LED摇摇棒 - AI-M61-32S-kit开发板
iiv
插眼大队大队长
电子DIY 8233 17 2023-11-7 22:31:51
大家好,作为一个入门级点灯大侠的楼楼,每次在接触到新的mcu都会拿它点亮各种各样的灯,这也是老传统了,相信很多人都会像楼楼一样,楼楼最近用安信可的M61-32S-kit开发板做了一个摇摇棒,分享给大家,如果喜欢的话可以打一块玩玩。
工程链接:点我
效果展示:
楼楼最开始是想着让它朝一个方向转的,所以搞的是红外管,后来发现太重了,转不太动,然后就成了摇摇棒,可以把红外的位置换成震动开关,这样就可以定位啦。
实物展示:
正面就是这个样子,电路很简单,通过gpio直接驱动每一颗发光二极管,一共16颗,m61开发板直接扣在排母上面就可以了。
背面沾了一块3.7v锂电池
通电后的样子,楼楼没有搞开关,所以它上电就会启动。
摇起来的样子,我摇,我摇,我使劲摇(好累....)
大概就是这个样子,其实这个原理也很简单,没有什么可说的,通过取模软件把点阵数据取出来,然后通过逐列逐个取出每一位数据来控制led的亮灭,只要循环一直这样做,就可以达到摇摇棒的效果,别的也没什么可说的,非常简单。
代码部分:
main.c
  1. #include "bflb_mtimer.h"
  2. #include "bflb_gpio.h"
  3. #include "board.h"
  4. struct bflb_device_s *gpio;
  5. uint8_t data[5][32] = {
  6.               {0x80,0x00,0x90,0x80,0x8C,0x80,0x84,0x84,0x84,0x46,0x84,0x49,0xF5,0x28,0x86,0x10,0x84,0x10,0x84,0x2C,0x84,0x23,0x84,0x40,0x94,0x80,0x8C,0x00,0x80,0x00,0x00,0x00},/*"安",0*/
  7.               {0x00,0x01,0x80,0x00,0x60,0x00,0xF8,0xFF,0x07,0x00,0x00,0x00,0x04,0x00,0x24,0xF9,0x24,0x49,0x25,0x49,0x26,0x49,0x24,0x49,0x24,0x49,0x24,0xF9,0x04,0x00,0x00,0x00},/*"信",1*/
  8.               {0x00,0x00,0x02,0x00,0x02,0x00,0xF2,0x0F,0x12,0x04,0x12,0x04,0x12,0x04,0xF2,0x0F,0x02,0x00,0x02,0x40,0x02,0x80,0xFE,0x7F,0x02,0x00,0x02,0x00,0x02,0x00,0x00,0x00},/*"可",2*/
  9.               {0x24,0x08,0x24,0x06,0xA4,0x01,0xFE,0xFF,0xA3,0x00,0x22,0x01,0x00,0x04,0x22,0x04,0xCC,0x04,0x00,0x04,0x00,0x04,0xFF,0xFF,0x00,0x02,0x00,0x02,0x00,0x02,0x00,0x00},/*"科",3*/
  10.               {0x10,0x04,0x10,0x44,0x10,0x82,0xFF,0x7F,0x10,0x01,0x90,0x80,0x08,0x80,0x88,0x40,0x88,0x43,0x88,0x2C,0xFF,0x10,0x88,0x28,0x88,0x46,0x88,0x81,0x08,0x80,0x00,0x00},/*"技",4*/
  11.
  12.               };
  13. uint8_t leds[] = {10,11,12,13,14,15,16,17,18,19,20,23,24,25,26,27};
  14. void led_play(uint8_t idx, int delay){
  15.     uint8_t index = 0;
  16.     for(uint8_t i=0;i<16;i++){
  17.         for(uint8_t n=0;n<8;n++){
  18.             uint8_t d = data[idx][index];
  19.             if(((d>>n) & 0x01) == 0){
  20.                 bflb_gpio_reset(gpio,leds[n]);
  21.
  22.             }else{
  23.                 bflb_gpio_set(gpio,leds[n]);
  24.
  25.             }
  26.         }
  27.         index++;
  28.         for(uint8_t n=0;n<8;n++){
  29.             uint8_t d = data[idx][index];
  30.             if(((d>>n) & 0x01) == 0){
  31.                 bflb_gpio_reset(gpio,leds[n+8]);
  32.             }else{
  33.                 bflb_gpio_set(gpio,leds[n+8]);
  34.
  35.             }
  36.         }
  37.         index++;
  38.         bflb_mtimer_delay_us(delay);
  39.     }
  40. }
  41. void del_led(uint8_t idx, int delay){
  42.     uint8_t index = 30;
  43.     for(uint8_t i=0;i<16;i++){
  44.         for(uint8_t n=0;n<8;n++){
  45.             uint8_t d = data[idx][index];
  46.             if(((d>>n) & 0x01) == 0){
  47.                 bflb_gpio_reset(gpio,leds[n]);
  48.
  49.             }else{
  50.                 bflb_gpio_set(gpio,leds[n]);
  51.
  52.             }
  53.         }
  54.         index++;
  55.         for(uint8_t n=0;n<8;n++){
  56.             uint8_t d = data[idx][index];
  57.             if(((d>>n) & 0x01) == 0){
  58.                 bflb_gpio_reset(gpio,leds[n+8]);
  59.             }else{
  60.                 bflb_gpio_set(gpio,leds[n+8]);
  61.
  62.             }
  63.         }
  64.         index -= 3;
  65.         bflb_mtimer_delay_us(delay);
  66.     }
  67. }
  68. int main(void)
  69. {
  70.     int dey = 800;
  71.     board_init();
  72.     gpio = bflb_device_get_by_name("gpio");
  73.     for(uint8_t i=0;i<16;++i){
  74.         bflb_gpio_init(gpio, leds[i], GPIO_OUTPUT|GPIO_PULLDOWN);
  75.         bflb_gpio_reset(gpio,leds[i]);
  76.     }
  77.     printf("hello world\r\n");
  78.     while (1) {
  79.         for(int i=0;i<5;i++){
  80.             led_play(i,dey);
  81.         }
  82.         // for(int j=5;j>0;j--){
  83.         //     del_led(j,dey);
  84.         // }
  85.     }
  86. }
好啦,以上就是全部内容,代码比较简单,先把字模数据保存到数组,然后循环遍历每一个字,最后一直循环就可以了,楼楼这只是一个很简单的,只能显示固定的内容,我们可以使用小程序连接m61的蓝牙或者wifi来给摇摇棒进行更新显示的内容(图片或者文字),还可以增加灯珠的数量,做成旋转的led屏,如果大家有兴趣的话我们可以一下研究。
棒棒哒
完全看不懂,都不知道写的啥
学习了,跟我猜的一样
2023-11-8 08:26:05
以前用51单片机做过,七哥这个不用水银开关吗?
直接就循环扫描?
2023-11-8 08:35:12
这手速 可以的
2023-11-8 08:35:27
完全看不懂不知道写的啥
2023-11-8 08:36:04
没有视频效果吗七哥~
2023-11-8 09:51:58
就说七哥有货
2023-11-8 20:08:03
直接就循环扫描?
要,不然没法搞位置,我瞎玩的,留了红外的位置,后来发现转不起来太重了,后面再改一下
  • 会员数: 31266 个
  • 话题数: 42377 篇
