AI-M61 怎么用c++编译呢
沈夜
Ai-M61系列 1282 4 2024-11-30 01:02:05
直接编译 爆非常多的错误,该修改哪呢
make[1]: *** [/y/code/bl602/wb3/Ai-Thinker-WB2/make_scripts_riscv/component_wrapper.mk:313: evb/src/strntoumax.o] Error 1
make[1]: *** Waiting for unfinished jobs....
make: *** [/y/code/bl602/wb3/Ai-Thinker-WB2/applications/get-started/helloworld/../../../make_scripts_riscv/project.mk:577: component-bl602-build] Error 2
make: *** Waiting for unfinished jobs....
make: *** [/y/code/bl602/wb3/Ai-Thinker-WB2/applications/get-started/helloworld/../../../make_scripts_riscv/project.mk:577: component-blmtd-build] Error 2
make[1]: *** [/y/code/bl602/wb3/Ai-Thinker-WB2/make_scripts_riscv/component_wrapper.mk:313: src/fdt_ro.o] Error 1
make[1]: *** [/y/code/bl602/wb3/Ai-Thinker-WB2/make_scripts_riscv/component_wrapper.mk:313: bl602_std/StdDriver/Src/bl602_adc.o] Error 1
make: *** [/y/code/bl602/wb3/Ai-Thinker-WB2/applications/get-started/helloworld/../../../make_scripts_riscv/project.mk:577: component-blfdt-build] Error 2
make: *** [/y/code/bl602/wb3/Ai-Thinker-WB2/applications/get-started/helloworld/../../../make_scripts_riscv/project.mk:577: component-bl602_std-build] Error 2
make[1]: *** [/y/code/bl602/wb3/Ai-Thinker-WB2/make_scripts_riscv/component_wrapper.mk:313: blog.o] Error 1
make: *** [/y/code/bl602/wb3/Ai-Thinker-WB2/applications/get-started/helloworld/../../../make_scripts_riscv/project.mk:577: component-blog-build] Error 2
马上抓个技术给你解决~
这不是602吗,汇编出问题了吧,我看工具链里是支持CPP特性的
2024-12-2 17:29:40
改成了 man.cpp 报错很多,
沈夜 发表于 2024-12-2 17:29
改成了 man.cpp 报错很多,
你加一下extern C符号
  • 会员数: 31178 个
  • 话题数: 42267 篇
