AiPi-SCP-4.3固件编译成功,求送个开发板!
molun
技术杂谈 1250 4 2023-9-1 20:33:13
2023/9/1 拉取最新代码
AiPi-SCP-4.3固件编译成功,AiPi-SCP-2.4依旧编译失败。
  1. d:/ai-thinker/toolchain_gcc_t-head_windows/bin/../lib/gcc/riscv64-unknown-elf/10.2.0/../../../../riscv64-unknown-elf/bin/ld.exe: build_out\mqtt_bl616.elf section `.nocache_ram_region' will not fit in region `nocache_ram_memory'
  2. d:/ai-thinker/toolchain_gcc_t-head_windows/bin/../lib/gcc/riscv64-unknown-elf/10.2.0/../../../../riscv64-unknown-elf/bin/ld.exe: region `nocache_ram_memory' overflowed by 11524 bytes
  3. collect2.exe: error: ld returned 1 exit status
  4. make[3]: *** [CMakeFiles\mqtt_bl616.elf.dir\build.make:116: build_out/mqtt_bl616.elf] Error 1
  5. make[2]: *** [CMakeFiles\Makefile2:734: CMakeFiles/mqtt_bl616.elf.dir/all] Error 2
  6. make[1]: *** [Makefile:90: all] Error 2
  7. make: *** [../aithinker_Ai-M6X_SDK/project.build:73: build] Error 2
固件都编译上了,还会没开发板没
AiPi-SCP-4.3,没货别想了
2023-9-2 08:20:53
jkernet 发表于 2023-9-1 23:07
固件都编译上了,还会没开发板没
没有哇,新鲜出炉的板子,还没有开始送呢
2023-9-17 20:44:18
点赞~
  • 会员数: 31167 个
  • 话题数: 42249 篇
