AI-WV02-32S 无法烧录 ErrorCode: 003B, ErrorMsg: BFLB FLASH SET PARA FAIL
cosmicpower
小安AI 1077 2 2026-5-2 10:33:27
操作步骤
1. 接到AI-WV02-32S 确认能正常语音控制小智
2. 确认了AI-WV02-32S供电为3.27V
3. 计划更新AI-WV02-32S的固件
a. 按住 boot 键,按下 reset 键,松开 reset 键,松开 boot,进入烧录模式。
b. 开始烧录
下面是完整的log
[10:30:01.819] - ========= Interface is Uart =========
[10:30:01.822] - eflash loader bin is eflash_loader_auto.bin
[10:30:01.823] - ========= chip flash id: ef4016 =========
[10:30:01.830] - create partition.bin, pt_new is True
[10:30:01.847] - Create bootheader using G:\Software\安信可\BouffaloLabDevCube-v1.9.0\BouffaloLabDevCube-v1.9.0\chips\bl616\img_create_iot\efuse_bootheader_cfg.ini
[10:30:01.847] - Updating data according to <G:\Software\安信可\BouffaloLabDevCube-v1.9.0\BouffaloLabDevCube-v1.9.0\chips\bl616\img_create_iot\efuse_bootheader_cfg.ini[BOOTHEADER_GROUP0_CFG]>
[10:30:01.850] - Created file len:256
[10:30:01.851] - custom_vendor_boot_offset not exist
[10:30:01.852] - Create
efuse using G:\Software\安信可\BouffaloLabDevCube-v1.9.0\BouffaloLabDevCube-v1.9.0\chips\bl616\img_create_iot\efuse_bootheader_cfg.ini
[10:30:01.853] - Updating data according to <G:\Software\安信可\BouffaloLabDevCube-v1.9.0\BouffaloLabDevCube-v1.9.0\chips\bl616\img_create_iot\efuse_bootheader_cfg.ini[EFUSE_CFG]>
[10:30:01.854] - Created file len:512
[10:30:01.860] - ========= sp image create =========
[10:30:01.861] - Image hash is b'e3b0c44298fc1c149afbf4c8996fb92427ae41e4649b934ca495991b7852b855'
[10:30:01.861] - Hash ignored
[10:30:01.861] - Header crc ignored
[10:30:01.861] - Write flash img
[10:30:01.862] - Encrypt efuse data
[10:30:01.918] - Create bootheader using G:\Software\安信可\BouffaloLabDevCube-v1.9.0\BouffaloLabDevCube-v1.9.0\chips\bl616\img_create_iot\efuse_bootheader_cfg.ini
[10:30:01.918] - Updating data according to <G:\Software\安信可\BouffaloLabDevCube-v1.9.0\BouffaloLabDevCube-v1.9.0\chips\bl616\img_create_iot\efuse_bootheader_cfg.ini[BOOTHEADER_GROUP0_CFG]>
[10:30:01.921] - Created file len:256
[10:30:01.922] - custom_vendor_boot_offset not exist
[10:30:01.923] - Create efuse using G:\Software\安信可\BouffaloLabDevCube-v1.9.0\BouffaloLabDevCube-v1.9.0\chips\bl616\img_create_iot\efuse_bootheader_cfg.ini
[10:30:01.924] - Updating data according to <G:\Software\安信可\BouffaloLabDevCube-v1.9.0\BouffaloLabDevCube-v1.9.0\chips\bl616\img_create_iot\efuse_bootheader_cfg.ini[EFUSE_CFG]>
[10:30:01.927] - Created file len:512
[10:30:01.931] - ========= sp image create =========
[10:30:02.074] - img already have bootheader
[10:30:02.086] - Image hash is b'7e67d1b4f541e2530878ff3eb14ae1fd5cc9915f5730e8c56ec04ec549f55ec7'
[10:30:02.086] - Header crc: b'5fc2fa3b'
