AI-WB2-01F烧录失败询问
夜雨喧嚣
Ai-WB2系列 1015 3 2025-5-8 15:17:26
我这边的测试代码,在12F和13的开发板上下载都是正常的,但是在01F的模组上烧录就有问题,我看了一下,编译的分区表是2M的
错误报错如下
  1. [15:07:24.000] - ========= flash read jedec ID =========
  2. [15:07:24.000] - Flash load shake hand
  3. [15:07:24.025] - default set DTR high
  4. [15:07:24.140] - clean buf
  5. [15:07:24.143] - send sync
  6. [15:07:24.361] - ack is b'afa7'
  7. [15:07:24.362] - reshake
  8. [15:07:24.362] - sleep
  9. [15:07:27.375] - default set DTR high
  10. [15:07:27.483] - clean buf
  11. [15:07:27.486] - send sync
  12. [15:07:27.593] - ack is b''
  13. [15:07:27.594] - retry
  14. [15:07:27.595] - {"ErrorCode": "0001","ErrorMsg":"BFLB EFLASH LOADER SHAKEHAND FAIL"}
  15. [15:07:27.595] - {"ErrorCode": "0030","ErrorMsg":"BFLB READ FLASH JEDEC ID FAIL"}
  16. [15:07:27.596] - Burn Retry
  17. [15:07:27.596] - 0
  18. [15:07:27.596] - Burn return with retry fail
开发板数据如下
  1. [15:06:54.195] - ========= flash read jedec ID =========
  2. [15:06:54.195] - Flash load shake hand
  3. [15:06:54.213] - default set DTR high
  4. [15:06:54.319] - clean buf
  5. [15:06:54.321] - send sync
  6. [15:06:54.552] - ack is b'4f4b'
  7. [15:06:54.585] - Read flash jedec ID
  8. [15:06:54.586] - readdata:
  9. [15:06:54.586] - b'5e401680'
  10. [15:06:54.586] - Finished
  11. [15:06:54.589] - Program operation
  12. [15:06:54.590] - Dealing Index 0
这个是代码里要做修改吗?
boot可能不一样,你用1.7.4或者1.8.0的看看
2025-5-8 18:00:49
感谢,换1.7.4就好了
不错,要学习一下
  • 会员数: 31059 个
  • 话题数: 44945 篇
