224704/1615456 {"progress":75}
[16:40:09.554] - Load 1226752/1615456 {"progress":75}
[16:40:09.568] - Load 1228800/1615456 {"progress":76}
[16:40:09.582] - Load 1230848/1615456 {"progress":76}
[16:40:09.598] - Load 1232896/1615456 {"progress":76}
[16:40:09.614] - Load 1234944/1615456 {"progress":76}
[16:40:09.630] - Load 1236992/1615456 {"progress":76}
[16:40:09.644] - Load 1239040/1615456 {"progress":76}
[16:40:09.658] - Load 1241088/1615456 {"progress":76}
[16:40:09.674] - Load 1243136/1615456 {"progress":76}
[16:40:09.690] - Load 1245184/1615456 {"progress":77}
[16:40:09.702] - Load 1247232/1615456 {"progress":77}
[16:40:09.721] - Load 1249280/1615456 {"progress":77}
[16:40:09.733] - Load 1251328/1615456 {"progress":77}
[16:40:09.751] - Load 1253376/1615456 {"progress":77}
[16:40:09.766] - Load 1255424/1615456 {"progress":77}
[16:40:09.781] - Load 1257472/1615456 {"progress":77}
[16:40:09.793] - Load 1259520/1615456 {"progress":77}
[16:40:09.809] - Load 1261568/1615456 {"progress":78}
[16:40:09.825] - Load 1263616/1615456 {"progress":78}
[16:40:09.841] - Load 1265664/1615456 {"progress":78}
[16:40:09.856] - Load 1267712/1615456 {"progress":78}
[16:40:09.871] - Load 1269760/1615456 {"progress":78}
[16:40:09.885] - Load 1271808/1615456 {"progress":78}
[16:40:09.901] - Load 1273856/1615456 {"progress":78}
[16:40:09.913] - Load 1275904/1615456 {"progress":78}
[16:40:09.928] - Load 1277952/1615456 {"progress":79}
[16:40:09.945] - Load 1280000/1615456 {"progress":79}
[16:40:09.961] - Load 1282048/1615456 {"progress":79}
[16:40:09.973] - Load 1284096/1615456 {"progress":79}
[16:40:09.988] - Load 1286144/1615456 {"progress":79}
[16:40:10.006] - Load 1288192/1615456 {"progress":79}
[16:40:10.022] - Load 1290240/1615456 {"progress":79}
[16:40:10.034] - Load 1292288/1615456 {"progress":79}
[16:40:10.050] - Load 1294336/1615456 {"progress":80}
[16:40:10.066] - Load 1296384/1615456 {"progress":80}
[16:40:10.081] - Load 1298432/1615456 {"progress":80}
[16:40:10.096] - Load 1300480/1615456 {"progress":80}
[16:40:10.109] - Load 1302528/1615456 {"progress":80}
[16:40:10.124] - Load 1304576/1615456 {"progress":80}
[16:40:10.141] - Load 1306624/1615456 {"progress":80}
[16:40:10.153] - Load 1308672/1615456 {"progress":81}
[16:40:10.169] - Load 1310720/1615456 {"progress":81}
[16:40:10.186] - Load 1312768/1615456 {"progress":81}
[16:40:10.202] - Load 1314816/1615456 {"progress":81}
[16:40:10.214] - Load 1316864/1615456 {"progress":81}
[16:40:10.230] - Load 1318912/1615456 {"progress":81}
[16:40:10.246] - Load 1320960/1615456 {"progress":81}
[16:40:10.263] - Load 1323008/1615456 {"progress":81}
[16:40:10.275] - Load 1325056/1615456 {"progress":82}
[16:40:10.292] - Load 1327104/1615456 {"progress":82}
[16:40:10.308] - Load 1329152/1615456 {"progress":82}
[16:40:10.323] - Load 1331200/1615456 {"progress":82}
[16:40:10.335] - Load 1333248/1615456 {"progress":82}
[16:40:10.352] - Load 1335296/1615456 {"progress":82}
[16:40:10.367] - Load 1337344/1615456 {"progress":82}
[16:40:10.383] - Load 1339392/1615456 {"progress":82}
[16:40:10.395] - Load 1341440/1615456 {"progress":83}
[16:40:10.414] - Load 1343488/1615456 {"progress":83}
[16:40:10.429] - Load 1345536/1615456 {"progress":83}
[16:40:10.444] - Load 1347584/1615456 {"progress":83}
[16:40:10.458] - Load 1349632/1615456 {"progress":83}
[16:40:10.474] - Load 1351680/1615456 {"progress":83}
[16:40:10.489] - Load 1353728/1615456 {"progress":83}
[16:40:10.504] - Load 1355776/1615456 {"progress":83}
[16:40:10.518] - Load 1357824/1615456 {"progress":84}
[16:40:10.534] - Load 1359872/1615456 {"progress":84}
[16:40:10.547] - Load 1361920/1615456 {"progress":84}
[16:40:10.562] - Load 1363968/1615456 {"progress":84}
[16:40:10.578] - Load 1366016/1615456 {"progress":84}