[10:30:02.086] - Write flash img
[10:30:02.099] - Encrypt efuse data
[10:30:02.103] - FW Header is 256, 3840 still needed
[10:30:02.104] - FW OTA bin header is Done. Len is 4096
[10:30:02.318] - BL60X_OTA_Ver1.0
[10:30:02.543] - FW OTA bin is Done. Len is 3646464
[10:30:03.858] - OTA XZ file len = 1861144
[10:30:03.859] - Partiton len = 3663616
[10:30:03.860] - BL60X_OTA_Ver1.0
[10:30:03.990] - FW OTA xz is Done
[10:30:03.991] - ========= eflash loader config =========
[10:30:04.263] - True
[10:30:04.266] - Version: eflash_loader_v2.5.1
[10:30:04.267] - Program Start
[10:30:04.267] - ========= eflash loader cmd arguments =========
[10:30:04.267] - Config file: G:\Software\安信可\BouffaloLabDevCube-v1.9.0\BouffaloLabDevCube-v1.9.0\chips\bl616\eflash_loader/eflash_loader_cfg.ini
[10:30:04.268] - serial port is COM6
[10:30:04.268] - cpu_reset=False
[10:30:04.269] - chiptype: bl616
[10:30:04.269] - ========= Interface is uart =========
[10:30:04.269] - com speed: 115200
[10:30:04.270] - Bootrom load
[10:30:04.270] - ========= get_boot_info =========
[10:30:04.270] - ========= image get bootinfo =========
[10:30:04.534] - Not ack OK
[10:30:04.534] - FL
[10:30:04.535] - result: FL
[10:30:04.812] - tx rx and power off, press the machine!
[10:30:04.813] - cutoff time is 0.05
[10:30:04.876] - power on tx and rx
[10:30:05.869] - reset cnt: 0, reset hold: 0.05, shake hand delay: 0.1
[10:30:05.869] - clean buf
[10:30:05.885] - send sync
[10:30:06.122] - ack is 4f4b
[10:30:06.169] - shake hand success
[10:30:06.686] - data read is b'0200160600000100279280010545a54b781c9c000f7580102099e95a'
[10:30:06.686] - ========= chipid: 1c784ba54505 =========
[10:30:06.687] - Get bootinfo time cost(ms): 2416.671630859375
[10:30:06.687] - change bdrate: 115200
[10:30:06.687] - Clock PLL set
[10:30:06.690] - Set clock time cost(ms): 3.0
[10:30:06.851] - Read mac addr
[10:30:06.856] - macaddr: 1c784ba54505
[10:30:06.856] - flash set para
[10:30:06.856] - get flash pin cfg from bootinfo: 0x02
[10:30:06.856] - set flash cfg: 14102
[10:30:06.856] - Set flash config
[10:30:10.876] - Retry
[10:30:14.447] - Retry
[10:30:18.473] - Retry
[10:30:22.034] - ErrorCode: 003B, ErrorMsg: BFLB FLASH SET PARA FAIL
[10:30:22.034] - Burn Retry
[10:30:22.034] - 0
[10:30:22.034] - Burn return with retry fail
1. 分区表方式,AiPi-PalChatV2 可以成功写入,但AI-WV-02S不行
2. Single download options,也不行
接线方式
是裸板链接的,
测试数量
2 pcs 都是一样的问题
2026-5-27 11:28:57
回帖奖励 +1 金钱
问题好久了,不知道解决了没有。按住boot不松开,然后点软件上的create&download按键,应该就可以烧录成功了。
shawn 发表于 2026-5-27 11:28
问题好久了,不知道解决了没有。按住boot不松开,然后点软件上的create&download按键,应该就可以烧录成功 ...
我也遇到了这种情况,但是boot长按烧录也没成功,请问还有什么方法吗?
  • 会员数: 31223 个
  • 话题数: 42325 篇
