PB03F如何使用P18的ADC功能啊
xmcxsta
PB&TG系列 808 5 2025-5-27 14:58:58
SDK好奇怪啊,P18是差分输入,但是把P18屏蔽了,怎么用啊,example ADC里也说了differential_mode is rarely used,
    if use please config channel as one of [ADC_CH3DIFF,ADC_CH2DIFF,ADC_CH1DIFF],
    and is_high_resolution as one of [0x80,0x20,0x08],
    then the pair of [P20~P15,P14~P13,P12~P11] will work.
    other adc channel cannot work(没有说P18怎么用)
2025-5-27 15:03:47
typedef enum
    ADC_CH0DIFF = 1,/*p18(positive),p25(negative),only works in diff*/
    ADC_CH0 = 2,ADC_CH1N_P11 = 2,
    ADC_CH1 = 3,ADC_CH1P_P23 = 3,ADC_CH1DIFF = 3,/*P23 and P11*/
    ADC_CH2 = 4,ADC_CH2N_P24 = 4,
    ADC_CH3 = 5,ADC_CH2P_P14 = 5,ADC_CH2DIFF = 5,/*P14 and P24*/
    ADC_CH4 = 6,ADC_CH3N_P15 = 6,
    ADC_CH9 = 7,ADC_CH3P_P20 = 7,ADC_CH3DIFF = 7,/*P20 and P15*/
    ADC_CH_VOICE = 8,
    ADC_CH_NUM =9,
} adc_CH_t;
int hal_adc_compare_enable(adc_CH_t ch,uint32_t flag,uint32_t th_high,uint32_t th_low)
    int i=0;
    if((ch >= ADC_CH1N_P11) && (ch <=ADC_CH3P_P20))// 差分配置相关的都是把P18屏蔽了,啥意思
2025-5-27 15:05:25
if(cfg.is_differential_mode != 0)
        if((cfg.is_differential_mode != 0x80) && (cfg.is_differential_mode != 0x20) && (cfg.is_differential_mode != 0x08))
            return PPlus_ERR_INVALID_PARAM;///和下面自相矛盾啊
switch(cfg.is_differential_mode)
        case 0x80:
            pin = P20;
            pin_neg = P15;
            chn_sel = 0x04;
            evt_index = 7;
            break;
        case 0x20:
            pin = P14;
            pin_neg = P24;
            chn_sel = 0x03;
            evt_index = 5;
            break;
        case 0x08:
            pin = P23;
            pin_neg = P11;
            chn_sel = 0x02;
            evt_index = 3;
            break;
        case 0x02:
            pin = P18;
            pin_neg = P25;
            chn_sel = 0x01;
            evt_index = 1;
            *(volatile int*)(0x4000F020) = 0x0060;
            break;
今天我们的蓝牙技术外出了,需要等他回来了才能回复。
        if((cfg.is_differential_mode != 0x80) && (cfg.is_ ...
目前此芯片P18的差分功能无法使用,此模块没有P25引脚,无法实现P18的差分功能,SDK例子提供的是单端模式的例程。
2025-5-28 13:44:49
Ai-Thinker-wu 发表于 2025-5-28 08:49
目前此芯片P18的差分功能无法使用,此模块没有P25引脚,无法实现P18的差分功能,SDK例子提供的是单端模式 ...
PB03F规格书写着P18  GPIO18/ADC input 7/PGA negative input;赶紧修改了,我就去看规格书分配管脚的
  • 会员数: 31129 个
  • 话题数: 44729 篇