[16:40:10.594] - Load 1368064/1615456 {"progress":84}
[16:40:10.606] - Load 1370112/1615456 {"progress":84}
[16:40:10.623] - Load 1372160/1615456 {"progress":84}
[16:40:10.639] - Load 1374208/1615456 {"progress":85}
[16:40:10.652] - Load 1376256/1615456 {"progress":85}
[16:40:10.667] - Load 1378304/1615456 {"progress":85}
[16:40:10.684] - Load 1380352/1615456 {"progress":85}
[16:40:10.699] - Load 1382400/1615456 {"progress":85}
[16:40:10.712] - Load 1384448/1615456 {"progress":85}
[16:40:10.726] - Load 1386496/1615456 {"progress":85}
[16:40:10.742] - Load 1388544/1615456 {"progress":85}
[16:40:10.758] - Load 1390592/1615456 {"progress":86}
[16:40:10.774] - Load 1392640/1615456 {"progress":86}
[16:40:10.790] - Load 1394688/1615456 {"progress":86}
[16:40:10.802] - Load 1396736/1615456 {"progress":86}
[16:40:10.818] - Load 1398784/1615456 {"progress":86}
[16:40:10.835] - Load 1400832/1615456 {"progress":86}
[16:40:10.850] - Load 1402880/1615456 {"progress":86}
[16:40:10.862] - Load 1404928/1615456 {"progress":86}
[16:40:10.878] - Load 1406976/1615456 {"progress":87}
[16:40:10.894] - Load 1409024/1615456 {"progress":87}
[16:40:10.910] - Load 1411072/1615456 {"progress":87}
[16:40:10.925] - Load 1413120/1615456 {"progress":87}
[16:40:10.939] - Load 1415168/1615456 {"progress":87}
[16:40:10.955] - Load 1417216/1615456 {"progress":87}
[16:40:10.971] - Load 1419264/1615456 {"progress":87}
[16:40:10.986] - Load 1421312/1615456 {"progress":87}
[16:40:11.001] - Load 1423360/1615456 {"progress":88}
[16:40:11.015] - Load 1425408/1615456 {"progress":88}
[16:40:11.029] - Load 1427456/1615456 {"progress":88}
[16:40:11.045] - Load 1429504/1615456 {"progress":88}
[16:40:11.061] - Load 1431552/1615456 {"progress":88}
[16:40:11.073] - Load 1433600/1615456 {"progress":88}
[16:40:11.089] - Load 1435648/1615456 {"progress":88}
[16:40:11.105] - Load 1437696/1615456 {"progress":88}
[16:40:11.121] - Load 1439744/1615456 {"progress":89}
[16:40:11.133] - Load 1441792/1615456 {"progress":89}
[16:40:11.149] - Load 1443840/1615456 {"progress":89}
[16:40:11.166] - Load 1445888/1615456 {"progress":89}
[16:40:11.182] - Load 1447936/1615456 {"progress":89}
[16:40:11.194] - Load 1449984/1615456 {"progress":89}
[16:40:11.210] - Load 1452032/1615456 {"progress":89}
[16:40:11.225] - Load 1454080/1615456 {"progress":90}
[16:40:11.239] - Load 1456128/1615456 {"progress":90}
[16:40:11.253] - Load 1458176/1615456 {"progress":90}
[16:40:11.269] - Load 1460224/1615456 {"progress":90}
[16:40:11.286] - Load 1462272/1615456 {"progress":90}
[16:40:11.300] - Load 1464320/1615456 {"progress":90}
[16:40:11.316] - Load 1466368/1615456 {"progress":90}
[16:40:11.328] - Load 1468416/1615456 {"progress":90}
[16:40:11.344] - Load 1470464/1615456 {"progress":91}
[16:40:11.362] - Load 1472512/1615456 {"progress":91}
[16:40:11.374] - Load 1474560/1615456 {"progress":91}
[16:40:11.391] - Load 1476608/1615456 {"progress":91}
[16:40:11.407] - Load 1478656/1615456 {"progress":91}
[16:40:11.419] - Load 1480704/1615456 {"progress":91}
[16:40:11.435] - Load 1482752/1615456 {"progress":91}
[16:40:11.452] - Load 1484800/1615456 {"progress":91}
[16:40:11.464] - Load 1486848/1615456 {"progress":92}
[16:40:11.480] - Load 1488896/1615456 {"progress":92}
[16:40:11.496] - Load 1490944/1615456 {"progress":92}
[16:40:11.514] - Load 1492992/1615456 {"progress":92}
[16:40:11.527] - Load 1495040/1615456 {"progress":92}
[16:40:11.543] - Load 1497088/1615456 {"progress":92}
[16:40:11.559] - Load 1499136/1615456 {"progress":92}
[16:40:11.575] - Load 1501184/1615456 {"progress":92}
[16:40:11.587] - Load 1503232/1615456 {"progress":93}
[16:40:11.605] - Load 1505280/1615456 {"progress":93}
[16:40:11.621] - Load 1507328/1615456 {"progress":93}
[16:40:11.633] - Load 1509376/1615456 {"progress":93}
[16:40:11.649] - Load 1511424/1615456 {"progress":93}
[16:40:11.665] - Load 1513472/1615456 {"progress":93}
[16:40:11.681] - Load 1515520/1615456 {"progress":93}
[16:40:11.693] - Load 1517568/1615456 {"progress":93}
[16:40:11.709] - Load 1519616/1615456 {"progress":94}
[16:40:11.726] - Load 1521664/1615456 {"progress":94}
[16:40:11.738] - Load 1523712/1615456 {"progress":94}
[16:40:11.754] - Load 1525760/1615456 {"progress":94}
[16:40:11.771] - Load 1527808/1615456 {"progress":94}
[16:40:11.783] - Load 1529856/1615456 {"progress":94}
[16:40:11.799] - Load 1531904/1615456 {"progress":94}
[16:40:11.815] - Load 1533952/1615456 {"progress":94}
[16:40:11.829] - Load 1536000/1615456 {"progress":95}
[16:40:11.845] - Load 1538048/1615456 {"progress":95}
[16:40:11.861] - Load 1540096/1615456 {"progress":95}
[16:40:11.873] - Load 1542144/1615456 {"progress":95}
[16:40:11.889] - Load 1544192/1615456 {"progress":95}
[16:40:11.905] - Load 1546240/1615456 {"progress":95}
[16:40:11.921] - Load 1548288/1615456 {"progress":95}
[16:40:11.933] - Load 1550336/1615456 {"progress":95}
[16:40:11.952] - Load 1552384/1615456 {"progress":96}
[16:40:11.967] - Load 1554432/1615456 {"progress":96}
[16:40:11.981] - Load 1556480/1615456 {"progress":96}
[16:40:11.996] - Load 1558528/1615456 {"progress":96}
[16:40:12.012] - Load 1560576/1615456 {"progress":96}
[16:40:12.026] - Load 1562624/1615456 {"progress":96}
[16:40:12.041] - Load 1564672/1615456 {"progress":96}
[16:40:12.054] - Load 1566720/1615456 {"progress":96}
[16:40:12.072] - Load 1568768/1615456 {"progress":97}
[16:40:12.084] - Load 1570816/1615456 {"progress":97}
[16:40:12.100] - Load 1572864/1615456 {"progress":97}
[16:40:12.116] - Load 1574912/1615456 {"progress":97}
[16:40:12.132] - Load 1576960/1615456 {"progress":97}
[16:40:12.148] - Load 1579008/1615456 {"progress":97}
[16:40:12.163] - Load 1581056/1615456 {"progress":97}
[16:40:12.175] - Load 1583104/1615456 {"progress":97}
[16:40:12.191] - Load 1585152/1615456 {"progress":98}
[16:40:12.207] - Load 1587200/1615456 {"progress":98}
[16:40:12.223] - Load 1589248/1615456 {"progress":98}
[16:40:12.235] - Load 1591296/1615456 {"progress":98}
[16:40:12.251] - Load 1593344/1615456 {"progress":98}
[16:40:12.268] - Load 1595392/1615456 {"progress":98}
[16:40:12.281] - Load 1597440/1615456 {"progress":98}
[16:40:12.297] - Load 1599488/1615456 {"progress":99}
[16:40:12.314] - Load 1601536/1615456 {"progress":99}
[16:40:12.325] - Load 1603584/1615456 {"progress":99}
[16:40:12.341] - Load 1605632/1615456 {"progress":99}
[16:40:12.357] - Load 1607680/1615456 {"progress":99}
[16:40:12.375] - Load 1609728/1615456 {"progress":99}
[16:40:12.387] - Load 1611776/1615456 {"progress":99}
[16:40:12.403] - Load 1613824/1615456 {"progress":99}
[16:40:12.415] - Load 1615456/1615456 {"progress":100}
[16:40:12.415] - Write check
[16:40:12.419] - Flash load time cost(ms): 11884.870849609375
[16:40:12.419] - Finished
[16:40:12.427] - Sha caled by host: fff56e48c8902437239c3a6a7f27f05ac46c68da6fc2ca59e6717e7706f099b4
[16:40:12.427] - xip mode Verify
[16:40:13.766] - Read Sha256/1615456
[16:40:13.766] - Flash xip readsha time cost(ms): 1339.30078125
[16:40:13.766] - Finished
[16:40:13.768] - Sha caled by dev: fff56e48c8902437239c3a6a7f27f05ac46c68da6fc2ca59e6717e7706f099b4
[16:40:13.768] - Verify success
[16:40:13.769] - Program Finished
[16:40:13.769] - All time cost(ms): 24370.42724609375
[16:40:13.876] - close interface
[16:40:13.876] - [All Success]
cp ./../aithinker_Ai-M6X_SDK/tools/bflb_tools/bouffalo_flash_cube/chips/bl616/img_create/whole_flash_data.bin build/build_out/
自己的帖,自己顶,好像是烧进去了
2023-10-17 15:09:56
编译成功了,但是会有找不到文件的提示。
烧录也成功了,提示 [All Success]
http://bbs.ai-thinker.com/forum. ... amp;_dsign=4e5076ce
  • 会员数: 30896 个
  • 话题数: 44868 篇
